HaydnG90
| Posted: Mon Feb 16, 2009 11:05 pm Post subject: |
| Quote: | | Terry. After this weekend I'm not sure what my scheduling is going to be like. I'm in SC and about 5 hours from you so traveling may be difficult just yet. But if all parties agree here is my thought. If Haydn want to send you his YA board for you to test on your test chassis to verify exactly what he has, then send me his board and your parts board, I can swap parts based on our conclusion. If we believe its possibly ic421, then I'll swap that chip only for the first test. I'll then ship boards back to you for testing. A little difficult for now shipping back and forth but its a start. I'll now better after the weekend if there would be other options. Let me know. |
Sounds good to me. This may be the only way I'll get my YA board repaired after being down for almost a year.
If this leads to an understanding of which components are the root of these YA board failures even better.
As a matter of interest, can failure of one component eg IC421 lead to failure of another associated part such as IC431 or vice versa. I can see how a power surge might take out multiple chips but my G90 was on a surge protector and there was no power glitch at the time of the failure.
Chuchuf
| Posted: Tue Feb 17, 2009 3:47 am Post subject: |
| stefuel wrote: | | Can you see the chip and touch it when it's running? If so, take a pencil eraser end and put pressure on each leg and watch for reaction. I'll bet the chip gets so hot that the legs are coming un-soldered from the inside just like the STK's in a NEC. |
Good thought, but this is just not the case on the YA board in general. It is a very cool running board and there is very little to no heat build up so I doubt that these failures have anything to do with heat at all. I tested a few today out of the chassis on extenders looking at heat as a possible culprit for up to an hour of operation.
Terry
Chuchuf
| Posted: Tue Feb 17, 2009 3:53 am Post subject: |
| HaydnG90 wrote: |
As a matter of interest, can failure of one component eg IC421 lead to failure of another associated part such as IC431 or vice versa. I can see how a power surge might take out multiple chips but my G90 was on a surge protector and there was no power glitch at the time of the failure. |
Personally I recommend that G90's be run with USP's (not surge protectors or power conditioners) that can handle the 1050 peak watts it can consume.
My personal feeling on these random failures we have seen with G90's which include tubes cracking and YA failures, have something to do with the PA board and the AC power coming into the unit. I have never been able to prove this BUT those using UPS's who have had failures prior did not have a failure after the use of a UPS. That much I do know.
Terry
Chuchuf
| Posted: Tue Feb 17, 2009 3:56 am Post subject: |
| macgyver655 wrote: | | Chuchuf wrote: | macgyver655, you are in TN correct?? I'm in GA.
I have an idea that might allow us to track down Haydns problem.
I have a few YA boards here that have unknown problems, that we could possible use for parts.
What I lack is the equipment to R&R these parts, which I believe you have.
I also have a test bed G90(with burnt tubes in it currently so if we have a failure that collapses the beam no big deal), but I don't know how much longer this test bed will be here.
If we could get Haydns YA board and figure out a way for you and I together with yours and my equipment, we might be able to solve his problem.
BTW RogueChili, I have extenders for the YA board thanks to John.
Terry |
We will have to see about doing it that way. My biggest concern is I don't have control over how long this G90 will be here and I was hoping that we could do something in one day. You know, try stuff and if that didn't work, try something else.
Haydn, maybe you should make arrangement to get me your YA board ASAP. If Curt has it he has my address.
Terry
JohnHWman
Joined: 15 May 2007 Posts: 215 Location: France - Grenoble
TV/Projector: Sony VPH-G90U (one unit for me, four others units repaired and sold)
| Posted: Tue Feb 17, 2009 8:31 am Post subject: |
Terry, Ron, Curt,
- I do have Oliverg's YA board that is probably defective on IC421,
- I just received two parts of CXD2309Q from an Ebay seller in Malaysia but I don't think this part failed on oliverg's board (as G2 is stable, image is only shaking). I bought them because there were cheap and just in case...
