| Posted: Tue Nov 11, 2008 11:04 pm Post subject: Just got an NEC 9PG+ |
Paid $900 Australian dollars for it, which seemed like abit of a bargain to me.
Looking forward to getting it here and seeing what its like, all i have read about them seems pretty promising.
I wont have it installed until my new house is built, at which time im not looking forward to the lifting part, cause at 50kgs +, it sounds like quite a bloody heavy barstard!!
What sort of things should i do to this rig when it turns up so i can avoid premature failure??
kschmit2
| Posted: Wed Nov 12, 2008 10:22 am Post subject: |
check to make sure the tubes still have an air bubble.
see instructions here: http://www.curtpalme.com/Bleeding_CRT_Tubes1.shtm
If there is no bubble, you should bleed the tubes. Unfortunately you may have to do that again before you install it in your new house.
jask
| Posted: Thu Nov 13, 2008 5:40 am Post subject: |
Congratulations, as Kai said check those tubes. I would power it up and ensure that it is working properly....at that point it really is a lot of fun just "trying " to converge it....next thing you know it is 3 in the morning and you are posting on the forum.....and watching out for your "next" projector.
That is a great projector!
| Posted: Thu Nov 13, 2008 5:41 am Post subject: |
What more than one projector? But why?
| Posted: Thu Nov 13, 2008 6:14 am Post subject: |
Thanks people, ill be looking into all that info when i can
| AnalogRocks wrote: | What more than one projector? But why?  |
I will have 4 now, in short, cause i can.
The NEC will be in the cinema room (where the TW2000 was going to go, but it got knocked on the head for a real projector), the Sony will be in the lounge room downstairs, and an Epson each for the 2 smaller bedrooms.
Mr. Green
| Posted: Thu Nov 13, 2008 6:51 am Post subject: Re: Just got an NEC 9PG+ |
| CasetheCorvetteman wrote: | Paid $900 Australian dollars for it, which seemed like abit of a bargain to me.
What sort of things should i do to this rig when it turns up so i can avoid premature failure?? |
Another 9PG+ owner, SWEET! Congrat's It's a great little machine. Take time to set it up right... and at your first opportunity add a PS3, the HDFury and box 1040!
You are hilarious. The 9PG+ is one of the SMALL CRT's at 123 pounds. I think it's the lightest of the "intermediate" group. I found a great way to lift the projector. Did it all myself... http://www.curtpalme.com/forum/album_page.php?pic_id=673&mode=next DON'T try this at home!
If you want a bit of a preview, check out my album... http://www.curtpalme.com/forum/album_page.php?pic_id=669 I think those were all standard def in broad daylight. I'll post better pictures later...
I just looked again, I really need to add more photos. Since I got the box 1040 my viewing experience has improved greatly.
LostManDan is working on a system board list. Please add your input to his post... https://www.curtpalme.com/forum_archived/viewtopic.php@t=12329.html
We will also be curious if yours can to 1080p. Most 9pg+'s don't seem to be able to sync to it and it runs the projector hard so it's not recommended. We are more curious than anything. You can see the results in LostManDan's post.
Luckily there are a lot of us that have them lately. We're all glad to help. While you're waiting for your house you can change out all the capacitors...
| Posted: Fri Nov 14, 2008 6:56 am Post subject: |
Gday Mr Green, how are ya mate?
The advert for it says it will do 1080p but looks abit softened, and is up the the individual whether they prefer 1080i, 720p, or 1080p.
Ill put a bluray player in the computer and use a program before id use the PS3 for that, but i will be looking into the HD Fury for sure. The Harman Kardon AVR i have upscales everything if you want it to, seems to work quite well.
Change out the capacitors? Bugger me that sounds like alot of work mate, is it worth the effort?
Thanks for your replies
lostmandan
Joined: 09 Jul 2008 Posts: 146 Location: Kitchener/Waterloo, Ontario, Canada
| Posted: Fri Nov 14, 2008 1:35 pm Post subject: |
Welcome!
Ahh, it is always worth the effort. I recall thinking that the more work that goes into a setup, the higher the satisfaction. YMMV, of course.
Mr. Green is referring to the issue that a few of us have had where 1080p/60 signals are scrambled (not to be confused with another fault called the 'dreaded scrambled mess').
I am seeing the scrambled but sync'd issues with my unit, and I believe Mr. Green is seeing it with his. Not exactly sure of the cause yet, but sometimes this can be caused by capacitors on the deflection board. This was not the case for me, unfortunately.
I would suggest seeing what your starting point is before even considering replacing capacitors. "Don't break what ain't broken", so to speak.
I would suggest carefully inspecting boards - I found leaky capacitors on my WAVE PWB which I replaced.
Keep Curt in mind for board repair - he is "your man" for all repair.
In North America it is advisable to ensure that the electrical circuit being used does not develop a voltage between the ground and neutral conductors. It is advised to run a separate circuit from the load center/breaker panel for the PJ on 120V service. I see you are in Oz, so you will have 220V service? If so, I believe this is less of an issue.
