| Posted: Thu Oct 16, 2008 12:35 am Post subject: |
| angryht wrote: | | AnalogRocks wrote: | Have you considered a CRT projector?  | Seriously, I would consider anything that would get me better picture quality. I always thought a CRT would be too big for my room. It's only about 10 FT wide and 13 FT long. It's pretty tight quarters. Any suggestions for a room that small. And aren't they kind of loud (fan)?
| AnalogRocks wrote: | Again, I'm betting the Box1020 may help you here. You'd be going from RGBHV to componenet into your projector. By passing the VGA scaling and you'd have the IAC control if the picture was still shifted.
I personaly own the Box1020 and the HDFury1, as a stand alone the HDFury1 was a good product, but attached to the Box1020 it was much, much better. What a great combo. | So that would convert the RBG signal to a component. Would the Fury2 do both, too? |
Yes the HDFury2 does component as well but there's no adjustable centring in the HDFury2. Although you may not need it. The other advantage of the Box1020 is the gamma boost or BB ( black boost ) as it is called. It really brings out the shadows. However that may be lost on your projector due to the high black level.
A CRT projector is large, some are noisey but doesn't the 6200 have a fan anyways? What size is your screen? CRT projectors don't have zoom lenses. So once you get it in, get the rasters maximized and throw the picture on the wall that becomes your screen size.
angryht
| Posted: Thu Oct 16, 2008 1:28 am Post subject: |
I am still curious about the extron, and maybe garyfritz can help me understand. What additional cables would I need. I have an HDFury with a D15 cable out and my projector has D15 in. As I look at the pdf manual, it looks like the break out cable may be all I need.
| Posted: Thu Oct 16, 2008 3:26 am Post subject: |
Yup. The Extron cable has a male D15 and goes to the strange Extron 9-pin jack. It also splits off a short cable to a female D15, which is intended to be used for a monitor. I.e. you could have a monitor sitting next to your DVD player to show what's going out to the projector.
The Extron's outputs are 5 BNC female. You just need a 5BNC -> VGA breakout cable, something like this one for $6.20 from monoprice. That one is 5 BNC males to 1 VGA male. Make sure the BNC & VGA genders are right.
angryht
| Posted: Thu Oct 16, 2008 4:03 am Post subject: |
Thanks, Gary. Check your pm's and we can probably move forward. Let me know what you think.
angryht
| Posted: Mon Oct 20, 2008 6:43 pm Post subject: |
| AnalogRocks wrote: | | angryht wrote: | Yeah. Looks like I will need a few more cable for the Extron. I'm trying to find a 9-pin to a 15-pin vga. I haven't had any luck at monoprice. garyfritz: What is the cable that you have with the Extron?
Analog: There is also a sync on green adjustment in the service menu. That is one setting I haven't tried yet. Do you know if 'sync on green' (SOG) is only for YPbPr signals? |
Sync on green is used for VGA. You essentially use 3 wires instead of the 5 that you would used for RGBHV, SOG is RGB. Not to be confused with component. There's also composite sync RGsB, does your BenQ take that as well? That uses 4 of the 5 wires, The extron can combine sync's to produce this signal. Again not sure if it would help you or not.
Here's a little primer to help you out: http://www.curtpalme.com/CRTPrimer_17.shtm | I guess I'm confused again. My projector says it will take an RGB input. And it seems like the RGB input is the same VGA output as a computer. My PJ is a digital DLP. So, I'm guessing it is sync on green (also, because there is an adjustment for sync on green in the service menu). But the signal output from the Fury is RGBHV. So it looks like the projector is expecting an RGsB but the Fury is sending out a RGBHV. I'm I getting that correct? To me this seems still like a sync problem and I am hopeful (but realistic) that the extron may help me out.
| Posted: Mon Oct 20, 2008 7:24 pm Post subject: |
You'll find out soon. It's all packed up and I'll drop it off this afternoon.
| angryht wrote: | | AnalogRocks wrote: | Have you considered a CRT projector?  | Seriously, I would consider anything that would get me better picture quality. I always thought a CRT would be too big for my room. It's only about 10 FT wide and 13 FT long. It's pretty tight quarters. Any suggestions for a room that small. |
A marquee 8500 or 8110 with upgraded HD-145 lenses will give an 84" wide screen, (120" diagonal) at 9 feet to tip of lenses, 12 feet to back of machine. That's also a sweet spot for a bright punchy image. BTW, the machine measures 32" x 28" x 18" tall. You pretty much have to ceiling mount these things
| angryht wrote: | | And aren't they kind of loud (fan)? | it depends, some are very loud and others are Pretty quiet. My Maruquee is about equal to a benq 721, but at a lower frequency. It could also be quieter if I did the fan isolation mod to the power supply.
angryht
| Posted: Mon Oct 20, 2008 7:40 pm Post subject: |
| garyfritz wrote: | You'll find out soon. It's all packed up and I'll drop it off this afternoon.  | Hey, thanks Gary, I appreciate it. I'll let you know how it goes.
angryht
| Posted: Mon Oct 20, 2008 7:50 pm Post subject: |
| draganm wrote: | | angryht wrote: | | AnalogRocks wrote: | Have you considered a CRT projector?  | Seriously, I would consider anything that would get me better picture quality. I always thought a CRT would be too big for my room. It's only about 10 FT wide and 13 FT long. It's pretty tight quarters. Any suggestions for a room that small. |
| angryht wrote: | | And aren't they kind of loud (fan)? | it depends, some are very loud and others are Pretty quiet. My Maruquee is about equal to a benq 721, but at a lower frequency. It could also be quieter if I did the fan isolation mod to the power supply. | I will look into them. Thanks for the suggestions, draganm. This CRT stuff is kind of new to me.