- I do have a G90 test chassis with burned tubes available with a working YA board. The problem is that this unit is already sold to a customer and I'm currently retubing the unit with Barco 9" bare tubes (Thanks Terry),
- I do have all the tools to R&R IC421 chip on Oliverg's board (Metcal MX-500P solder station with proper size TQFP dessoldering tool). I also have a very good japanese binoccular magnifier to let me resolder the chip on the board.
I really don't wanna take the risk of removing the working IC421 part from the Test chassis unit and mount it on Oliverg's YA board to confirm that this completely solve the issue. This is too risky about the working YA board I've got and which is from a G90 unit that is already sold and paid
Curt or Terry : if you have another defective YA board known to have a working IC421, maybe you can send me this card so I can recover the chip and mount it on Oliverg's board to try. The only issue is that I'm located in France and maybe Ron is closer to you to make this chip replacement and let you test on one of your test units. On the other hand, If I do it, this leaves you time to investigate Haydn YA board failure in the same time
John
_________________ Home theater enthusiast for over 20 years !
My dedicated HT room !
RogueChili
Joined: 31 Mar 2008 Posts: 162 Location: Westfield, MA
| Posted: Tue Feb 17, 2009 2:12 pm Post subject: |
John, the theory of operations shows the output signal sequence and timing for the controller chip and the best I can tell there are test points on the YA board allowing access to these signals. Verifying if the chip is functional properly should be straight forward! Am I missing something here?
JohnHWman
| Posted: Tue Feb 17, 2009 2:44 pm Post subject: |
Yes RoqueChili,
I've used these tests points two years ago when I discovered that IC421 had failed on curt's YA board : http://www.avsforum.com/avs-vb/showthread.php?p=9824398#post9824398
Checking IC421 'CE' signal and output communication clock out of the chip (using test points) can easely tells if IC421 is defective... Since I've build YA board extenders, it's now very easy to check.
John
Chuchuf
| Posted: Wed Feb 18, 2009 6:15 pm Post subject: |
John,
Sent you an email. Let me know if you get it.
Terry
JohnHWman
| Posted: Wed Feb 18, 2009 6:40 pm Post subject: |
I've got it Terry
John
| Posted: Fri Feb 20, 2009 1:22 am Post subject: |
I just saw this thread for the first time.
Just to let everyone know, I have a fully functional G90 test unit here with burnt tubes that I plan to hold onto for a while... It's open for testing.
| Posted: Fri Feb 20, 2009 1:26 am Post subject: |
| CIR Engineering wrote: | I just saw this thread for the first time.
craigr |
That is good to know. Some things are in the works now. Well see how things go.
| Posted: Fri Feb 20, 2009 2:25 pm Post subject: |
I also have an SMD rework station here and am pretty comfortable with working on high dollar stuff. However, pulling the chip off a working YA may be more risk than I am willing to assume on my own... due to the possibility of a pretty bad financial loss.
JohnHWman
| Posted: Tue Feb 24, 2009 8:38 am Post subject: Some more bad news ... |
Here is the reply from my japanese friend upon CXD305-127R internal structure informations :
Hi John,
In recent couple of weeks Ixxx-san and Axxxxx-san(Sony Co.) worked hard to get answer for you and G90 user request.
However so far they realized that Sony or Sony related company never provide internal design information and software etc. to anyone including Ixxxx-san too.
So it will be mostly impossible to get the same.
The only thing I've got from Ixxxx-san is to deliver New YA board with CXD305-127R chips from distributor in Japan.
There are few boards available and Ixxxx-san can deliver it to anywhere.
The cost is not cheap , something like $2500 or more.
please let me know your thought.
thanks,
h.
At least, there is some 'like-new' YA boards available in Japan Bad new is the price of these
Let me know if someone want to go that route despite the price, I'll ask.
I'm affraid that we should do Reverse Engineering job on this chip sooner or later
John
| Posted: Tue Feb 24, 2009 9:36 am Post subject: |
John that REALLY sucks !
From now on no more Sony products for me.
Let them design their way out of existence...
| Posted: Tue Feb 24, 2009 10:40 am Post subject: |
Non of this does me any good. It won't sway Pete from dumping on AmPros. The good news is there will be a flurry of great tubes and lenses available for you hardcore Marquee guys to play with.