As Mr. Green mentioned, I started a thread a while back to research which system boards/deflection boards, etc are in NEC PG projectors. There are black ink stamps (for example '1X0-154AJ') on the boards. The quest was started so I could get an idea of what combinations work for 1080p (not scrambled) and which ones exhibit the issue.
Let us know how things go for you and post back
Cheers,
Dan
| Posted: Fri Nov 14, 2008 11:57 pm Post subject: |
No worries Dan, thanks for your reply mate
We are on 240v here, i havent got my meter at home (left it at work, only got an automotive one here, doesnt do A/C) so im not sure the exact voltage, however where i work (i do maintenance there) the voltage is between 228v and about 237v, depending on where it is measured in the building and how far away from the distribution board it is. 3 phase power is around the same for each phase when measured phase-to-neutral, when measured phase to phase is anywhere from 410v to 415v (i got 410 the other day when i checked one.)
I dont mind the effort involved in the set up of the unit, that is certainly worth the effort, but i dont know about replacing perfectly good components though!!
lostmandan
| Posted: Sat Nov 15, 2008 12:41 am Post subject: |
Understood. I definitely do not suggest replacing perfectly good components either.
When do you get your PJ? I remember the excitement when I was waiting for mine
Dan
Mr. Green
| Posted: Sat Nov 15, 2008 1:01 am Post subject: |
Hey guys,
Yeah, sorry. I was a bit tired when I rambled through that. I didn't mean you have to replace all the capacitors, just that you might notice some are leaking and need replacing. I'm too scared to look myself at the moment. It's running beautifully on 1080i right now and I want to enjoy it for a bit before fiddling with it.
Next Thursday, my poor old 9PG+ is going up a brand new Epson 1080p LCD projector . A friend just took delivery of it yesterday so we'll see how it goes. We are going to shoot at the same screen with the same source. I'll just picture mute when we are looking at his.
Spec's here... http://www.projectorcentral.com/Epson-PowerLite_Pro_Cinema_1080_UB.htm
I'm pretty sure it's gonna smoke mine since I'm not done getting mine up to the level I want (I need to work on the sharpness a bit and colours are a bit off). For the 2 hour showdown I'll run the tubes a bit harder if I need to. I'm really hoping mine does well against it.
| Posted: Sat Nov 15, 2008 1:30 am Post subject: |
Look at the specs:
Street Price (USD) : $2,999
MSRP (USD) : **
Brightness (Lumens) : 1600 ANSI
Contrast (Full On/Off) : 50000:1
Variable Iris: Yes
High Brightness:
ANSI Lumens: **
Contrast Ratio: 4000:1
High Contrast:
ANSI Lumens: **
Contrast Ratio: 50000:1
Audible Noise: **
Eco-Mode: 24.0 dB
Weight: 5.4 kg
Size (cm) (HxWxD) : 12.2 x 31.0 x 39.6
Std. Lens: Focus:
Manual
Zoom: Manual, 2.10:1
Throw Dist (m) : 2.5 - 4.5
Image Size (cm) : 101.6 - 381.0
Optional Lenses: Yes
Digital Zoom: **
Digital Keystone: No
Lens Shift: Horz & Vert
Networking: Wired:
No
Wireless: No
Warranty: 3 Years
Performance:
H-Sync Range: **
V-Sync Range: **
Compatibility:
HDTV: 720p, 1080i, 1080p/60
1080p/24
EDTV/480p: Yes
SDTV/480i: Yes
Component Video: Yes
Video: Yes
Digital Input: HDMI (HDCP)
Computers: Yes
Display: Type:
1.9 cm 3LCD
Native: 1920x1080 Pixels
Maximum: 1920x1080 Pixels
Aspect Ratio: 16:9 (HD)
Lamp: Type:
170W E-TORL
Life: **
Eco-Mode Life: 3000 hours
Quantity: 1
Speakers: No
Max Power: **
Voltage: 100V - 240V
FCC Class: B
Special: RS232 Port
Status: Shipping
First Ship: Dec 2007
** this item is either not applicable, unpublished, or unknown
Those are called a TW2000 over there in Australia. Its only got a 4,000:1 contrast ratio, so i dont know why they give a number of 50,000:1 as well, which one do you believe? It will also be interpolated on any res that isnt 1080i or 1080p, so it wont look its best when on 720p, so if you use 720p as a base, yours should easily look nicer assuming his is going on the same screen (im not sure how his will go on your screen though, its got about double the lumens, may be too bright for a 2.4 gain...)
Mr. Green
| Posted: Sat Nov 15, 2008 1:36 am Post subject: |
He'll use the cinema mode to get it as dark as possible. The 50,000-1 one is acheived through a dynamic iris or something. It will have to be 1080i. That's what I have setup.
| Posted: Sun Nov 16, 2008 2:19 am Post subject: |
What frequency are you running on 1080i? If its 72Hz or more you probably dont notice any flicker, where as LCD are pretty near all 60Hz, and i know both mine flicker abit when 1080i goes in.
