VIM-FULLHD v3: Marquee HDMI 1.3 Input Card
Goto page Previous  1, 2, 3 ... 10, 11, 12, 13, 14  Next
dvh99
Posted: Thu Oct 21, 2010 2:32 pm    Post subject:
what is the bandwidth limit on the current moome hdmi v1.3 card cause 1920*1080 at 96hz might require a higher pixelclock then 250mhz.
moome
Posted: Thu Oct 21, 2010 4:40 pm    Post subject:
hi, HDMI spec for HDMI link is 225MHz, for analog bandwidth, it is 1.5GHz~~
dvh99
Posted: Thu Oct 21, 2010 6:30 pm    Post subject:
moome will you be providing a card with dual dvi-link for 3d purpose or perhaps a dual-hdmi link?
i would prefer this instead of the single hdmi link.
dual dvi goes to 2*165mhz.
moome
Posted: Wed Oct 27, 2010 8:43 am    Post subject:
we will consider this function for next VIM card~~~
dvh99
Posted: Wed Oct 27, 2010 3:06 pm    Post subject:
thanks, i was thinking of 1 hdmi and 1 dvi dl.
people that have more then 1 hdmi device use a switcher anyway.
JamesAB
TV/Projector: Marquee 8000
Posted: Sun Jan 16, 2011 6:53 am    Post subject:
What is the development cycle like for the moome cards? Will we be seeing a "version 4" card for Marquees within the next few months?
James
moome
Posted: Thu Jan 20, 2011 4:12 pm    Post subject:
James
Dear James:
we planned the V4 for VIM, but what function or upgrade you think can put on new V4?
we need some customer input.
antorsae
Posted: Sun Feb 06, 2011 7:57 pm    Post subject:
Hi Moome, how about a color management system (CMS)? At its simplest form, 10-bit LUTs for each color would do.
dturco
Posted: Sun Feb 06, 2011 8:03 pm    Post subject:
I have no idea whatt this is, but everyone is always going on about Lumagen's Color management System so It sounds worth while. Sorry Embarassed
http://www.hulu.com/firefly
Posted: Sun Feb 06, 2011 8:11 pm    Post subject:
Id go along with this if Andre made a PC based program to control it. Moome would have to find a way to ad a USB port
to the card. I know andre can write the program no problem.
Come on Guys, you have each others contact info lets get this idea going!!!
So how about that blend project I tried to get you two to work on?
MoomeZilla!!!!!
That sounds Cool !!!
I'll add the edge blend Circuit you should try to implement from the moome card. I am not sure if the
connector pins from where the moome card goes ties into the EDGE blend switching circuit.
 Filesize:  22.86 KB
 Viewed:  18465 Time(s)
J Kildare
Posted: Sun Feb 06, 2011 8:38 pm    Post subject:
1) I think CMS would be huge!!
2) Porch settings would be nice if possible
3) 72 hz if possible also
Not sure which most would want more. I would prefer CMS just because I have a vp-50 and basically have 2 and 3 covered, but for those without VPs 2 may be a bigger priority.
Jim
mistagreg
Posted: Thu Feb 10, 2011 10:38 pm    Post subject:
I know you can't say for sure, but what would be a rough time frame? 6 months, 1 year, more?
-Greg
DB Cooper
Posted: Thu Mar 31, 2011 8:06 pm    Post subject:
I would also like to see it do 72hz.
Posted: Sun Sep 04, 2011 1:37 pm    Post subject:
Moome is now offering volume discounts on his products including his Electrohome Marquee HDMI card:
5% off 5 cards, 10% off 10 cards, and 15% off 20+ cards
Get together with friends to order a group buy and save! Contact me at kal@curtpalme.com if interested and I'll point you to a special order page with discounts applied.
nidi
Posted: Wed Sep 21, 2011 2:03 pm    Post subject: discount for new 1.4 HDMI Cards?
Kal,
are the discounts for the remaining stock of 1.3 cards or for the new ones coming out in October?
Michael
Posted: Wed Nov 16, 2011 2:08 am    Post subject:
Moome's having a limited time sale on his HDMI cards for Electrohome Marquee projectors & clones (Madrigal, Vidikron, etc).
This card is a must-have for enjoying Blu-ray 1080p Full HD on your CRT projector!
Features two HDMI inputs, IR remote control, adjustable gamma boost for perfect black details, and more. Installation takes 5 minutes (plug and play).
Sale ends January 15, 2012.
For complete details visit the Marquee VIM-FULLHD order page: http://www.curtpalme.com/VIM-FULLHD.shtm
Posted: Thu Jan 12, 2012 5:54 pm    Post subject:
Heads up! The HDMI card sale ends January 15, 2012. Price goes back up after that!
HighDefMike
Posted: Fri Jan 20, 2012 1:20 am    Post subject:
Kal, are there still any of these left? It's not that big of a deal 'bout the price going back up...since the price didn't double or triple! THAT would be a deal ender.
Also, please tell me there's no auto HDMI input detect on this card.
I've read the post about the individual having handshake difficulties with the V2, and I've had (& still have) those issues with my v2 extfullHD (in addition to it not handling any refresh rate above 60Hz), but mine @ least DOES eventually link...(it's my 2nd, Moome replaced my 1st almost a year ago..great guy). But my v2 takes a while for the handshake....whereas my v1 extfull HD converter, and even the older VIM HD card are almost instantaneous. I have a Pioneer VSX 1018Ah AVR. My v2 is still under warranty, but I thought I'd try something different.
My current plan is to get a V3 VIM HD card for my 8500, and remove the VIM HD (which never got used...I like having a Plan B Smile ). I'll keep my RGBHV input card, since I have ONE source (MyHD PC HD OTA Tuner card) that outputs RGB. If the DVI daughter card were still available for that, I could go TOTALLY digital into the Marquee via HDMI.
The way I see it, with the V3 VIM HD, I'll continue to get all the image improvements the v2 extfull HD brought into the mix, PLUS bypass the quirk that limits my refresh to 60Hz on the v2...and possibly eliminate the slow linking issue. And I'll also have the v2 extfull HD (& VIM HD) as backups in case I have any issues with the v3 down the road....and need my HD fix Thumbs Up
I can wait until Moome returns to order (I read he may be out for a week or so)..assuming some v3s for the M8500 are still available; there's no rush.
Just let me know.
Posted: Fri Jan 20, 2012 1:45 am    Post subject:
Hi Mike,
Moome's 2 month sale ended 4 days ago. Moome sets the prices so if you like, you can email him and ask (moome@curtpalme.com). I can't change the prices for him.
I don't think the card auto-detects which input is active. You have to manually switch with the 1 and 2 keys on the remote.
They ship directly from him so he keeps tabs on the stock. If he's sold out he lets us know and I post that there may be a delay with the orders.
HighDefMike
Posted: Fri Jan 20, 2012 2:08 am    Post subject:
Roger.
I'll email him and see if he still has some left.
Thanks!
Page 11 of 14
