Toshiba P7300U
Heywood Jablome
Posted: Sat Aug 23, 2008 12:58 am    Post subject:
convict4ever wrote:
I am just learning, this site has been my resource. there is a lot make this PJ work, definately not like plugin in a dvd player to the TV and watching it.
The learning curve may seem daunting looking up at it from the bottom, but setting up these PJs is a highly scripted and iterative task... Do the basics, in order, to get a usable pic, then do it all over again, and again, and by the third or fourth time you won't be doing a Complete Setup but you will have learned enough to become a tweaker.
You can see this curve played out in others postings when they write "I know my spot size needs work" or "I know I can improve my optical focus."
Iterate complete setups a few times to beat the learning curve, then tweak and tweak some more.
convict4ever
Posted: Sat Aug 23, 2008 5:25 am    Post subject:
Thanks everyone. I know I keep saying thanks but this is so helpful. The only thing that I need an answer to is so that I may start my purchases is, what statistics or info do you need to see if this will do 1080P? I want a blu ray player. I dont want to purchase it if the 1080P wont work. I mean i would have to buy the HD Fury 2 and all the accesories just to see if it will work? Doesnt seem to logical or finacially smart. Let me know what else you need to aid me with the question of, will my PJ play 1080P?
Heywood Jablome
Posted: Sat Aug 23, 2008 10:17 am    Post subject:
1080p may WORK, but it likely won't "resolve." The difference is the electronics versus the optics: Being MultiSync (yes, just like the NEC brand name for computer monitors) the electronics may be able to latch on ("sync") to a signal of such a high frequency BUT when the projector tries to draw the image the optical restrictions of a 7" machine will prevent it from displaying 1080p properly.
CRT monitors and TVs have pixels, which are actually three dots in a cluster (Red. Green, & Blue.) An electron beam lights up one of these dots to make that pizel a given color.
A CRT projector has no pixels... rather they just draw lines on the phosphor with the electron beam. They are limited in resolving ability by the area of the phosphor on the tube face and the 'spot size' of the electron beam.
If a 7" tube has, say, 5" of usable height then the e-beam spot needs to be 5/1080 (.0046") diameter to properly resolve. This is a tall order for the electronic focus of a CRT PJ.
What will happen is the eFocus will be able to create a spot of, say, .007 inches. While the electronics are giving you 1080p, the optics are suffering 'overlap' where the lines are literally drawn on top of each other. The result will be poor focus of the finished image.
1080i is still 1080 vertical lines of resolution, but are separated into alternate frames of 540 which makes the strain on the electronics less and improves the resolving ability two ways: Even separated by 1/60th of a second your eye will detect the difference between the frames and perceive greater sharpness AND you may achieve a smaller spot size at 1080i than 1080p due to less electronics strain.
Don't write off a free CRT PJ because of a lack of 1080p: It'll still run rings around any digital under $5000 when running 1080i or 720p. Do a quick setup on the floor with the component inputs and HD cable as a source and your decision will be made. Really!
Posted: Sat Aug 23, 2008 10:39 am    Post subject:
I agree with Heywood, 1080i is just fine and 720p is also and should be used for any sporting event you watch, so you will have two memeories for each. Most PJ have memry blocks for different resolutions so your not stuck with one. So if you find a blu ray player just get it and you can output 1080i from component to your PJ right away, same as cable box or sat box. SD DVD you could upscale to 720 like most do but if you get a vieo processor i fing doubling the native 480i to 960p looks best for me. it should do 1080p with a H frequency of 15-100 and V frequency or 15-150 and the same resolution as the onix 8 so i think it can handle it. Id get one of the LG multiblue players Either the BH100 or BH200 if i were Con4e, nice way to cover all the basis. and if you like euro movies it can be made region free.
CRT_Ben
Posted: Sat Aug 23, 2008 11:57 am    Post subject:
Count me another vote for 1080i...don't buy the marketing hype of 1080p. 1080i gives you just as much detail and you're not losing a thing, believe me. The only difference is 1080p refreshes at 60Hz, and 1080i at 30Hz, but with films at 24Hz, 1080i is more than sufficient and you're still getting every last pixel up on screen.
