Some Barco setup questions.......
Posted: Sun Dec 28, 2008 6:50 am    Post subject:
I have the chip I replaced. Not sure of the firmware but will take a look. Should work OK with an Iris 2 If I can find it ...
zGman
Posted: Sun Dec 28, 2008 7:01 am    Post subject:
OK Tom, that would be perfect - your 'old' chip should be able to tell us if
this idea will work out - and if so, then we can work on finding the latest
version...
Cool - that will be fun. Thanks!
Now I really really am going to get some sleeeep....
G
Posted: Sun Dec 28, 2008 7:14 am    Post subject:
OK I'm Next !
Mad Mr H
Posted: Mon Dec 29, 2008 2:06 pm    Post subject:
PM sent to Galen..........
Thanks for the nudge Tom.
Laughing
jkruger
Posted: Mon Dec 29, 2008 2:22 pm    Post subject:
My Runco 1100 has V7.13 and I would be interested in a newer version if you guys get this figured out. I'd hate to miss out on what might be the last chance to do this.
NewbieDAN
Posted: Tue Dec 30, 2008 5:38 am    Post subject:
Back to Barco picture tuning setup questions Wink
What should my Clamp, Sync & peaking be set to for 1080p
what about Orbiting controls
Gamma? is it worth mucking about with the blue, slope break point?
Cheers
Dan
Posted: Tue Dec 30, 2008 5:41 am    Post subject:
Laughing
Thanks ! Thumbs Up Thumbs Up Sorry Dan for the interuption... Wink
Ile
Posted: Tue Dec 30, 2008 6:21 am    Post subject:
Cheers
Dan
Clamp normal
Sync slow
Peaking off
Orbiting off with video
On with static objects like in games, if no games it should be easy to remove R9827781 orbiting kit from vertical board.
Gamma adjustments are good with colorimeter, but without it leave those alone.
huggy
Posted: Tue Dec 30, 2008 6:44 am    Post subject:
Well I've redone the setup and have a couple of questions
1)I've adjusted sheimpflug and mechanical focus,I cant get the corners well focused,I only notice it with text.Ive tried the 3*5 card trick and it seems all 4 corners are in the focal plane at equal distances from the screen so I'm assuming sheimflug is correct however,I cant get it well focused with lense rotation.Is it a limitation of the lenses?HD 120's.
2)The left hand side is a huge pain in the ass in regards to convergence,the only way I ca fix it is to shift raster slightly to one side,the wear on the green suggests the previous install had the same issue, hence the wear is off centre.
Is it O.K not to have raster perfectly centred?
Ile
Posted: Tue Dec 30, 2008 9:04 am    Post subject:
1. What is your screen width? HD120 is made for 2-3 m wide picture.
2. Adjust picture with Hphase to right from raster center, this helps with left side convergence with high resolutions -> beam have more time to stabilize. Then adjust side blankings correctly and finally center picture to center of tube with raster centering.
huggy
Posted: Tue Dec 30, 2008 9:42 pm    Post subject:
Screen is 120" diagonal 16*9 which is 2.7 m wide,so well within spec.
zGman
Posted: Thu Jan 01, 2009 6:38 am    Post subject:
Hi Dave,
If you can input an external fine grid (displaymate or colorfacts test pattern)
and turn down the contrast a bit so you don't fry your eyes, and look in the lenses,
you should be able to see if the lines are all in focus on the tube face. If the focus
is the same all over the tube face, that is, if the center looks the same as the corners,
then the issue is optical - however, if there's a difference, as I might suspect,
it is time to work with the astig setup in the service menu. You can actually use
that same external grid pattern to work with the astig settings - you will see the lines
expand and contract in different directions with each control, and should be able to improve
the focus considerably.....( yes I know, everyone will jump in to say that it is all about dot shape,
but honestly, you can get quicker results sometimes just to use an external fine grid....)
Good Luck, and Happy New Year,
Galen
