Has anyone successfully used old Barco EHT part in new Barco
Goto page Previous  1, 2, 3
Decibel
Posted: Sat May 16, 2009 12:19 pm    Post subject:
Ok the new frame is out Very Happy
Domenico (Barco fan!)
Decibel
Posted: Sat May 16, 2009 1:23 pm    Post subject:
Comparation new/old frame
Decibel
Posted: Sat May 16, 2009 1:29 pm    Post subject:
So ... if I will remove existent jumper and solder a new jumper in other holes can I use this new motherboard/frame with older eht/splitter/quadrupler?
Thanks in advance
secstate
Posted: Sat May 23, 2009 1:06 am    Post subject:
Thanks in advance
Yes that should do it, but honestly Curt's trick of modding the EHT board is much easier.
Decibel
Posted: Sun May 24, 2009 5:22 pm    Post subject:
Ok ... thank you ... but I have a unused chassis with new frame and some boards (without tubes and other).
So ...to remove the frame is very simple and solder the new jumper too Thumbs Up
Posted: Sun May 24, 2009 5:58 pm    Post subject:
Leave both jumpers in place. That way you can use either the old or new EHT board. THe main thing is, the new quad and new EHT board cannot be mixed with the old quad or EHT board. That's where you get very short life EHT boards.
Decibel
Posted: Wed Jul 29, 2009 3:04 pm    Post subject:
Curt
Are you sure that I must to leave both jumpers?
See here
Posted: Wed Jul 29, 2009 3:31 pm    Post subject:
You don't HAVE to, but all that jumper does is switch the location of the +300 volt feed, so it's not damaging anything if you leave both in place.
Page 3 of 3
