Barco Graphics 808s horizontal lines
bohnenblust
Posted: Mon Jul 07, 2008 7:18 pm    Post subject: Barco Graphics 808s horizontal lines
New to CRT PJ and cant figure this one out for the life of me.
I cant figure out what the horizontal lines on the picture in the darker images is. It appears to be in the blue realm, but I am not sure
I am running a progressive DVD player with a composite transcoder to the RGBHV input in the back of the CRT.
Adam
87" screen
(DIY not painted yet.)
 Filesize:  83.52 KB
 Viewed:  9215 Time(s)
Posted: Mon Jul 07, 2008 8:34 pm    Post subject:
Adam disconnect all input sources. Do you still see the diagonal lines with no input signal ? Next reduce brightness and contrast and look through the lenses at the CRT's themselves.
bohnenblust
Posted: Tue Jul 08, 2008 1:14 am    Post subject:
How do you keep the CRT on with no input?
It was on the blue face But it isn't moving at all could it be burn?
Posted: Tue Jul 08, 2008 1:37 am    Post subject:
The point is the with the projector turned on and no input the tubes should all be dark. Is the Blue CRT still lit ?
bohnenblust
Posted: Tue Jul 08, 2008 1:42 am    Post subject:
Ahhhh, Yes the blue tube is still lit and it has a lot of noise on it including flashes on the bottom.
Posted: Tue Jul 08, 2008 1:59 am    Post subject:
Double post... Embarassed
bohnenblust
Posted: Tue Jul 08, 2008 2:01 am    Post subject:
I have a spare PJ of the same specs with a very burnt blue.
Which should I try first?
Posted: Tue Jul 08, 2008 2:07 am    Post subject:
Swap the Blue neck board. Sounds like a G2 short in the CRT though. Did it just suddenly happen ?
bohnenblust
Posted: Tue Jul 08, 2008 2:09 am    Post subject:
no it seemed to be on the crt the whole time I have had it.
Posted: Tue Jul 08, 2008 2:16 am    Post subject:
Do a search for Sencore on this forum.
bohnenblust
Posted: Tue Jul 08, 2008 2:19 am    Post subject:
What is that?
Posted: Tue Jul 08, 2008 2:29 am    Post subject:
Sorry here's a link...
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10109.html
And this.
http://www.happcontrols.com/images/pdf/SencoreBlowsAwayCRTFailuresWithCR70001.pdf
bohnenblust
Posted: Tue Jul 08, 2008 2:50 am    Post subject:
Just changed the neck board and the lines appear to be lessend but when I viewed the tube with no input there was a constant blue flash at the bottom of the face. Is that a bad thing? it does not do that with the inpout on.
Posted: Tue Jul 08, 2008 3:13 am    Post subject:
Can you post a screen shot ?
bohnenblust
Posted: Tue Jul 08, 2008 3:14 am    Post subject:
Sure of what the tube face or another movie?
It would be neat to see if the Sencore would help the tube.
Posted: Tue Jul 08, 2008 3:18 am    Post subject:
Blue tube face with no signal and projector on.
bohnenblust
Posted: Tue Jul 08, 2008 3:22 am    Post subject:
I cant get it to show the little flare of the bottom after it has warmed up and the movie has been going for a while, not even the lines are apparent.
Ill try tomorrow.
Posted: Tue Jul 08, 2008 3:31 am    Post subject:
Sounds like maybe it's fixed. Reset the G2 levels.
Posted: Tue Jul 08, 2008 6:57 am    Post subject:
If this is not G-2 issue, then trye "run in cycle" operation that is found at barcos menu. Run projector warm and let that "run in cycle" run long enough. Many has got good results with that.
Read this (last post)
https://www.curtpalme.com/forum_archived/viewtopic.php@t=11043.html
DVDO VP-50
New hobby, Rally
bohnenblust
Posted: Fri Jul 11, 2008 10:30 pm    Post subject:
How do I reset the g2 levels on the barco, I printed both the manuals and cant seem to find a process to do this.
