New product idea: Frame rate tripler (1080p24 to 1080p72)
Gino
Posted: Tue Dec 09, 2008 12:50 am    Post subject:
WTS wrote:
I'd have to agree with Person99, and just what PJs are going to be able to use a 1080P/72hz signal without it looking very very soft. BW folks, it takes lots of BW to use that and I know of none that will including stock cine9 boards. Even my modded boards or Gregs or MPs won't handle this.
I don't understand this... MP has numerous posts and shots showing that his "lowly" 8500 is capable of 1080p72. In fact he sells his mods as being 1080p72 capable. He even writes that they do a better job of it than the mighty Cine9
WTS
Posted: Tue Dec 09, 2008 2:03 am    Post subject:
Well what can I say, MP should know the limitation of the Barcos video path as well as I do so I'm not sure now he could claim that for the cine9 or any Barco. And yes him and I have had this discussion before.
Even the Marquee boards which use a similiar chip as found in the Cine/S series will have the same limitations, and that is one of BW.
Walter
Gino
Posted: Tue Dec 09, 2008 2:32 am    Post subject:
He actually claimed that his 8500 outperformed the Cine9 when it came to 1080p72
WTS
Posted: Tue Dec 09, 2008 4:49 am    Post subject:
I'm not about to challenge what he saw on PJs that he worked on.
Walter
Person99
Posted: Tue Dec 09, 2008 3:41 pm    Post subject:
So, let me get this straight--you think the guy that is selling boards for several hundred dollars that are a few bucks worth of parts and less than 1 hour of labor to create is an impartial observer? Or are any of the people that have paid this money an impartial observer?
I've seen the mods in an 8500 and they certainly improve the image. But, the bandwidth is simply not there as Walter says. This is physics of the situation (I understand it and I only had 2 EE courses). Search for Chiem's bandwidth write up on AVS--he details this pretty well.
Bottom line is you are not going to get an 8500 nearly as sharp at 1080p/72 as just about any good 1080p digital that accepts 1080p/24 (most display that at 72 or 96).
Posted: Tue Dec 09, 2008 3:56 pm    Post subject:
VDC does have thier 8500HR that does do 1080p easily and I think its @72, TSE mentioned it somewhere else but not in this post i am linking:
http://archive2.avsforum.com/avs-vb/showthread.php?t=708814&highlight=8+inch+tube+does+1080p
He has a new VNB that they were working on that really improved on BW, if we ever see these out on the used market
will be another thing, they are like 1700 each new IIRC. They also did work on the VIM. I do believe this is what really pushed mike to get 10870p@72 from his 8500. he Visited TSE and saw that and coudln't let it go and had to try. I think its awesome he pushed himself to achieve that. But if I could only get my hands on those VNB's and Vim ! Very Happy And this
pic from TSE is much sharper than the one MP has posted. But remeber this is set up on a small screen and
with the PJ perfectly centered on the screen. So i do think Mike has got 1080p on the 8 inch tubes no problem but not as good as this!!
TSE does 1080p on an 8 inch tube
Person99
Posted: Tue Dec 09, 2008 4:02 pm    Post subject:
Athanasios, what is the bandwith of the 8500HR? What tubes are in it (are they just 180s like the 8500 MP was playing with or P16s or better)? How did MP get the bandwidth up over 180 as Greg is the only one I know trying that path (and on Barcos). I've not seen any Quee mod that increased the bandwidth to near that.
Posted: Tue Dec 09, 2008 5:31 pm    Post subject:
I am not sure of the HR BW i know the newer VDC's are 150 , so for mike to get it up a bit more i can believe , you have to remeber on producton machines , even small quantity numbers the bean counters still use less expensive and less than optimal speced parts, there are better performing parts that would allow the high bandwidth parts to achieve there originaly tested specs that were performed in lab conditions. if you look at specs for IC's and the associated exernal parts used in testing then look at the actual use of that IC in production equipment you never find the exact recomended parts, they always go the cheaper route.
