antorsae
| Posted: Tue Apr 27, 2010 12:15 pm Post subject: |
The devil You just made me do it... I am going to buy this:
http://sewelldirect.com/Blackmagic-Design-Intensity-Pro_specs.asp
To test what you just suggested.
Right now I am using my HTPC as the only source but the software I modified to do 1:1 edge blending with gamma compensation, 10-bit processing, etc... This is a labor of love for me... if you want to play with my software, etc. just let me know and I'll send it over... I've improved it a lot since I last reported here. I've been very silent b/c I am just enjoying movies....
| Posted: Tue Apr 27, 2010 1:57 pm Post subject: |
| antorsae wrote: | The devil You just made me do it... I am going to buy this:
Right now I am using my HTPC as the only source but the software I modified to do 1:1 edge blending with gamma compensation, 10-bit processing, etc... This is a labor of love for me... if you want to play with my software, etc. just let me know and I'll send it over... I've improved it a lot since I last reported here. I've been very silent b/c I am just enjoying movies....  |
I was talking about the marquee control software and the DSLR calibration software. I am not sure if you
sent it before . I have so many e-mails i can't keep track!
maybe some time this or next week we can try the remote calibration once i get the hard ware all set up.
I need to get one more PC to run the test patterns program you made.
I'll email you when i think I am ready.
Boilermaker
| Posted: Tue Apr 27, 2010 6:20 pm Post subject: |
| Quote: | | The devil You just made me do it... I am going to buy this: |
I have many time been accused of "helping" others spend their own money!
I'll admit it would be awesome if we could have a standalone PC with DVI or HDMI input, have two analog/digital adjustable blended outputs with full and separate CMS', with adjustable output resolutions/refresh rates. It would also be nice if a 2-3 way toggle could also be done to switch output refresh rates for video/film.
While it would be better if it were simply hardware based, I, and probably many others would go for this as a cost effective way to have state of the art blending. My problem is that I am a hardware guy, so it would have to be an easy thing to set up. I was born in a day that "digital" meant you did it with yur fingers!
BTW - The only thing I see missing on that input card is the ability to accept 1080P@ 24 fps. so it wouldn't have to do any de-interlacing. It would probably do it, but they just left it off.
Keep it up,
Bob
antorsae
| Posted: Tue Apr 27, 2010 10:02 pm Post subject: |
You're right about 1080p - I am not going to use that anyway (non-HTPC sources for me are just XBOX360 and PS3 and no games I play are 1080p... so 720p60 would suffice) ... but that being said it would probably make more sense to get this one http://www.blackmagic-design.com/products/intensity/techspecs/ instead. It supports DirectShow which is what is required to be pluggable into the SW blend.
Boilermaker
| Posted: Wed Apr 28, 2010 1:09 pm Post subject: |
Since it appears that there are at least a few people interested in the possibility of a blend, I thought that I should share some of my experiences with it to help anyone considering doing a blend. The easiest way to do this is probably by just listing points and trying to give my opinion on the differences between the available methods.
There are currently three ways to create a blend: The Diventex (sp?), the TVone, and the software method as done by Andre. Sorry, but I can't help with any info on Andre's software solution as it is way above my pay scale. You have to have a big brain. Perhaps he can add his thoughts. My experience with the Diventex is very limited, but because I ended up using the TVOne's and I learned from every one of the many mistakes I made, hopefully I can give some good advice.
The advantages I see for the Diventex are that it is a one box solution. The TVOne requires two boxes and therefore any operational or programming changes need to be done twice. This means that if you decide to go with the TVOne, I highly suggest using a separate scaler (Lumagen, DVDO, etc.) to perform multiple input switching and AR control and allow the TVOne's to do nothing but the blending.
The second advantage I see to the Diventex is in its ability to shape the gamma correction within the blend zone whereas the TVOne's are less adjustable. I have found, however, that if both projectors are perfectly matched in their grayscale/gamma curves, the blendzone with the TVOne's does become invisible.
The first advantage of the TVOne's is pricing, but remember that while you might be able to get away without a separate scaler on the Diventex, it would be a major PITA to do so with the TVOne's.
The second advantage I see with the TVOne's is its ability to customize the output resolution to whatever you want. It will store more than 100 different resolutions and they are all customizable. The Diventex does not allow for customizable resolutions and the resolutions available do not correspond to any of the ATSC HD standards. This ability means that you can set your resolution such that it is a perfect 1:1 pixel mapping and also such that you are really saving bandwidth. For example, a 10% blend using output resolutions of 1064X800 @72 Hz. refresh would allow for perfect 1:1 mapping of a 2.4 AR film based movie with absolutely no manipulation of any pixels, and no scaling or de-interlacing. The end result would be that the video frequency of this would be such that each projector sees is actually less than conventional 1080i.