If the rig youve got will almost do 1080p, you should be able to do a respectable scan rate on 1080i, cause its only displaying half the lines. Ill have to wait til i get mine and see what i see
| Posted: Sun Nov 16, 2008 6:42 am Post subject: |
Bleed the tubes.
Add a fan or two the deflection board heatsink - old Athlon CPU fans are thin enough.
Add a heatsink and fans to the baseplate opposite the C and F drives.
And Mr Green, the time has come. A decent new digital will smoke a PG.
| Posted: Sun Nov 16, 2008 7:13 am Post subject: |
Thanks for your advice mate, between me and a mate up here, we now have 2 of them, as he just bought one today as well for about $723 with a motorized screen.
| Mark_A_W wrote: | | And Mr Green, the time has come. A decent new digital will smoke a PG. |
Not for $700-$900 AUD it wont. Not even close. And digital is only good for about 1/4 of the life span.
| Posted: Sun Nov 16, 2008 7:29 am Post subject: |
| CasetheCorvetteman wrote: | Thanks for your advice mate, between me and a mate up here, we now have 2 of them, as he just bought one today as well for about $723 with a motorized screen.
Not for $700-$900 AUD it wont. Not even close. And digital is only good for about 1/4 of the life span. |
My CRT projector I watch like a regular TV set. My friend has a d!gital, he tried that and got about 9 months out of it. I put over 2000hours on the Sony 1251 in 6 months and it has 12 000 hours on the tubes when I got it. It still runs nice. His DLP, well it's inverted ( negative picture ) and black n white. He paid $900 on ebay 2 years ago, I paid $600 at a pawn shop for my Sony 2 years ago and it still works. It's traveled down and up basement steps ( thump,thump,thump) and I tossed it in the back of my truck 2 years ago and took it on a 6400km driving vacation. Those Sony CRT's are tough
I think I got the better deal.
Plus the CRT projector gives off a nice warm breeze from the fans that'll keep me toasty warm. A digital would be like walking out of an air conditioned room into the desert. Too hot, too much....soon broken.
Mmmmm analog.
| Posted: Sun Nov 16, 2008 7:48 am Post subject: |
Yeah mate, ive been there with digital for a few years, as i said though, never had one fail and never blown a bulb, but they do lose brightness and contrast gradually over the first 12 months.
I always liked the CRT smoothness, which no matter what digital you go and what the native is, it still is over sharp and has jaggies you cant get rid of without putting it slightly out of focus. DLP is just as bad as LCD for the jaggies, and the screen door is shut on both of them if youre close enough.
For the money these days, you cant buy a digital that beats an analog CRT projector in any respect apart from overall lumens, and i dont watch movies with all the lights on!!
| Posted: Sun Nov 16, 2008 8:39 pm Post subject: |
| AnalogRocks wrote: | | CasetheCorvetteman wrote: | Thanks for your advice mate, between me and a mate up here, we now have 2 of them, as he just bought one today as well for about $723 with a motorized screen.
Mmmmm analog. |
I usually don't make value judgements about people, but give me a break. You watch your pj around 11 hours a day!!!!! Why?
| CasetheCorvetteman wrote: | Yeah mate, ive been there with digital for a few years, as i said though, never had one fail and never blown a bulb, but they do lose brightness and contrast gradually over the first 12 months.
For the money these days, you cant buy a digital that beats an analog CRT projector in any respect apart from overall lumens, and i dont watch movies with all the lights on!! |
That is great that you like the CRT, but I am not sure a PG is worth $900 even in Australia. As long as you are happy with it, that is all that matters. The reason I point this out is Dave just bought a digital that he likes better than his 8" LC for $1k. I love CRT as much as most (even more than the guys that were just here to pick up a buck:)), but I would never pay a huge premium for a CRT. As the on board vps get better and the native on/off gets over 20k to 1, the decision to go CRT will be based on something other than pq parameters. Lets not get off on a digital argument as you should be sitting back and exploring and enjoying your new pj.
| Posted: Sun Nov 16, 2008 9:14 pm Post subject: |
| Spanky Ham wrote: | | AnalogRocks wrote: | | CasetheCorvetteman wrote: | Thanks for your advice mate, between me and a mate up here, we now have 2 of them, as he just bought one today as well for about $723 with a motorized screen.
Mmmmm analog. |
Hey Spanky,
That was 2 years ago. I was a kid with a new toy! I would watch a few hours before work and many hours after work and all weekend. It was fun! I re-watched most of my favorite and not so favorite movies in my collection. I watched untill I passed out from exhaustion some nights.
Too bad I don't have that kind of time anymore.
I spend more time configuring this 'dat and the other thing than I do watching movies or TV. It's still fun though.
Gotta go I started a movie about 20 minutes ago, came into my office to grab something and the forum grabbed me and wouldn't let go