Posted: Sat Aug 23, 2008 12:23 pm    Post subject:
Actually , after talking with Ken Whitcomb at Cliffs meet, 1080p gives you more light output due to all lines being drawn on the screen at the same time as opposed to 1080i where at any one moment only 540 lines are lighting up the phosphor. I never looked at it that way but it makes sense and is logical. 1080p is also for when you dont want to see scan lines to get that true film like image. On my marquee 8500's I prefer 1080p. I did the test and got about 1.5 foot lamberts more output with 1080p then 1080i, I also tried 720 p and got the same results. I didnt think i would be able to measure it but i was, and you can see it too. The issue is how well you can set it up, the better the set up,focus,cpc magnets,raster maximization ect the more you can get out resolution wise with out it being to soft, some softness is wanted. If you can see scan lines in program material from your seating distance whats the point? You might as well stick with 480i.
Heywood Jablome
Posted: Sat Aug 23, 2008 10:35 pm    Post subject:
There's a neat graphic in the Reality912 marketing glossy that clearly demonstrates what i was trying to type regarding overlapping pixels:
http://www.curtpalme.com/docs/BarcoReality912_Brochure.pdf
Page 1, bottom right-hand corner, under the heading Very High Resolution Images. See the 7", 9", and 12" tube faces? That's the overlapping spot I was referring to.
And, no, you should not hold out hopes of finding a 912. There were probably only 50 ever made (WAG estimate there.) Special tubes and optics that are effectively irreplaceable.
convict4ever
Posted: Sun Aug 24, 2008 6:10 am    Post subject:
That 912 is a serious PJ. I already own an upscaling Samsung HD-841 DVD player that outputs 1080I. I just wanted to have blu ray as I have seen that player. Its an awesome pic on an HD TV. Now i have never seen a PJ in action of any sorts with any output. Thats why I ask what do i need to purchase in order for me to have the best pic at a resonable price. Make a list, maybe not ur dream list, but a list that is way better than entry level. I did price that Lumagen processor. WOW is that expensive. I was thinking about using my PC to make a HTPC. I read those forums and get lost. I know alot about computers but they just talk about the hardware, etc. Can i make my PC perform with programs if needed to be purchased run my PJ? Do I need a better video card? Can you buy programs that give what an external processor can do? I.e the Lumagen. If you know of a link please copy here so I may reference it. I have done so much research, I'm gettin sensory overload. You all here on these forums help me simplify things. So lay it down for me. If you were me, what do i need to get a HTPC running. I have the follwing:
------ASUS NCT-D motherboard
------2- Crucial dual channel ECC registered 1megs of RAM for a total of 2megs
------2-250 GIG Western Digital SATA hardrives
------Gforce 7600GT Overclocked Video card
------1-Intel XEON 3.4 ghz processor, motherboard is capable of holding 2 of these bad boys
------Microsoft Windows XP w/service pack 3
------Microsoft Elite Bluetooth mouse and keyboard
------Sony DVD drive
------Thermaltake Armor aluminum case
I have acquired a 50 Meter spool of Oyaide FTVS-510 pure silver coax that I will have custom HD cables made out of with BNC connectors to RCA if I cant get an HDMI cable to work with my PJ. Ok, I think I'm done talking here and now hope to get some responses as to the setup of my PJ. Also what is the recommended screen type? You no by now I want HD 16:9 quality.
Posted: Sun Aug 24, 2008 11:38 am    Post subject:
Lumagens are expensive new but can be found used if you are patient and search e-bay and the other for sale video places or craigs list. I have seen the HDP sell for about 500 at the lowest, not bad for a 1500 scaler. your PJ cant use HDMI unless you get a box that converts it. I dont use a HTPC but what you have should work, but then how are you going to add HD sattelite and A blu ray player unless you get some sort of input card or get a blu ray drive. You'll need a VGA/RGB to RGBHV break out cable to go from your PC video card to the PJ. I still say a scaler is the way to go, sure they are expensive but i may start an argument here but they are more tuned for CRT PJ.s than HTPC's I had a fairly good PC similar to your hooked up and couldt get used to it or control everything steadily like with my Lumagen. But like I said others are more comfortable using a PC. keep looking for one and fr now use a PC i guess.
