Who has a working 1080i 72 or 1080p@48 Nivida custome res
Posted: Sat Oct 18, 2008 12:01 am    Post subject:
Desktop gamma does not affect overlay.
The ATi CCC gamma (overlay I think) does not work in Powerdvd.
So rip you movies to MKV and use Haali Renderer in another player.
Elaine Benes
Posted: Sat Oct 18, 2008 12:47 am    Post subject:
Is there a one step GUI for ripping BD's to mkv ?
Or is it a fourteen step, command line labyrinth, only for computer engineers...
Elaine Benes
Posted: Sat Oct 18, 2008 12:51 am    Post subject:
yeme wrote:
Elaine,
Do you have a custom timing for 1080P/60 you could post for the nVidia? I have been able to get 1080i working through the Nvidia custom setup but am unable to get a 1080P working. (I can get 1080P/60 with my ATI setup)
No custom timing was needed, just chose 60Hz refresh for 1920x1080....30Hz is Nvidia's version of 1080i, afaik.
The one thing I did do was swap the default synch from, I think, ++ to +- so it would be recognized by my Marquee as a typical 1080i signal using the 30Hz refresh. I don't normally use the 1080p, there's no discernible difference to me with video, so I just use the signal that I've got tweaked the best, which is 1080i.
Posted: Sat Oct 18, 2008 2:26 am    Post subject:
No single step process I know of, if you discover one let me know. "Or is it a fourteen step, command line labyrinth, only for computer engineers..." sounds about right though, wait it may only be thirteen steps Wink
fishlogan
Posted: Tue Oct 21, 2008 3:21 am    Post subject:
worked out a way around nvidia setting their own porches, sync widths etc with the custom resolutions
i was having trouble getting the right active width with their standard settings and when i changed them on manual setting it would mess with the refresh rates (instead of 48hz it would be 51.6 or some garbage like that)
so what i did was to get 1080 x 1920 at the right widths etc (usualy for me reduced widths) i set the custom res to say 1080 x 1860 and hit the auto button. this gives you reduced sync,porches for the lower res (1860). then go to manual and change both the active pixel AND the custom res box back to 1920 and hit the test button.
this gave me the 1080 x 1920 res i wanted but with the right porch settings
i am running vista and have 9600gt. some say powerstrip now works with these cards but i have found it is way to flakey and generally doesnt work
Elaine Benes
Posted: Tue Oct 21, 2008 10:18 am    Post subject:
I'll have to try this, can you use it to get 96Hz interlaced to work too ?? Or is this ONLY for 48Hz refresh...
fishlogan
Posted: Fri Oct 24, 2008 10:25 pm    Post subject:
yeah, it works for interlaced too but its been a while since i used and interlaced res. best to load an existing interlaced refresh rate and then adjust accordingly
Elaine Benes
Posted: Sat Nov 01, 2008 4:22 pm    Post subject:
Zebu Fellenz wrote:
I have working timings for an Nvidia card. However I'm using a 7950GT with powerstrip, you may want to look into one of these cards it works great for HD and has all the gamma and playback (purevideo HD) settings that the other cards have. I've run 1080p 48, 1080i 96, and 1080p 60 with this card and use 1080p 60 now with my G70.
Erik
Hey, I just picked up one of these cards, can you post what OS you have all of these resolutions working with ? And what version of the drivers/control panel, and what version of powerstrip, and the timing particulars, if its not too much of a hassle, please ?
I'd really like to try 1080i 96 or 120 even...
Posted: Sun Nov 02, 2008 2:38 am    Post subject:
I believe Powerstrip is now working for later Nvidia cards.
Has anyone tried it?
Posted: Sun Nov 02, 2008 12:17 pm    Post subject:
Define "later Nvidia cards"
Elaine Benes
Posted: Sun Nov 02, 2008 2:12 pm    Post subject:
It is working very well with my old 7950GT that I just got, using VISTA OS, which is a very pleasant surprise, BTW. Its nice to be back to the point where experimenting with resolutions is easy again...
One thing though, some of the custom interlaced resolutions I've tried, while producing a good desktop, end up doubling the size of the BD playback in PowerDVD8 so I can't play the movies back properly, anyone know what's up with that ?
Posted: Sun Nov 02, 2008 9:00 pm    Post subject:
All of them I think. 8x and 9x series.
