Setting Up a Constant Image Height System
Goto page Previous  1, 2, 3
Person99
Posted: Mon Nov 10, 2008 8:47 pm    Post subject:
Deleted due to the fact that this post runs counter to the site position that "CRTs are always great and digitals always suck."
Person99
Posted: Mon Nov 10, 2008 9:22 pm    Post subject:
VideoGrabber
Posted: Tue Nov 11, 2008 8:00 am    Post subject:
Thanks for all the answers, Dave.
I was a bit concerned there was only a non-reproducable path to where you're at, and you addressed that well. And, no, I have no problems with used. I'm sure, as time goes on, there will be even more "acceptable" options, and opportunities.
With the proper guidelines, folks will know what to look for, thanks to you. And the big revelation that it's possible at all to get a CIH scope image a former CRT-owner is happy with, at an affordable price... which I think is the main point you wanted to share.
- Tim
Person99
Posted: Fri Nov 14, 2008 10:56 pm    Post subject:
Last part up. Have fun guys.
CRT_Ben
Posted: Sat Nov 15, 2008 5:44 am    Post subject:
Thanks for completing this, Dave. I was one of those on the sidelines, watching and learning. We appreciate the education!
VideoGrabber
Posted: Sat Nov 15, 2008 11:17 am    Post subject:
Thanks for completing the odyssey, Dave. Well worth the trip.
A couple concerns...
> bulbs lose brightness as you use them <
I seem to recall reading something like half brightness at ~500 hours(?) on some/most bulbs (help me out here)? If it's anywhere near that ballpark, it doesn't seem like it would be long before your CIH display was just over 6 ftL, and even with the high boost would be only ~7.8 ftL. Isn't that going to be a problem for the guy who said how great 16 was, and he could never go back to 12?
> As a point of comparison here are typical CRT projector output in 4:3 mode:
8” machines do about 180-210 ANSI Lumens
Aren't you falling into the common trap here of using ANSI lumens with a CRT? I.e., digitals have an essentially constant output, but CRTs are highly dependent on the %age of the screen that's illuminated (because their output is mostly limited by beam current). So at 10% coverage, CRTs are ridiculously high output (e.g., 1200 non-ANSI lumens), while at 10% digitals are exactly the same as they are at 100%. And while 10% isn't really a good metric to use (selected by manufs to make their numbers look good), in reality, most film content runs around 20-30%, and TV-ish content ~30-40%. This means that the _effective_ light output from a CRT will be much higher than the 100% ANSI reading would indicate. If we had lumens at 30% output, that would be a lot more reasonable method of evaluation.
> Let’s say you are using an 8” on that screen (8 foot wide, 16:9 format), you are looking at: (180/36)*1.3=6.5 ftL <
And yet Kal has measured his output at ~12 ftL (see his award-winning Calibration series), with a gain closer to 1.2. Your implication (seems to be) that he's off by a factor of 2. Then to get the "desired" 12 ftL, he'd need to go TWICE as bright as he currently does. While it's possible he may feel a bit more brightness wouldn't hurt, I seriously doubt that he'd want anywhere near twice his current brightness levels.
Thus the fallacy of using ANSI lumens to evaluate CRT PJs.
> CRTs have great on/off especially with gamma mods but horrid ANSI (LC typically about 130:1 AC about 80:1). <
Is it really THAT bad? That sounds pathetic. I'll have to win a meter and test that one for myself. Wink That doesn't sound right. In fact, even the ratio sounds far off. It's fairly well accepted that LC over AC buys you ~30% better CR (USPL papers). Which would either put AC at 100:1, or LC at ~104:1. That's just picking nits, but I find it difficult to believe it's that poor (not that it's less than digitals).
Thanks again for a well-done series.
- Tim
Person99
Posted: Mon Nov 17, 2008 4:27 pm    Post subject:
Person99
Posted: Mon Dec 15, 2008 4:49 pm    Post subject:
Posted: Mon Dec 15, 2008 5:40 pm    Post subject:
Umm, Ummm Ummm? Did I miss something? Shocked Shocked Confused
Posted: Mon Dec 15, 2008 5:42 pm    Post subject:
The Dave giveth...and the Dave taketh away....... Wink
Person99
Posted: Mon Dec 15, 2008 6:13 pm    Post subject:
No one really cared about the thread because we all know digitals completely suck--right?
Since it has been made clear that this is first and foremost "Curt's forum" (see the discussion in the for sale section) and that Curt does not like pro-digital info here, I am respecting his wishes and will not correct any misinformation about digital projectors nor will I suggest that anyone might enjoy one.
Posted: Mon Dec 15, 2008 6:14 pm    Post subject:
Well one more good thing has come of this thread. THe above comment is hysterical! Thumbs Up
VideoGrabber
Posted: Mon Dec 15, 2008 10:38 pm    Post subject:
> No one really cared about the thread ... <
Disappointed to hear that I am no one. Sad
- Tim
Posted: Mon Dec 15, 2008 10:40 pm    Post subject:
I'm sorry you are??.......
Posted: Mon Dec 15, 2008 11:42 pm    Post subject:
Thumbs Up
CRT_Ben
Posted: Tue Dec 16, 2008 12:06 am    Post subject:
Well, that sucks. You guys can clap and say good riddance but *when* I switch from my 9500LC at some point, I'll at least have some fundamentals laid out by someone who's opinion I trust. Hell, I almost switched now as I'm moving into my new home, because with 1,000 different home improvement projects waiting for me I really didn't relish the thought of how long it would take to mount and setup the PJ, and be waiting during that time with only a 27" SDTV.
Page 3 of 3
