Marquee 8500 - 4 parrallel lines across screen (photo)
radar
Posted: Fri Feb 27, 2009 11:25 am    Post subject: Marquee 8500 - 4 parrallel lines across screen (photo)
I have a Marquee 8500 which only recently I notice 4 faint lines across a plain white screen. I swiched colours and noticed its only really appears on the blue. Changing source makes no apparent difference. What I did notice is that when I have the Horizontal frequency at 15hz, all 3 colours have 4 faint lines (very hard to see), but on the blue tube, the lines are more visible. The lines are in a different spot depending on the colour. If I increase the HF to 30hz, the red and green remain the same, but the blue is more noticeable still. When I increase to 48hz, the lines on the blue tube is very visible. Have a look at the photo. I have heard of banding, but I don't know if this is it. I have also tried moving the 'bow' as I heard this causes banding? But this makes no difference... it just makes the lines 'bowed'!
[/img]
Any idea what this is and how to fix?
Kevin.
 Filesize:  64.07 KB
 Viewed:  9820 Time(s)
Posted: Fri Feb 27, 2009 11:56 am    Post subject:
Yepp I had the same thing, cleaned the chips on the CLM and the DPB chip U7 especialy. Try that one first as you dont have to remove the DPB from the CLM to fix it. You will need and ic puller to get it off. If you have no cleaner try putting it in and taking out a few times to remove the oxidation. The DPB controls the frequencies so it most likely is that. But also check the HDM and its smaller daughter board. That needs to be cleaned up as well. You may have removeable chips on the smaller boar as well.
Here is some thing to look at :
http://www.avsforum.com/avs-vb/showthread.php?t=1079352&highlight=marquee+flickers
Posted: Fri Feb 27, 2009 1:14 pm    Post subject:
I have one CLM here with a similar problem, and it wasn't socketed chips, it's a fault somewhere on the board. If cleaning the chips doesn't work, send it to me and I can repair or swap it out with a spare.
Posted: Fri Feb 27, 2009 2:08 pm    Post subject:
You know curt you might be right,IIRC I think i had to re solder a few caps that had cold solder joints near one of the chips under the DPB, I first had it doing what this pic above showed then it would randomly re initialize the PJ after about 30 minutes.
I don't know which capacitor it was as I did a whole bunch at the same time, But they were the buffering caps next to the socketed IC's. Check those Curt.
Posted: Fri Feb 27, 2009 3:15 pm    Post subject:
Funny, I'm learning the importance about buffering caps, despite being in electronics for 30+ years. I just worked on 3 boards, all of which had open caps causing random problems.
Posted: Fri Feb 27, 2009 3:21 pm    Post subject:
WOW!!! that makes me feel better about the things I have learned this past two years !! I think in electronics there is never
an end to what there is to learn.
Posted: Fri Feb 27, 2009 9:28 pm    Post subject:
Hello
Try unplugging the blue convergence yoke, see what that does if anything.
Posted: Fri Feb 27, 2009 11:58 pm    Post subject:
That's a really weird one there.
I'm also thinking the HDM or LVPS.
Posted: Sat Feb 28, 2009 12:49 am    Post subject:
Hello
I can't tell from the picture; either the luminance is unstable or the raster is bunching and spreading.
Posted: Sat Feb 28, 2009 12:55 am    Post subject:
I still think its a cold solder joint somewhere on the CLM, look at this thread from AVS. I linked to some pics he had of the same issue. it was acold solder joint on U44, he posted a pic further down the thread.
http://www.avsforum.com/avs-vb/showthread.php?p=14571495#post14571495
radar
Posted: Sat Feb 28, 2009 2:17 am    Post subject:
I unplugged the blue convergence yoke from the back board (in the middle) and the problem went away. Does this narrow things down?
radar
Posted: Sat Feb 28, 2009 2:37 am    Post subject:
Ok... read AVS... let me check U44 as per Nashou66.
BTW... fantastic to get such help from all the top 8500 guys!!!
Posted: Sat Feb 28, 2009 4:53 am    Post subject:
It would not be the H board, the lines would be vertical if that was the case. It's either a bad convergence output board (unlikely) or bad info coming from the CLM to the convergence board
radar
Posted: Sat Feb 28, 2009 7:37 am    Post subject:
U44 is good. I tested it with a multimeter. The next step (I suppose) is touch up as many joints as I can with the multimeter looking for dry joints on the CLM. MAN... there are a LOT of places to look.
One thing to note is that its only really happening on the Blue... not all colours. I'm assuming the CLM treats each colour seperately. If not, then maybe its not the CLM?
One of the problems with being in Sydney, Australia , is I think I'm the only bloke within (literally) 10,000miles of the next person with a M8500.
Curt... have you ever spoken to anyone in Australia with a Marquee? If there was, I'd at least have a chance of swapping over the CLM to narrow things down. Also, can you pls send me a PM with cost of a working CLM you might have. If I can't find the problem, it may actually be cheaper to just send a working one rather than sending mine all the way to Vancouver.
radar
Posted: Sat Feb 28, 2009 11:04 am    Post subject:
Is it safe to run the PJ without the DPB? This could narrow it down to the DPB if the fault goes away.
Also, I don't have a chip puller.... Any safe way to remove the chips without one or should I just go buy one just to do this once off diagnosis?!
Posted: Sat Feb 28, 2009 11:47 am    Post subject:
It wont run with out the board. that sends all the frequency signals and band switching. I guaranty its the DPB chips and or the CLM chips that need a cleaning. Any Computer store should have an IC chip puller. it can be done with two thin screw drivers but you could damage a pin if it doesn't pop out straight up.
radar
Posted: Sun Mar 01, 2009 10:16 am    Post subject:
Ok... bought the chip puller (US$7). Pulled all the removable chips off the DPB and refitted them three times each. Put card back in PJ. No change. Pulled all the removable chips off the CLM and refitted them three times each. Put card back in PJ. No change.
Next step... buy a magnifying glass and go over the DPB and CLM and look for dry joints. If I find the little rascal I'll report back here.
If no luck, then it looks like replacement time.
Any further suggestions to isolate given its only the circuits affecting the BLUE tube only?
fishlogan
Posted: Sun Mar 01, 2009 10:47 am    Post subject:
i thought you get those lines from excessive zone adjustment. If i try to correct my green geometry with too much zone i get that tearing horizontal line like your pic
try adjusting your zones with an all white screen and adjust them too their full hoiz range and se if it makes it better or worse
also, where in aus are you?
Posted: Sun Mar 01, 2009 12:52 pm    Post subject:
You could try this but i never have but seen it done on youtube and mentioned here and other forums. Heat up your oven to about 250 f and bake it till some of the solder joints get soft, then take it out and let it cool. I never tried this so just a warning. But lots of manufactures actually do this or more specific wave form soldering ovens.
I may test it with a spare board i have here that has been acting up and I dont use.
Posted: Sun Mar 01, 2009 10:47 pm    Post subject:
Heat up your oven to about 250 f and bake it till some of the solder jonints get soft, then take it out and let it cool. I never tried this so just a warning. But lots of manufactures actually do this or more specific wave form soldering ovens.
This is a very good method for SOME PC boards, but you'll need to first make sure it'll work on the board you intend to fix using this method.
It works well with basic boards that are not multi level solder through. More complex boards that has massive IC pin connections and solder through points can be damaged using this method. Especially older boards. they are already stretching and warping, and that's the nature of the problems. When fixing them with an oven method they can stretch and warp even more, to include loose some contacts all together.
this is a very good idea for new boards. older boards have taking on a different personality, and have become very finicky with age and heat.
