NEC XG-751G Not working
Posted: Sat Nov 22, 2008 7:52 pm    Post subject:
Nope, all boards MUST be installed and working for the XG to work and lock to a signal.
I can also test all your card cage boards here, I have working XGs here for test purposes.
pgb265
Posted: Sat Nov 22, 2008 8:23 pm    Post subject:
So does the fact that I DO get a a picture when using the S video input mean the oscillator board is OK?
Posted: Sat Nov 22, 2008 8:29 pm    Post subject:
Nope, it seems that these boards all work harder as you go up in signal resolution, so it could be the system or osc board. I think it can even be the wave board.
pgb265
Posted: Sat Nov 22, 2008 8:44 pm    Post subject:
Do you know any techs in Sydney Australia worth getting in?
Posted: Sat Nov 22, 2008 9:21 pm    Post subject:
Edit: Oops, responded to the forum e-mail, missed a few posts.
No, the Moome card will not help.
I would leave the Moome card well alone until you get it working. They can be a total PITA to get working with a properly functioning projector.
And no, I don't know any techs in Sydney. Sorry. Without the correct spare parts, a tech can't help anyway.
Posted: Sat Nov 22, 2008 9:29 pm    Post subject:
If Mark doesn't have the boards, then send your 3 boards to me. Should be $35 or so to send them airmail.
Posted: Sat Nov 22, 2008 10:02 pm    Post subject:
All I can offer is a diagnosis - by swapping boards till it works.
Perhaps it would be more sensible to send it to Curt for diagnosis and repair/replacement.
pgb265
Posted: Sun Nov 23, 2008 8:31 pm    Post subject:
It sounds like air mailing the boards is the way forward.
How tricky is the extraction procedure for the "3 boards"?
I tried to find some pictures so I know what to look for.
Are there any on the website I missed?
Is it totally obvious to someone who has never seen the inside of one these before?
Posted: Sun Nov 23, 2008 8:36 pm    Post subject:
About as hard as changing a video card in a PC.
Under the perforated metal cover in the bottom of this pic:
http://www.curtpalme.com/NECXG_Layout1.shtm
pgb265
Posted: Sat Feb 07, 2009 1:16 am    Post subject:
Hi Guys,
I am finally back onto the job of fixing by crt.
This is probably a real dum question BUT...
Is it OK to remove the 3 boards while the unit is still mounted to the ceiling??
I would prefer not to pull it down if it is not needed?
Paul
Posted: Sat Feb 07, 2009 1:23 am    Post subject:
It's dead easy Paul.
Just take the covers off, and you will see how to do it.
Covers, then big metal card cage lid at the back.
The little white levers at the end of each PCB are for removal.
It will take 5 minutes.
pgb265
Posted: Sun Feb 08, 2009 5:53 am    Post subject:
Hi Mark,
I have the lid off, ready to extract, just collecting a few anti-static bags and checking with Curt exactly how many and wich boards to send.
Many thanks for your help
Paul.
P.S how did the your projector work with 110kHz oscillator card? Would you recommend I try this upgrade while fixing my existing problem.
Posted: Sun Feb 08, 2009 6:22 am    Post subject:
Err..it worked up to 110khz.
Which is completely pointless. 75khz is plenty. I just did it out of curiosity as I had the board on hand.