Heywood Jablome
Posted: Sun Aug 24, 2008 11:50 am    Post subject:
I'm still in the camp for pointing the thing at a wall and doing a setup. You'll need the practice and the experience will answer a lot of your questions.
Since that thing has component in, spend seven bucks at Radio Shack for BNC to RCA adapters and set the PJ up with 525p out of that Samsung HD-841. (There may be a remote hack to unlock HD component on that sammy, there were many hacks around when those scaling-limited players came out.)
Posted: Sun Aug 24, 2008 12:29 pm    Post subject:
True Haywood, you dont need a source to converge and do the focus. He should learn all this first.
Then he should look into what his source chain should be. There is a Lumagen Vision DVI on Videogon for about 450 i bet hell take 375. and you can get it to input 1080p and at least scale out 720p@72 which I think will be best for your 7 inch machine.
here is athread on a memeber who got it to work inputting 1080p:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10190.html
Posted: Sun Aug 24, 2008 1:26 pm    Post subject:
No way! 720p sucks! I'm just kidding, but there are people that love 1080i and hate 720p, and those that are the the other way around. I'm in the former camp. I can't stand giving up almost half the spacial resolution to get progressive. Worst case, taking only half the fields of a 1080i frame, there's more spacial resolution than 720p. At best case with static or slow-moving images, there's over DOUBLE the resolution in the 1080i signal. I watch hockey and have friends over for football, and 1080i just looks amazing!!! 720p is like going halfway back to SD. People pan DirecTV for being "HD Lite" because it's 1440x1080i instead of 1920x1080i... That means 720 is like HD Zero. I'm exaggerating, but on my older projector (Sony 1271), and even on my sharp new G70, I MUCH prefer 1080i over 720p - ESPECIALLY with movies.
ABSOLUTELY! Well, yes - you get every pixel on the screen, and every few frames you get pixels from two film frames at once! Seriously, film source material displayed at 1080i does NOT equal film source material at 1080p, BUT 1080i can look excellent, no question. It really depends on the projector.
What? That's like saying, "Well, I can't afford a Ferrari with 550HP, so I might as well just drive a Geo Metro." It really depends on how easily you see the scan lines... I should really probably be using a scaler with my G70 - I can see 1080i scan lines from my seating position, but 720p scan lines are just as visible. I have a lot of other toys I'd like to spend money on, so at this point I run 1080p from the PS3, and settle for 1080i from my other two sources. It's not a big deal because it's probably less 15-20% of what I watch in the theater - BD/PS3 is the other 80-85% and I watch it at 1080p.
You guys kill me talking about scalers and signal chains - even I'm silly getting into the whole 720p vs. 1080i vs. 1080p debate... and he hasn't even plugged a source into the projector, yet! We don't know how sharp the machine even is yet! Will it resolve 1080p? Who knows! Will it even resolve 1080i? Who knows? Will it probably look pretty kick-ass compared to most of the digital stuff at the stores for two grand - no matter what resolution it's running? Yes.
OP, just pick up some BNC-to-RCA adapters from Radio Shack like somebody already said, plug in your scaling DVD player, do a setup or two and see how it looks. Play with it. Learn it for a week or so. It's SD and it'll look like crap compared to HD, but you'll get a sense of how sharp scan lines will be at 1080i. Then, pick up a Blu-ray player of your choice, and maybe an HD Fury and see how you like 1080i vs. 1080p and bask in the HD glory for awhile. You'll likely be astounded by the pictures, and you'll probably watch some movies awhile that way. After that, you can start thinking about upgrades and scalers, and obsessing over resolutions and custom refresh rates and debating 1080i vs. 1080p with the rest of the freaks here (myself included).
Wink
Posted: Sun Aug 24, 2008 1:37 pm    Post subject:
I was being sarcastic with the" you might as well stick with 480i" Wink He has a 7 inch set not like your 8 inch, so 720p is most likely the best as it will give more light output having 720 lines on the screen instead of 540 with 1080i.