There are some issues that I feel you should consider if contemplating a TVOne blend that Athanasios and I have discovered, so I'll list them here:
1 - There might be some sort of HDCP or EDID handhake issues - Athanasios has some issues, and we also found that if the VideoEq's were placed before the TVONe's in the signal chain, there would be no video output. This problem was solved by using the VideoEq's after the TVOne's which required me to use a pair of Moome Mux boxes as D/A converters instead of just using the analog outputs of the TVOne's. This occured even if the original source was analog which couldn't contain any HDCP!
2 - While they are capable of storing many output resolutions, in order to change the selection, you must navagate through the menu section of each box to make the change. It takes a few minutes, and is hardly user friendly. While you can select 60Hz as your output for all sources, if you decide to use 72 Hz for film based sources, you will find that 72Hz is so jerky with 60 Hz video sources that it is unwatchable. Your choice here.
3 - While I don't deny that there might be some professional calibrators that can perfectly match both projectors, I highly recommend that you have separate CMS systems such as Lumagen, VideoEq or the new DVDO Duo. Athanasios has chosen the Lumagen route as he already had one, but I had to buy a pair of VideoEq's to get the job done.
My experience has shown me that this is one of those things with a relatively long learning curve, but once you finally get it right, it would be easy (but still somewht time consuming) to do again!
Would I recommend anyone to do this - Absolutely!!! You will be rewarded with a PQ that is truly incredible. Now that I have done it, I would not want to live without it.
Bob
| Posted: Wed Apr 28, 2010 2:44 pm Post subject: |
Nice Write up Bob.
I was looking through the Tv-One catalog and they have another Blend scaler not listed on the Blend section of the web site and it is significantly lower cost than the C2-2250's looking at my dealers price list.
its the Model 1T-C2-760. it has 2 dvi inputs, no LCD screen but it can be controlled via the Corio2 PC software.
The latest version is really nice because you can control an array of Corio2 based processors at the same time
just by switching tabs. Also they have an edge blending set up software I have not tried yet.
I think someone could get into blending with these for a little more than the cost of 1 C2-2xxx model.
So about 2200 or so for two units , I don't have the price list in front of me but It is in that ball park.
Bob is right about my HDCP issues so i use the Moome MUX before the Tvones and Lumagens and use that as a splitter
since it has one hdmi and one DVI. Moome said he is making new units with 2 HDMI and HDMI audio to boot!! I asked him to add an HDMI audio specific out as well for us blenders. I also use the Mux as my source switcher since it has 4 hdmi inputs. It is a great unit for anyone to have as it totally eliminates any HDCP issues. I hate HDMI.
Bob uses HD-SDI so that is another way to avoid HDCP but it is very costly and you need HD-SDI inputs for the one of the processors, either the Tv-ones or the radiance or use a HD-SDI to HDMI/DVI converter. Both methods work well to avoid HDCP, just pick your poison.
The biggest issue is matching both PJ color Gamut, greyscale, and Gamma at the typical 11 point IRE's.
once Tv-One writes the windows based 256 point Gamma control that they might even add CMS to it will be arguably the de facto blend unit on the planet.
But there is possibly another in the works, and not from TV-One....
Bob I am glad you keept pushing me and continue to. i need a reliable probe.
Sounds like the DIY HFCR probe you borrowed is better than the i1-'s so far.
I found another issue with my i1 yesterday. I figure if i use the screen offset and then have the probe face the screen i would get higher readings for Y as more light will go into the probe. I got worse Y readings, droping in half. with your D2 it went up. i really think i have a bum i1 pro. Also it would not read the red and green color gamut unless i tried it at least 5 times. blue read on first try each time.
ok i am digressing here.
Boilermaker
| Posted: Wed Apr 28, 2010 3:12 pm Post subject: |
I just took a look at the specs for that new model C2-760 and they are identical to the 2350A for 1/2 the price!
If you look at the picture of the front panel it has two buttons labeled "preset 1" and "preset 2". My guess is that is for two output choices which means that to switch from video source to film source would be just a couple of button pushes or maybe just an IR button!
Hey - If they choose to activate the full grayscale/cms that it is capable of, this blending thing just got real cheap!
Bob
| Posted: Wed Apr 28, 2010 3:16 pm Post subject: |
| Boilermaker wrote: | I just took a look at the specs for that new model C2-760 and they are identical to the 2350A for 1/2 the price!
Bob |
I think I need to ask one of the engineers if they use the same scaling engine and have the protocols in the units like they do in the C2 2xx series. If so then yes it is the best solution. I would miss the LCD screen, and toggle control. i got very used to it now and whip my way around the menu system very easily now.
Boilermaker
| Posted: Wed Apr 28, 2010 5:12 pm Post subject: |
| Quote: | I think I need to ask one of the engineers if they use the same scaling engine and have the protocols in the units like they do in the C2 2xx series. If so then yes it is the best solution. I would miss the LCD screen, and toggle control. i got very used to it now and whip my way around the menu system very easily now.
Athanasios |
I have never used the Corio software. Have you used it, and if so, is it user friendly?
