| Posted: Thu Jan 15, 2009 3:15 pm Post subject: |
| jkruger wrote: | | So all we need to do is take the box over to someone's house that has a valid card and borrow it for a few minutes to set the menu for antenna? |
This probably wont work either as the cards marry the receiver as stated above. You could try a valid card but probably wont work but you never know. Your just trying to get into the menu. Location of the receiver doesn't matter so someone else's dish wont help at all.There is another option but really shouldnt be discussed on here. I'll do a little experimenting later.
| Posted: Thu Jan 15, 2009 3:38 pm Post subject: |
Let me know if you can find a work around ! I got one and it worked fine until I left it unplugged to power for a year ?
| Posted: Thu Jan 15, 2009 3:41 pm Post subject: |
| Tom.W wrote: | | Let me know if you can find a work around ! I got one and it worked fine until I left it unplugged to power for a year ? |
Did you have the original card for it?
| Posted: Thu Jan 15, 2009 3:51 pm Post subject: |
Yes
| Posted: Thu Jan 15, 2009 3:59 pm Post subject: |
Cant you bring up a menu and select no dish? What cant you do or what does the onscreen say?
| Posted: Thu Jan 15, 2009 4:02 pm Post subject: |
No display at all. Will have to check the power supply. Was working OK before storage. Tried resetting the card but no luck...
| Posted: Thu Jan 15, 2009 4:16 pm Post subject: |
Pull the card, hook up to tv, plug it in and see if you get "Please insert a valid card".
jkruger
| Posted: Thu Jan 15, 2009 4:41 pm Post subject: |
My dad and I had a couple of TS360's, so I knew about needing an access card - any access card, old or new, active or not - just to be able to get the receiver to fully boot so you can access the menus and turn off the DirecTV part of the receiver... But the last post about it being dead until it was plugged into the wall outlet for 18 hours... Now, THAT'S weird.
| Posted: Thu Jan 15, 2009 5:14 pm Post subject: |
| ecrabb wrote: | My dad and I had a couple of TS360's, so I knew about needing an access card - any access card, old or new, active or not - just to be able to get the receiver to fully boot so you can access the menus and turn off the DirecTV part of the receiver... But the last post about it being dead until it was plugged into the wall outlet for 18 hours... Now, THAT'S weird.
SC |
Hmmm wonder if the dead one I have need to be plugged in? I have VCR's like that. Dead for 12 hours then they'll work for years. JVC's usually.
| Posted: Thu Jan 15, 2009 5:15 pm Post subject: |
| macgyver655 wrote: | | jkruger wrote: | | So all we need to do is take the box over to someone's house that has a valid card and borrow it for a few minutes to set the menu for antenna? |
This probably wont work either as the cards marry the receiver as stated above. You could try a valid card but probably wont work but you never know. Your just trying to get into the menu. Location of the receiver doesn't matter so someone else's dish wont help at all.There is another option but really shouldnt be discussed on here. I'll do a little experimenting later. |
Heywood is lending me a card. I'll let you know how it goes.
| Posted: Thu Jan 15, 2009 7:01 pm Post subject: |
| AnalogRocks wrote: | | macgyver655 wrote: | | jkruger wrote: | | So all we need to do is take the box over to someone's house that has a valid card and borrow it for a few minutes to set the menu for antenna? |
Heywood is lending me a card. I'll let you know how it goes. |
Maybe it will work even if the card is not married. Ecrabb said it worked for him....
Did you try the boot sequence that was in the link that jkruger posted?
| Posted: Fri Jan 16, 2009 12:15 am Post subject: |
| AnalogRocks wrote: | | ecrabb wrote: | My dad and I had a couple of TS360's, so I knew about needing an access card - any access card, old or new, active or not - just to be able to get the receiver to fully boot so you can access the menus and turn off the DirecTV part of the receiver... But the last post about it being dead until it was plugged into the wall outlet for 18 hours... Now, THAT'S weird.
SC |
Hmmm wonder if the dead one I have need to be plugged in? I have VCR's like that. Dead for 12 hours then they'll work for years. JVC's usually. |
OK this is downright strange. I left mine plugged in for about 6-7 hours and now it works. Before it looked dead to the world...
| Posted: Fri Jan 16, 2009 12:33 am Post subject: |
Welcome to......................the Twilight Zone nenene nee ne ne ne neee....
| macgyver655 wrote: | | AnalogRocks wrote: | | macgyver655 wrote: | | jkruger wrote: | | So all we need to do is take the box over to someone's house that has a valid card and borrow it for a few minutes to set the menu for antenna? |
Did you try the boot sequence that was in the link that jkruger posted? |
Not yet. I'll give it a try in a bit. Just bussy with work here
-Pjackso
| Posted: Fri Jan 16, 2009 3:02 am Post subject: |
Heads-up to everyone.
The link that jkruger posted on how to reset the TS360 has a virus. My Norton Antivirus gave me a warning and wouldn't let me access the site.
Wierd, I've been to satelliteguys before - but it didn't like this visit.
_________________ -Nothing relevant to add.
| Posted: Fri Jan 16, 2009 3:08 am Post subject: |
SC |
Plugged mine into power and 6 hours later I checked and all is working now ? Before that when I plugged it in it appeared
there was no power at all. Not really sure how long it took to come back to life though ....
| Posted: Fri Jan 16, 2009 3:28 am Post subject: |
Plugged my dead one into power and got a relay going click click click....It was annoying so I unplugged it. I'll try again later.
| Posted: Sun Feb 08, 2009 8:19 am Post subject: |
Never did get that one going but I've determined it's a power supply fault.
The Direct TV card arrived. It worked like a charm. Allowed me to set it for no dish.
Samsung did a great job of designing these boxes. You can turn ATSC, NTSC, NTSC cable and I'll guess Satelite all without haveing to manually switch inputs! All you have to do is sit there and mindlessly flick the channels! It's great!
Now why didn't someone else come up with this idea and impliment it in say a TV set!?
Only issue so far though. The ATSC tuner isn't very sensitive. I'm doing a comparison to the PHD205 since they both offer 1080i over RGB output.
More to follow.