I agree that he should first hook up his dvd player and get familiar with the set before he searches for the other options, as I stated way back from the get go of this thread. My other suggestions are for down the road once he gets it set up and familiar with it. But the cleaning of it is first thing its too easy to 'just set it up quick" and then forget to clean it out nad a few days of watching movies and it over heats and blows something. especially with a set that is so rare as his, if something goes even curt might not be able to help, he has never seen one and said they maybe sold all of 4 or 5 of these.
But once again go to radio shack get some bnc/RCA adaptors and hook up your dvd player and start exploring your sets menu an features on any wall you can shoot it on.
Posted: Sun Aug 24, 2008 1:57 pm    Post subject:
Yep, clean it up and start playing!
For what it's worth, I ran 1080i exclusively on my good old 1271, and it was awesome - it blew people away when they saw it. Of course, it was soft enough that I couldn't see scan lines standing right at the screen, let alone from my chair. It was probably closer to resolve 960x540, but 1080i still looked awesome compared to 720p... so that's what I ran. I think because of he lackluster optical performance of the 1271/PT-whatever lenses, I think 1080i was sort of "oversampling" the optical system. This Toshiba with HD-145's may be much sharper, and 1080i scan lines may be plainly visible - or not.
Posted: Sun Aug 24, 2008 3:41 pm    Post subject:
A funny story I have about this guy I knew. He bought a car from someone. The guy actually delivered it to his house. It was one of those cool looking but rare cars. So he went out a bought new chrome wheels and fancy tires, window tinting. Then being an amature body and paint guy, painted the car. Red yet, you know, the most expensive color.
After the paint was dry he wanted to take it to town to show off to his friends, only to find out the car had no reverse and only 1st gear, and slipped at that. So now he has all this time and money into a rare car that he cant find parts for, and even if he could find some parts, hes not a mechanic and doesn't know how to fix it himself. Also being rare he cant find anyone to fix it for him.
I guess he should of test driven it before spending all that time and money to make it what he wanted it to be.
Oh well, lesson learned.
Posted: Sun Aug 24, 2008 4:24 pm    Post subject:
great analogy Gyver !
nashou
convict4ever
Posted: Sun Aug 24, 2008 5:26 pm    Post subject:
WOW!!! my only problem is I have no where to set this beast up. I will definately clean it first. I take care of everything I own and to me it seems dirty. Some Caigs, a can of air, and some isopropyl alcohol should clean those boards up real nice. I will check the high voltage wires for cracks. Blow the fans out as well. any suggestions on a screen? I can only imagine the debates that will come from this question. Laugh out loud!!! Laughing
Posted: Sun Aug 24, 2008 5:42 pm    Post subject:
Screen size is up to how bright you want your picture and how much room you have for the screen and also the throw distance of the PJ in the room. here are some specs on the HD 144/145 the two lens are close in specs.
Screen are not cheap, so you can get a piece of wilson art designer white and use that, But one of the cheapest and a very good screen from what a few here have said is the hurley matt finish and super glow, If you get the lace and gromet type and make your own frame it is the least expensive , I just was quoted 400 bucks for 13 FOOT 2.35 screen. I think its a good price.
HD-144 pdf 1.pdf
 Filename:  HD-144 pdf 1.pdf
 Filesize:  1.35 MB
 Downloaded:  184 Time(s)
Posted: Sun Aug 24, 2008 5:52 pm    Post subject:
For now, while your just getting use to the projector and testing to make sure all of it functions correctly and for an extended period of time, I would just shoot it on a white wall. If you dont have a white wall and dont want to paint one, then just use the lightest color wall you have, just dont expect good color balance. If it still continues to function well and doesn't give you any problem, then decide on a screen. This is still a learning process for you as far as convergence and setup and you really need to learn all these functions first. But just remember to have fun. Thats what its all about.
convict4ever
Posted: Sun Aug 24, 2008 5:55 pm    Post subject:
Cool! I will clean the PJ up as I have had no NO's as how I plan to clean it from the forum. I go into everything with confidence. I know this PJ wont do me wrong. LOL!!!
Page 3 of 4
