ilias
| Posted: Mon Jul 14, 2008 2:40 pm Post subject: G70 Centering 1080p? |
I have centering the image in 1080i, but in 1080p the image is not goin in the center with SHIFT!!!
| Posted: Mon Jul 14, 2008 3:00 pm Post subject: |
It sounds to me like you're using the wrong adjustment, SHIFT moves the image within the raster while the center adjust moves the raster on the tubeface. Try using the center adjustment in the service mode and see if it fixes your problem, you may be running out of shift range.
Erik
| Posted: Mon Jul 14, 2008 8:29 pm Post subject: |
What's your source? Some sources will be trouble... The left-shift problem at 1080p can be tricky.
You may need to increase the size of your raster (relative to your screen) to give you more range, by using the "size" control.
ilias
| Posted: Tue Jul 15, 2008 6:33 am Post subject: |
My source is PIONEER DVR-550H is DVD-RECORDER with HDMI and upscale 1080p, i tried the DVDO VP30 but 3 people (specialist! and manual) no make work! so direcly to PIONEER! and later, splitter for BLUE RAY!
ilias
| Posted: Mon Jul 21, 2008 10:49 am Post subject: |
I fixed my self!!! the VP30 has lock in HDCP and has no picture!!! I play in 1080p 60, but i can't go in 1080i 75 hz, and no 75 hz at all.
ilias
| Posted: Mon Jul 21, 2008 1:36 pm Post subject: |
I have the HD FURY! and i fix the one problem, now see the 1080p 60hz with very little artifacts, but the DVDO VP30 can't play in 1080i 75hz, the picture is very small and no fit in the screen!!!
Must change the DVDO?
| Posted: Mon Jul 21, 2008 2:00 pm Post subject: |
I'm not familiar with the Vp30,s But there should be size and position controls to adjust the pictures size, or you may have to use the sony size and position controls, or a combination of both, the VP30 and the sony.
Maybe someone who has a VP30 can help you more, any one here have more experiance with these units?
ilias
| Posted: Tue Jul 22, 2008 2:12 pm Post subject: |
Must change the Gain and Bias numbers? were find the basic numbers?
ilias
| Posted: Sun Jul 27, 2008 7:04 am Post subject: |
I think the HD-FURY not support the 75Hz!! Who's answer to this? Curt?
| Posted: Sun Jul 27, 2008 8:13 am Post subject: |
| ilias wrote: | | I think the HD-FURY not support the 75Hz!! Who's answer to this? Curt? |
I don't know if it will go 75Hz but it will do 1080P at 72Hz.
| Description: |
| Filesize: |
136.96 KB |
| Viewed: |
7230 Time(s) |
ilias
| Posted: Sun Jul 27, 2008 3:09 pm Post subject: |
I have SONY G70!! Were you have the HD-FURY?
ilias
| Posted: Sun Jul 27, 2008 5:18 pm Post subject: |
Then the HD-FURY is ok with 1080p 75Hz !!!
| Posted: Sun Jul 27, 2008 6:26 pm Post subject: |
| Nashou66 wrote: | | ilias wrote: | | I have SONY G70!! Were you have the HD-FURY? |
I think Analogrocks has it on his Ampro 4200.
Athanasios |
Actually I have an Ampro 4000 but that screen shot was from my Sony G520P 21" CRT monitor. I love the on screen clock rate display.
ilias
| Posted: Mon Jul 28, 2008 6:55 am Post subject: |
[quote="Nashou66"]Illias Did you figure out how to center the Picture yet?
No the 1080i 75Hz it very small picture and not fit in the screen, 1080p 75 the G70 it can't be up this analysis (I think!!)
ilias
| Posted: Mon Jul 28, 2008 3:43 pm Post subject: |
Now plaiyng with 1080p 60Hz in 120' and it very nice picture!!! i thing stay in this, and litle search the VP-30 more!!!
ilias
| Posted: Tue Jul 29, 2008 11:08 am Post subject: |
| Nashou66 wrote: | So your not going to use the VP30 anymore?
Athanasios |
Yes that scaler i use now! i have output 1080p 60Hz! And i like my picture, but some friend found artifacts and flickering, playing DVD's say is from scaler, or the PIONEER DVP-550H DVD RECORDER !!!
I can't fix that problem!!
