HD-SDI baby!!
Posted: Sat Jul 12, 2008 4:30 am    Post subject:
Phil Smith wrote:
Gary M. wrote:
with your diagram though there is something that I didn't even realize, the digital audio signals are multiplexed with the digital video signals
Hmm...well that does sound bad! You know what sounds even worse? Cramming ALL the data one ONE wire, like HD-SDI does.
Man, the more I think about HD-SDI, the worse it sounds! Mr. Green
I believe twisted cant hold as much as solid RG6, that why they need more in there. a dual link HD SDI carries way more, but that is really only used in the Pro Broadcast field. plus shielding is much better with HD SDI, no possibility of cross talk or any fields being produced with one solid single wire.
Phil Smith
Posted: Sat Jul 12, 2008 4:31 am    Post subject:
Gary M. wrote:
whatever Phil Wink
I just stated that I didn't know that HDMI info, nothing more was said
smart ass comments help this discussion about as much as a fart in the wind Smile
-Gary
You don't back peddle worth a sh*t Gary? Wink
Hey, let's see a pic of the inside of your modded BR player! You can cover up part numbers to protect your mod. I just want to see in general what it looks like.
Posted: Sat Jul 12, 2008 4:33 am    Post subject:
probably like any SDI mod of a regualr DVD player.
Phil Smith
Posted: Sat Jul 12, 2008 4:39 am    Post subject:
Umm...I don't know how data transfer works, but I don't think that's right. I'll look into it tomorrow.
Posted: Sat Jul 12, 2008 4:46 am    Post subject:
I was thinking stranded wire not twisted pairs, my bad, as long as those twisted pairs are not stranded wire.
Gary M.
Posted: Sat Jul 12, 2008 5:06 am    Post subject:
exactly Thumbs Up only about 3 times as many connections Crying or Very sad
plus if I post images I am marketing, and finally I *can't* for various reasons
-Gary
Gary M.
Posted: Sat Jul 12, 2008 5:07 am    Post subject:
Phil Smith wrote:
Gary M. wrote:
whatever Phil Wink
-Gary
you never give it up dude Thumbs Up
-Gary
Gary M.
Posted: Sat Jul 12, 2008 5:14 am    Post subject:
SDI SMPTE 259M supports 360 Mbit/s
HD-SDI SMPTE 292M supports 1.4 Gbit/s
dual link HD-SDI SMPTE 372M supports 2.9 Gbit/s
HDMI 1.3b supports 10.2 Gbit/s
-Gary
Posted: Sat Jul 12, 2008 5:16 am    Post subject:
-Gary
It's going around ..... Wink
nomadII
Posted: Sat Jul 12, 2008 6:58 am    Post subject:
Be it HD-SDI or HDMI information is carried in specified packets.
HDMI has one packet dedicated soley to HDCP. This should be irrefutable, it is why the format exist for gods sake.
HD-SDI 292 M standards state that jitter must be within a spec of .673 pico seconds or it would also have problems very similar to a HDMI handshake issue.
Goal here for HD-SDI was performance oriented not protection oriented.
HD-SDI implements a NRZI codec, non return zero inverted so that a signal can be precisely re-clocked if necessary.
Once again the goal here is all out performance not compatibility exclusion.
I did not indicate that my link would tell you that Somers preferred one format over the other (exactly who are you waiting to hear that from?) he merely stated the differences in how they work & were constructed.
Give me an example of your favorite HD-DVD or Blu-Ray & I can tell you right now which format they used. Perhaps they had no knowledge that HDMI was "in theory" the equivalent???
Please show me a freaking $40,000 HD-Camera with an HDMI output!!
Dual link is a non factor since 3gig chip solutions have already made them obsolete.
They are now back to a single BNC w 424M.
Posted: Sat Jul 12, 2008 1:41 pm    Post subject:
I don't think Phil was making smart ass comments. (Well yes he was, but he made a good point too. Smile)
His point: you're all concerned now that you discover HDMI multiplexes digital audio and digital video. But HD-SDI uses a single wire, so obviously it is ALSO multiplexing digital audio/video! So if it's a problem for HDMI, why isn't it a problem for HD-SDI -- or if HD-SDI is so perfect and it multiplexes, why is it an issue of HDMI multiplexes?