_________________ Chip
| Posted: Tue Feb 24, 2009 11:21 am Post subject: Re: Some more bad news ... |
| JohnHWman wrote: |
There are few boards available and Isobe-san can deliver it to anywhere.
John |
And I'm sure they could make that happen because they'll be using chips from a different chip manufacturer. And these same original chips are most likely the work of that same chip manufacturer.
If the G90 was designed and built back in the 70's or early 80's, I would go along with them having a chip designed specifically for that control board. But no one (but maybe NASA and some other Aerospace Industrial operations) has need for specially designed chips. Almost all electronic stuff the past 20 years has been going with what the chip manufacturers have to offer. It just does not make a lot of sense to design and use a special chip for a control board for a video projector. maybe so for a computer used to auto-pilot an airplane or submarine. But why would any manufacturer waste the money to design a chip as such for a projector control system. What's really complex and so special there?
I remember a few years back when talking to one of the former Electrohome Engineers about a particular part they used in the Marquee. I asked why did they use such a crappy part in a particular circuit. And said for a few pennies more, they could have used a much better part. He replied that the use of more expensive parts happens only if they are really necessary, because they have eyes on keeping all cost as low as possible. And that the difference in the parts price is huge on paper with the people who keeps their eyes on cost.
Now, If Sony had a special chip designed it would be very costly for the design and manufacture. And that same chip because it would be designed for one product only, it would also be an expensive chip because of its limited use. that just don't make sense for them to go that way. especially when there's a bunch of off-the-shelf options already available from every chip manufacturer.
Some years back, you could criss-cross devices (Ic's and transistors). They even had a few books out on this. And over the years I've found a many chip with such names a NEC, Mitsubishi and some others that had an exact chip that was also available from some of the chip manufacturers. Everything on the chip itself was different, but it was the same chip.
If you look at the chips being used on the YA board, they all look different physically, yet they have the same Sony part number system.
my 5 cent
| Posted: Tue Feb 24, 2009 1:18 pm Post subject: |
Even though I already knew all that Mike, reading it again in your post has moved me into your direction. Maybe we should start looking at all the 80 pin DAC controllers and their pin-outs to try and see if we can find something similar.
If someone sends me a broken YA I could put a socket on the board and we could test lots of DAC controllers in a working G90 that way.
JohnHWman
| Posted: Tue Feb 24, 2009 1:45 pm Post subject: Re: Some more bad news ... |
| mp20748 wrote: | | Now, If Sony had a special chip designed it would be very costly for the design and manufacture. And that same chip because it would be designed for one product only, it would also be an expensive chip because of its limited use. that just don't make sense for them to go that way. | Unless this chip is based on general purpose CPLD that was programmed by Sony LSI company people to realize the DACs controler job. Then it is just software design that can be done quite easely without any silicon wafer build
John
JohnHWman
| Posted: Tue Mar 31, 2009 8:00 pm Post subject: |
Okay Gents,
Here is an update and a confirmation of the source of the "image shaking" problem !
My test was made on Oliverg's original YA board that he sent me almost 10 months ago for servicing his "image shaking problem" on his G90 unit.
First I've re-checked about Oliverg's YA board behaviour on my test chassis unit : image was shaking as hell...
I've then spent a couple of hours to carefully remove the suspected 'defective' IC421 (CXD305-127R) chip, clean the footprint pads on the PCB and replace it with a known 'working' CXD305-127R chip (taken from a working YA board).
I've resolder all the chip's pins pin by pin under my binocular magnifier and checked that I've made no shorts between pins (this IC is rare and costly !).
Once everything was visually checked OK, I've re-installed the YA board within my test unit and fire-it up : Image is now really stable and all parameters (contrast, brightness, convergences, ...) are well updated through the remote
Conclusion : The image shaking problem comes ONLY from this CXD305-127R chip failure... This confirm my own finding when I've sent the YA board of my second G90 unit two years ago to Sony at San Jose (for the same 'image shaking' issue) and where I found that they replaced IC421 when the board came back to me (after spending $1650 for the service to Sony ).
Now Oliverg's YA board is fully OK
John