Bob
| Posted: Mon Sep 12, 2011 1:28 am Post subject: Blend and Equipment pics of Bob's rig he sent me to post |
Here are some pics of Bob's NEC Blend screen shots along with some pics of his set up. He's still learning how to host pics etc so I said I'd do it for him.
I bet Curt will like some of this stuff
I like how Bob built the tweeters into the wall same with the drivers. maybe he'll comment on what he did.
Pretty cool I think!!!
Custom built 4 inch square steel tubing!!!
Its his first time with screen shots but really good I think!!!
Great work Bob !!!!
dturco
| Posted: Mon Sep 12, 2011 1:49 am Post subject: |
Holy sheep sh*t!!! Anyone who uses Bryston power is alright in my book. That "Rig" for the p/J's is cool too. Hell the whole DIY bit is fantastic.
http://www.hulu.com/firefly
ChrisWiggles Opinionated SOB
| Posted: Mon Sep 12, 2011 2:02 am Post subject: |
Cool setup!
What the heck is that amp!?
Boilermaker
| Posted: Mon Sep 12, 2011 10:07 am Post subject: |
| Quote: | | Anyone who uses Bryston power is alright in my book. |
Good eye's! Believe it or not, I got those Bryston's for 0$. I rebuilt a HT for a guy after a fire. They weren't damaged at all, just needed a bath, and he insisted on new replacements which the insurance company went along with.
Gotta go right now, but when I get back from work I'll tell about that awesome Perkins monoblock.
Bob
Boilermaker
| Posted: Mon Sep 12, 2011 10:13 am Post subject: |
NOSTALGIA QUESTION - Anyone recognize the component just above the Otari reel to reel? Yes Curt, I know you were in diapers when they were used!!!
Bob
| Posted: Mon Sep 12, 2011 11:10 am Post subject: |
Bob |
Not recently; the new STE100 SmartEdge has the Diventix' one box ease of use, is HDCP compliant, and was MSRP $6600 last time I checked. You may give up custom resolutions but everything else is simplified.
Boilermaker
| Posted: Mon Sep 12, 2011 6:16 pm Post subject: |
| Quote: | | What the heck is that amp!? |
In the mid 1970's, a Canadian named Mike Wright started a speaker company called Dayton-Wright that built and sold a very different full range electrostat that IMHO had more potential than any speaker made up to today. Unfortunately, Mike never completely worked out all the many bugs before he ran out of $$, so it was never a commercial success. But that didn't stop me from buying a pair!
The biggest flaw was that its impedance dropped below 1 ohm at high frequencies which caused all amplifiers made back then to crap out at any reasonable volume level. That was before some companies started to build "high current" amps.
So, along with a friend who owned an electronics service company that had the tools to custom make equipment (Perkins), we designed and built a pair of monoblocks specifically to drive my Dayton-Wrights. It worked!
Particulars on the amps are: 150lbs. each, 220volt input as 120 volt/20 amp circuit breaker would usually trip on start-up, supply rails run at +-100 volts, output stage has 32 - 250watt bipolar transistors all mounted on a"chimney" style heat sink with a high volume fan at one end.
We measured the output power and got 500 watts rms at 8 ohms, 1,000 watts at 4 ohms, 2,000 watts at 2 ohms, but did not have an adequate load resistors to measure at 1 ohm, but felt fairly confident it would do 4,000 watts.
After I traded my Dayton Wrights, I have used the amp for many years as a subwoofer amp. About 2 years ago the full wave bridge rectifier went up in smoke on turn on, so I have been using a big Crown amp until I can lift it up to my bench and replace the diodes.
The circuitry was copied from an early generation Nelson Pass design (just put the power supply and outputs on steroids).
Bob
Boilermaker
| Posted: Mon Sep 12, 2011 6:32 pm Post subject: |
| Quote: | I like how Bob built the tweeters into the wall same with the drivers. maybe he'll comment on what he did.
Pretty cool I think!!! |
Thanks Nash - Both left and right channel speaker assemblies are fabricated from 5/4" mdf. They are 9' tall and I never had to saw anything especially that obtuse angle that makes the tweeter face my seat. All cuts were done by a local cabinet shop that has a 16' cnc table that made perfect cuts. The woofer section contains 4 - 8" Peerless (forgot the model number) drivers that are used in a ported enclosure for an F3 of 35 Hz. The port is invisible as it is on top. All designs were done by "Bassbox" software. The electronic crossover is at 250 Hz to the 6' tall BG Corp, Radia ribbons.
The thing that really made the audio come to life was the Audyssey Pro calibration I did a couple of month's ago. Well worth the price of the kit.
Bob
Boilermaker
| Posted: Mon Sep 12, 2011 7:32 pm Post subject: |
| Quote: | | How much did that thing cost you back then? |
I don't remember exact costs, but as I recall we started with a conventional steel chassis but had to have two reinforcing sections from side to side to handle the weight of the transformer. The "cooling tower" was the most expensive as it was made by Wakefield to our dimensions and all the predrilled holes for all the TO3 outputs. It was a lot of fun. Custom doing things is much more rewarding than just buying things.
Bob
