| Posted: Sat Aug 16, 2008 11:26 am Post subject: OK Marquee guy's, I need your help |
No I didn't buy a Marquee. At least not yet, not as long as the 4600HD lives
I am programming a Crestron controlled theater that has a Marquee. I'm using 5.7" touch panels for control. To allow for comfortable sized buttons on the panel, I'll have to do 2-3 pages. I would like all source/channel selection buttons on page 1. All setup/touch-up controls on page 2. anything else on page 3 if needed. I also have a couple of questions.
1. Does a Marquee detect and automatically switch to a saved memory location like a NEC or does it need to be manually switched?
2. If it needs to be manually switched, what is the button press sequence required to select a pre configured channel?
The idea here is to have all these operations happen in the background using logic to automate the whole thing. Master power on/off buttons turn on/off everything with one button press. Press the Blu-Ray button and the sound system, video switcher and projector go to pre-configured set-up's. 99% of the time, the end user will never have to access the individual component control pages. For day to day use, only basic navigation controls for cable and DVD control will be provided. Of course, full controls will be available on the individual component page. Thanks,
_________________ Chip
Gino
| Posted: Sat Aug 16, 2008 11:42 am Post subject: |
1. It can do both depending on if you have ASR active, or ASI active, or both. If none are enabled, you will have to manually choose memories.
2. Most would have memories saved in Recall memories. So you need to press 'recall' and then the memory location eg. '01'
If you are connecting to different input boards, you'll also need to press 'input' and the input location eg. '01' before hand.
You can also choose to enable channels, so you can just press the number for the channel or up/down i think.
I find it easiest just to setup each memory and have ASR active to automatically choose, but leave ASI off as this tends to make mistakes with interpolating the settings.
| Posted: Sat Aug 16, 2008 11:59 am Post subject: |
Thanks Gino, For the most part I think he'll be using his internal HDMI input card, although I'm sure he still has some use for his RGBHV input. I haven't got that far yet.
| Posted: Sat Aug 16, 2008 3:11 pm Post subject: |
| Nashou66 wrote: | | get a logitech 1000. |
Baby-balls This is part of a whole house automation project including irrigation without a outside controller. Crestron will provide all logic and switching for that. That is especially handy for when the bible bangers come knocking at your front door and refuse to leave until someone answers You can turn it on from the comfort and safety of your favorite recliner
JustGreg
| Posted: Sat Aug 16, 2008 6:18 pm Post subject: |
LMFAO!! That's hilarious and Oh So wondefully evil.
_________________ Greg
| Posted: Sat Aug 16, 2008 8:37 pm Post subject: |
| JustGreg wrote: | LMFAO!! That's hilarious and Oh So wondefully evil.  |
Life's a bitch, if I've got anything to say about it
The Girl Scouts make it to the front door, but only if mom's smokin hot
Heywood Jablome
| Posted: Sat Aug 16, 2008 11:49 pm Post subject: |
| stefuel wrote: | That is especially handy for when the bible bangers come knocking at your front door and refuse to leave until someone answers You can turn it on from the comfort and safety of your favorite recliner  |
The Witnesses came to the door to save me today.... I could have used the privacy trigger.
Instead, I have a 150lb dog that can take seven stair treads in two strides and punctuate his appearance with a great big WOOF
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
| Posted: Sun Aug 17, 2008 12:11 am Post subject: |
| Heywood Jablome wrote: | | stefuel wrote: | That is especially handy for when the bible bangers come knocking at your front door and refuse to leave until someone answers You can turn it on from the comfort and safety of your favorite recliner  |
Instead, I have a 150lb dog that can take seven stair treads in two strides and punctuate his appearance with a great big WOOF |
Ahhh the Jovee's, exactly who I was talking about. I have naild them a couple of times
| Posted: Sun Aug 17, 2008 12:14 am Post subject: |
Heywoodie, What's left to do to get the Marquee back together?
| Posted: Sun Aug 17, 2008 12:25 am Post subject: |
Oh, one quick heads up. Those touch panels need to be in the docking station to charge. If you plug the PS into the power port on the side, it's simply running on external power. There is no charging function in that configuration.
Heywood Jablome
| Posted: Sun Aug 17, 2008 12:34 am Post subject: |
| stefuel wrote: | | Heywoodie, What's left to do to get the Marquee back together? |
Well, I've got a week to play. I've pretty much done nothing but landscaping and working too much in the past few months... I've got to change two more bellows and a C element and put it all back together again.
Heywood Jablome
| Posted: Sun Aug 17, 2008 1:04 am Post subject: |
| Nashou66 wrote: | Do you need a red C-elemne buddy we are trying to get group buy going to save 50 bucks, and there are only 24 left at 3M, then they are gone.
And VDC wont sell them i think like the Bellows. I am also looking for a maker for those as well.
Hope you get it back together soon.
Athanasios |
Don't need any parts... Just gotta get off mine arse and get moving. Between work, yardwork, all together too much charity work, and now emergency appendectomy I've been ignoring the 9501LC.
Heywood Jablome
| Posted: Sun Aug 17, 2008 1:15 am Post subject: |
Nope. Bought the C element and three bellows from VDC in April IIRC.
| Posted: Sun Aug 17, 2008 11:46 am Post subject: |
| Heywood Jablome wrote: | | stefuel wrote: | | Heywoodie, What's left to do to get the Marquee back together? |
Well, I've got a week to play. I've pretty much done nothing but landscaping and working too much in the past few months... I've got to change two more bellows and a C element and put it all back together again. |
If you want a hand with it, I can come over for a couple of hours tomorrow after my Dr.s appt. (@2:30).
aspec2
| Posted: Sun Aug 17, 2008 3:28 pm Post subject: Re: OK Marquee guy's, I need your help |
| stefuel wrote: |
The idea here is to have all these operations happen in the background using logic to automate the whole thing. Master power on/off buttons turn on/off everything with one button press. Press the Blu-Ray button and the sound system, video switcher and projector go to pre-configured set-up's. 99% of the time, the end user will never have to access the individual component control pages. For day to day use, only basic navigation controls for cable and DVD control will be provided. Of course, full controls will be available on the individual component page. Thanks, |
Don't use the auto detect unless you like an average of 2 parts of your work. Set up a recall and channel for each input. and turn off ASR and ASI.
Set up channels in th projector associated with recalls. Then when DVD is pressed you send "1" "0" to the projector (channel 10 e,g,) which is associated with the recall that has your set up for DVD. This is simpler than sending "recall" "1" "0".
Mine is so simple the wife can use it.
Walt
