CALIBRATION SONY G90
contemplationaveugle
Posted: Tue Mar 10, 2009 10:59 am    Post subject: CALIBRATION SONY G90
First of all sorry for my bad English
Hi I post this subject in France for those interested in the calibration sony G90.
It was the dochlywd's Sony g90
Video Configuration:
- Platinum source TOSHIBA HD XE1 (fw 2.7)
- HDMI / DVI REAL CABLE (5m)
- Broadcaster tritube SONY VPH G90
- Input card IFB DVI johnHWman
- Screen for the moment there is not projected on the wall but it will happen
- Room not dedicated black soil
Calibration configuration
- PC xp pro
- Software HCFR
- Spyder probe 2
- HD DVD AVS Rods
- Measurement of the window 100 IRE to 12.8 ftl
Settings:
- TOSHIBA XE1
-contrast -7 (large white or burnt)
7-lum
-sat -1
- SONY G90
defocal-on
Defocus-blue + between 20 and 30 (important for any TT that gamma is blue in the right place!)
Result:
Below 30 IRE the spyder 2 is not quite accurate, I will make a new measurement with the probe HCFR
 Filesize:  253.98 KB
 Viewed:  16210 Time(s)
 Filesize:  46.76 KB
 Viewed:  18053 Time(s)
 Filesize:  253.98 KB
 Viewed:  16205 Time(s)
 Filesize:  214.11 KB
 Filesize:  172.95 KB
 Filesize:  191.32 KB
 Filesize:  212.17 KB
huggy
Posted: Tue Mar 10, 2009 11:23 am    Post subject:
I wish I knew what those graphs meant Sad
Posted: Tue Mar 10, 2009 11:33 am    Post subject:
This graphics software HCFR colorimetry.
The curves correspond to the RGB levels, the color temperature must be at 6500, the gammas to be located at 2.2 and the color saturation
WTS
Posted: Tue Mar 10, 2009 1:12 pm    Post subject:
I have never used the probe that you are using but I would say it looks pretty good overall except for the extreme low end.
Walter
n@t
Posted: Tue Mar 10, 2009 1:50 pm    Post subject:
your Gamma Settings are bad!
2,5-2,6 is better.
Regards Bernd
think positiv
Posted: Tue Mar 10, 2009 4:14 pm    Post subject:
2,5-2,6 is better.
Regards Bernd
Not true. Anywhere between 2.2 and 2.5 is good. It all depends on the room and viewer preferences.
If the room is a 'bat cave' (100% black) with lots of light control to get rid of reflections off the walls/floor/ceiling then closer to 2.5 (less gamma boost) may be ok.
If the room is the way I see it above with white walls I would suggest that he stick with more gamma of around 2.2 (lower numbers means more gamma boost).
For what it's worth my room's somewhere in between and I still prefer 2.2 on my setup.
Really nice results on the graphs! Other than the sub-30 IRE readings (which few meters do right) everything looks bang on to me! I wouldn't change a thing!
Posted: Tue Mar 10, 2009 4:16 pm    Post subject:
Easy solution. Read my guide:
I explain them all and how to do your greyscale from scratch. I assume the reader knows nothing about any of this stuff.
dochlywd
Posted: Tue Mar 10, 2009 4:51 pm    Post subject:
Cedric!
Glad to hear you're dialing it in!!! I hope you are enjoying the great pic that the G90 can produce. I forgot to ask what screen you are using? It almost looks like a painted flat wall.
Posted: Tue Mar 10, 2009 6:00 pm    Post subject:
2,5-2,6 is better.
Regards Bernd
Exactly, kal, you have anticipated me for the answer!
Gamma to 2.2 was necessary because I don't have a completely dark room.
For values below 30 IRE I think the spyder probe is not precise enough to measure. I'll try another probe (HCFR) is better in measures of dark or with my crysatlio 2 I will try to correct these values.
Posted: Tue Mar 10, 2009 6:06 pm    Post subject:
dochlywd wrote:
Cedric!
Thank you, exactly for the time being I plan on painting my wall, but the screen will happen!
My resolution is 1920x817p71.94
Posted: Tue Mar 10, 2009 7:01 pm    Post subject:
contemplationaveugle wrote:
dochlywd wrote:
Cedric!
Nice choice on that resolution... one of my favorites Smile
Charts look really good too. And as you suggest, the Spider will not measure accurately below 30 IRE. Most likely your gray scale is good below 30 IRE because G90's track very flatly in general.
Have you ever spoke with John? He's a fellow Frenchman who is very good with the G90's. Here is a link to his web page.
http://johnhwman.free.fr//index.html
Posted: Tue Mar 10, 2009 7:11 pm    Post subject:
Also, for what it's worth, I think gamma of around 2.2 on a G90 is plenty high. The G90's somehow appear to have a higher gamma than they really do. Don't ask me why or how that can be, but I usually set G90's up with 2.2 ~ 2.3.
Posted: Tue Mar 10, 2009 8:04 pm    Post subject:
Definitely talk to John (Jean) if you have questions too... I think he has about 5 G90's now. Wink
Posted: Tue Mar 10, 2009 8:19 pm    Post subject:
I know john! I see that it is successful here.
I have often over the phone, I learned a lot with him, it is a person available who is listening.
He helped me to communicate with dochlywd to bring the G90 in France.
Posted: Tue Mar 10, 2009 8:29 pm    Post subject:
John has given me a lot of help over the years too Smile
Very smart man.
Posted: Wed Mar 11, 2009 12:41 am    Post subject:
Michael if you want the history and changes in your sony G90 in France here is a link :
http://www.cinetson.org/phpBB3/tritubes-f7/mon-nouveau-jouet-sony-vph-g90-t27117.html
I just bought 3 tubes p19lug to put in place with c green marquee element 9500.
I look at the work of mike parker 1080p72 on the G90.
I will try with my crystalio 2 a flea from Algolith.
Posted: Wed Mar 11, 2009 12:45 am    Post subject:
For the eyes Wink
 Filesize:  98.62 KB
 Viewed:  17922 Time(s)
NewbieDAN
Posted: Wed Mar 11, 2009 1:11 am    Post subject:
For the eyes Wink
A bikini would make this shot much better Wink
Posted: Wed Mar 11, 2009 2:11 am    Post subject:
I don't get it is she going to stab you in the eyes for bringing this big monstrosity into her home?Very Happy
On your link, it looks like you bought it last year. I hope you get good use out of it. With the chip issue, the G90s are risky purchases these days.
Posted: Wed Mar 11, 2009 1:48 pm    Post subject:
The issue with the failing chip is being blown out of proportion IMHO. I mean how many have actually failed this way??? I know of no more than 10 G90's, and most were fixed with doner YA boards out of parts units. Sure it is a pain if you own one, but parts unit G90's are becoming available these days and the chances that you will be effected are very low...
