Worlds most powerfull subwoofer
Posted: Mon Nov 17, 2008 12:45 am    Post subject: Worlds most powerfull subwoofer
http://www.ohgizmo.com/2005/10/31/worlds-most-powerful-subwoofer/
 Filesize:  229.74 KB
 Viewed:  15076 Time(s)
greg_mitch
Posted: Mon Nov 17, 2008 1:05 am    Post subject:
They would be interesting to see and hear in real life.
Many threads over at AVS on them. I believe it is spanky ham that has first hand experience with it?
Very specialized room design though.
Posted: Mon Nov 17, 2008 1:14 am    Post subject:
Looks like a 1940's fan to me.
 Filesize:  487.85 KB
 Viewed:  15060 Time(s)
greg_mitch
Posted: Mon Nov 17, 2008 4:35 am    Post subject:
True. Come up with a bigger motor and figure out how to coordinate the variable fan blade pitch with low frequencies and you could start selling those!
lostmandan
Posted: Mon Nov 17, 2008 5:21 am    Post subject:
Hmmm.. $12,000?
If only I could find someone who was actually selling one of the Clark Synthesis Tactile transducers at a price I could afford. Heck used would be fine even. Unforunately the TST329 looks to be $315 everywhere and that is a bit more than I can justify.
I've never heard one in action but I have read that bolting one to the bottom side of a deck can avoid the need for outdoor speakers - it can reproduce the audio spectrum fairly well.
nomadII
Posted: Tue Dec 09, 2008 2:51 pm    Post subject:
Apparently a whale can hear that Eminent Technologies sub from 3 miles!
Now that is not neighbor or structure friendly!!
Posted: Tue Dec 09, 2008 2:54 pm    Post subject:
Good point.
What if it hit's the resonant frequency of the building?
Or worse yet.
What if it hit's........the brown note? Shocked
jask
Posted: Fri Jan 16, 2009 5:59 am    Post subject:
6 miles if you play Barry White.
Posted: Fri Jan 16, 2009 6:09 am    Post subject:
I dunno, I'm still skeptical, and followed all of the avs posts in the high end forum a year or two ago.
Posted: Fri Jan 16, 2009 6:21 am    Post subject:
Interesting concept though...
http://www.eminent-tech.com/RWbrochure.htm
Domminigan
Posted: Sun Jan 25, 2009 6:26 am    Post subject:
So what, this thing starts moving air and then the blades of the fan move in and out like a sub cone, or does it control the speed of the fan blades?
I need to paint one green and park them together.
jask
Posted: Sun Jan 25, 2009 9:29 am    Post subject:
the blades pitch or angle of attack can be controlled (tilted) while at speed and this sets up the frequency- as the frequency gets lower the angle of the blades "lays back" more, moves more air and changes the frequency. If you have ever been around big prop planes when they are taking off you have experienced a similar effect.
Posted: Sun Jan 25, 2009 3:42 pm    Post subject:
It might be what you meant, Jask, but I wasn't clear... So here's my version:
The motor is driven at a constant speed. The blades' angle of attack is modulated just like a normal subwoofer cone is. Amplitude is controlled by the angle of attack (steeper angle, more air movement, more amplitude, louder), while the frequency is simply the frequency of the oscillation of the blades' movement. The power is in the spinning motor-driven fan. That makes it efficient from an amplifier perspective because all the amplifier is doing is rotating the fan blades themselves... It's the motor itself that's the "power" behind the process.
Here's their page on it:
http://www.rotarywoofer.com/howitworks.htm
Very cool piece of technology, and I'd LOVE to hear (feel?) one. It would be kick-ass for two or three grand, but $12,000 makes it a non-starter for 90% of people into home theater. Of course, 90% of auto enthusiasts can't afford a Ferrari, either.
DrKnow65
TV/Projector: Vidikron Vision One
Posted: Sun Jan 25, 2009 4:18 pm    Post subject:
I believe you are correct ecrabb, fan blades only push/pull air with the +/- sine wave just like a diaphragm while the rotation is constant...
Clever for low frequency, suppose at to high of a frequency you would start to get velocity noise of the edges of the blade though?
We used to use servo drive 36" woofers for live PA work that were impressive and cost around $3000~ but you had to use a $10000 amp/processor to push them and the transient was a little lacking. I think Pink Floyd ran them too in the later years.
jask
Posted: Sun Jan 25, 2009 9:15 pm    Post subject:
SC/ DK65 that is what I was trying to say,... you just said it more clearly! - the pitch oscillates at the frequency desired to create the increasing/decreasing pressure that becomes the sound wave. I know a fellow that had a chance to play with one of these and he said the "impulse" he felt standing in front of it was physically painful!! He was in to competition car audio and said this was unlike anything he had ever experienced in or out of a car.
SC that link is great, do you think the fan blades in the animation are meant to be spinning counterclockwise?
DrKnow65
Posted: Sun Jan 25, 2009 9:30 pm    Post subject:
Being a pressure wave (sound) it would require a baffle. Just standing in front would not be the full effect.
Posted: Sun Jan 25, 2009 9:37 pm    Post subject:
Cool link.
Posted: Sun Jan 25, 2009 10:14 pm    Post subject:
Yeah, the animated gif looks backwards to me, too... It's probably just the capture rate that makes it look backwards... Same effect as the wagon wheels going backwards in western films.
jask
Posted: Sun Jan 25, 2009 10:30 pm    Post subject:
The unit I was talking about was tube mounted, it was also on a manufacturers table- not actually mounted in the car. the ET units are mounted in an IB configuration.
Here is a Youtube link with info on the drive motor/pitch control:
http://ca.youtube.com/watch?v=3j4HfdImTZo
50W of Amp power= approx 210Db !!!! sweet!!!
Posted: Sun Jan 25, 2009 11:24 pm    Post subject:
http://www.youtube.com/watch?v=E7Bkrypxzs4&feature=related