Ok I found a one on one off shot from mikes pics 1080p@72 not as sharp as TSE's but close. and its all three colors at once so its not as sharp as if it could be on a single color. And I think he was useing 180 tubes as he says they can relove 1090p@72 fully. I know he had more pics of the 1:1 but its a pain to look for all his posts.
Mike Parkers 8500 ar 1080p@72
Mike parker 909 1080p@72
they look pretty close.
Person99
Posted: Tue Dec 09, 2008 6:25 pm    Post subject:
I don't believe that at all. The video chip is the bottle neck. You cannot drop in the 180s used in the 909 due to the power requirements. That is why when Greg played with the 180 MHz chips, he had to build a custom power supply for them. Perhaps MP is doing this but I've never seen talk of it. So, he probably still has the lower BW chips in their.
Yes, but upgrade those parts all you want, your bottle neck is still going to be the video chip. It will certainly help if MP shifts the whole chain so that the weekest point is the video chip, but I don't care if he feeds it with a firehose, the video chip will still be a garden hose.
Show me 1 on/1 off from the top left corner. Smile
Secondly, which should go without saying, it is a fair assumption that even with MPs mods, pretty much no one here has the set up talent of MP or tse, so they will not achieve results comparable to what they can achieve. So, I'd invite anyone who set up their own PJ to post 1/1 patterns of the top left corner of the screen at 1080p/72--modded or not, I'll bet you a huge chunk of money they won't look like these. Smile
Posted: Tue Dec 09, 2008 7:06 pm    Post subject:
This is what MP and Greg change, the video chip, transistors in the video chain etc, greg and I have had some talks Via e-mail about the Marquees Video Chain And he says it is doable, But has of late concentrated on the Barco's.
Once again those are changed, Greg told me he uses a 2 Gig chip in the Marquee
there was thread started by the Late MrKing about this,
http://www.avsforum.com/avs-vb/showthread.php?t=873475&highlight=smpte
Mike has some pics some where of the cornes, and On TSE's machine does well in the corners
corner of TSE's
Person99
Posted: Tue Dec 09, 2008 7:21 pm    Post subject:
Thanks. Anthanasios. One caveat, I'm not saying it can't look decent with typical HT content, it just will not be razor sharp, nor as sharp as lower bandwidth.
That said, let's consider tse's top left corner (which you said tse's looked better than MPs). Note the MTF of the black and white horizontal lines in the 2 on-2 off pattern--that is what they should look like. Compare that to the 2-on 2-off vertical bars--not even close.
But, the real tell-tale sign is the thick white box around the test patters. Look at the outer left edge of that--way soft. Imagine that is a planet surrounded by space--it is going to look more like a cotton ball than a planet! This part of the picture proves it is only "adequate" at 1080p/72, not what it should be.
WTS
Posted: Wed Dec 10, 2008 12:02 am    Post subject:
I'd have to agree with Dave on this too, looks pretty soft to me. What test discs have these patterns on them so I can run a test on mine?
Walter
Posted: Wed Dec 10, 2008 12:29 am    Post subject:
The patterns shown of mine are at 72HZ. TSE's are at 60HZ.
The bottleneck issue is not true on the Marquee boards that uses the AD835 chips as gain (contrast). Those chips are rated at 250Mhz. The board that I was using in my test for the patterns were modified 03 VIM's that had the AD834's, which are rated at 500Mhz. I'm also using lower resolution tubes compared to the newer higher resolution 8" tubes VDC now uses.
Also, what I'm claiming has also been verified at VDC on my visit and as TSE points out, the only way to make a bandwidth claim is to support it with the 1:1 pixel pattern.
Posted: Wed Dec 10, 2008 12:51 am    Post subject:
Thanks Mike, I knew the Marquee has plenty of room to get there, the 500hz what would be the limiting factor but for 1080p@72 its plenty of BW.
I also say lens's are a limiting factor as well, on my tube face there is less fuzz on pattern lines that with the lens's on.
I bet if Mike had better lens's it look much sharper, the HD 144 are good but not as good as HFQ 900's.
Posted: Wed Dec 10, 2008 12:54 am    Post subject:
MrKing had a test program here to run on a PC i think but i never used it, here is the link to the thread:
DVE also has a 1 on 1 off pattern but you need to get it to 72hz and no scaler does that except for the Tv-ones.
Posted: Wed Dec 10, 2008 1:11 am    Post subject:
Let's first look at the 03 VIM. Stock, it is a higher bandwidth board than the 02's. And at the time, it was still the highest bandwidth video board out there, and to this day, the only exception was what VDC had in the oven when I was down there.
being able to get the bandwidth through the video chain of either 02 or 03 VIM has a lot to with the shortness of the chain more so than a particular device being in the video chain. the thought is always the higher the bandwidth device in the chain the better the bandwidth. that is true with a stock designed board that was designed for that particular video bandwidth, but when modifying boards, you're need to be able to choose the right bandwidth device (chip or IC), which is not always a higher bandwidth device. And that can be done quite easier today because of the newer lower noise chips that are now available.
One of the goals when shooting for 'proper bandwidth' is to also look at the "flatness" bandwidth measurement.
The bottleneck in the Marquee video chain is the neck boards, though a stock 02 VIM is weak for true 1080P, it can be modified to do very well at 1080P / 72HZ.
Yes, the lenses are VERY important at these resolutions. Actually, you'll not going to do well at all with a AC lens assembly. And you'll need the very best in lenses to for AC to make things look nearly good.
1080P really requires LC lenses and the best lenses to pull off properly. my attempts in the screenshots were to show how well I was able to pull this off using standard tubes and lenses.
WTS
Posted: Wed Dec 10, 2008 1:16 am    Post subject:
Yes that is true the 835 is rated at 250Mhz BW, but that is the -3db point, the -.1db flatness which is more telling is only 15MHz. As for the 834, yes it is rated at 500MHz -3db BW but the manufacturers datasheet is a very thin on specs and doesn't even give the -.1db spec or any graphs of BW vs rolloff etc. Even trying to compare the 834 to the 835 is hard to do because they don't even list the same parameters with the same tests circumstances. This isn't unusual for IC manufacturers to do even within the same family and typically if they don't give certain specs or lots of specs it usually means they're probably hiding it's poor performance.
Walter
Posted: Wed Dec 10, 2008 1:22 am    Post subject:
The AD835 is also being used in the Barco 909, which claims a 180mhz bandwidth. And with that in the video chain, it is almost impossible to believe that spec.
On my Mikron Mods, there's a few components gathered around that AD835 chip that allows it to do better than stock. I'm also doing something very similar on the Barco 909 mods. Without that change and some major changes to the neck boards, those 909 patterns would not be as they are shown in the screen-shots.
WTS
Posted: Wed Dec 10, 2008 1:31 am    Post subject:
Yes Mike as we've discussed this before I'm familiar with BW boosting on those chips but you can only take it so far before you run into other problems. Barco did no BW boosting on any of their versions, how they can make that spec claim is beyond me. That IC is still one of the BW bottlenecks in both the Barco and EH PJs.
But regardless of BW claims etc etc, if it looks good and does the job then that is what counts in the end.
Walter
Posted: Wed Dec 10, 2008 1:42 am    Post subject:
OH.. that AD825 is a very noisy (hash) chip. it requires a ton of work to tame most of the noise. It also requires a bit of work to +/- rails to it. proper de-coupling of this chip is very important. Otherwise, it just won't do so well at those higher frequencies.
I learned a few tricks while at VDC during my visit. It's not so much what they are saying in the specs with a device as it is how and where they are using it in the chain. Impedance a few other things are very important to getting the best from the device. That's a little over my head, but I've learned a lot from Scott on this.
Also, on my G90 mods. There's also a AD835 in the video chain. That one I remove.
And as you can see from my G90 screenshot of the same resolution, I'm also pulling off 1080P / 72Hz... I'm doing something very similar to the weaker link in that chain that I'm doing to the AD835 in the Marquee's.
First screenshot taking from the lens of a modifed G90 doing 1080P /72hz
My initial
Page 2 of 3