Gary M.
Posted: Sat Jul 12, 2008 3:51 pm    Post subject:
but I wasn't saying that, I simply was saying that I did not know that HDMI worked that way, I assumed it had separate data channels for audio and video, no discussion was made of whether or not I thought that was a *issue*, if I thought that you can be damn sure that I would have said something, I don't shy away from anything
for the record, we are not multiplexing audio and video with home implemented HD-SDI, only video, not that it would matter I would think Wink
I don't know enough about either to start discussing multiplexing Very Happy
-Gary
Gary M.
Posted: Sat Jul 12, 2008 3:54 pm    Post subject:
Mark everyone here is missing your entire point you are trying to make, professional users were attempting for best performance as possible and in regards to PQ as much, this is in addition to the robustness, that is going over folks heads because you know, digital is digital so HDMI = HD-SDI Thumbs Up
-Gary
Phil Smith
Posted: Sat Jul 12, 2008 5:13 pm    Post subject:
Ok. I'm not getting the point you're trying to make.
The handshake issue seems for the most part a thing of the past. Unless you plan on buying 1st generation gear, I wouldn't worry about it.
I've had 2 handshake issues:
One was with John's DVI card. An EDID chip update fixed that. But that's a cottage industry product and doesn't really count.
The other was an Octava HDMI switcher. That turned out be because something was wrong with it (as in broke). Initially it wouldn't handshake with my HD-DVR. AS time went on, it wouldn't handshake with anything! So again, it was because it had problems other than inherent ones. So that doesn't count either.
The 7 or 8 mainstream HDMI products I've owned have had zero handshake problems. Granted, it would be nice to eliminate HDCP altogether, but I see that as a luxury, not a necessity.
And here's another article where he doesn't say anything negative about HDMI: http://www.extron.com/company/article.aspx?id=dvihdmi_ts
And another: http://www.inavateonthenet.net/article.aspx?ArticleID=15364
So as you say, Somers doesn't prefer one format over the other. Thanks for "pro HDMI" link Mark! Wink
I thought we got past that, but I guess not. HD-SDI *IS* better in a commercial envioment, but NOT because of PQ. I'm not going to cover it again. You can read the posts of Gary F. and I "violently arguing" while in total agreement ( Mr. Green ) that you apparently skipped over.
Phil Smith
Posted: Sat Jul 12, 2008 5:26 pm    Post subject:
I'm beginning to think that you HD-SDI guys are living in a "pro environment fantasy land". You're just gear whores that are dreaming your HTs are professional studios.
HD-SDI is designed for a commercial environment. HDMI is designed for a home environment. So what did the HDMI engineers say to each other when they were designing HDMI? Maybe, "Even though it's easy to make HDMI PQ perfect, we need to mess it up a little, because it's not intended for the commercial market. Home market stuff should inherently be a little sh*tty."
You guys make a lot of assumptions about HDMI's supposed limitations. Saying, "HD-SDI is a pro format!" in no way proves that HDMI is inferior. Rolling Eyes
Gary M.
Posted: Sat Jul 12, 2008 6:56 pm    Post subject:
you know that CRT PJ you use Phil, you think it was designed for the home enviornment? you point is worthless
prove it Thumbs Up , statements mean nothing without proof, I have offered contrary evidence to that yet you have offered nothing but HDMI = HD-SDI for PQ, hardly valid Phil Wink especially coming from someone that has never seen it in action Thumbs Up
are you having a senior moment? have you not read this entire thread of examples and technical reasons why HD-SDI gives better PQ? you have addressed none of them and my guess is that you will not
it would be nice if everyone lived in a fairy tale world like you do and they could go around and claim everything they think is better is definitively better while ignoring evidence and claims to something else superiority, you are so confident that you don't even address it
you have yet to address why some sources with HD-SDI and HDMI look better via HD-SDI (Samsung 1000 definitively and every other player released IMHO), you say get better sources, in that very comment you prove my entire point that I and others are making, yet you don't even realize it
you have also yet to address the technical aspects or even my points of argument I posted a few pages back (well you did address point 1)
1) HDCP insertion is processing whether you like it or not, simple fact, processing is processing
2) colorspace sampling and conversions on 90% of players, 4:4:4 HDMI vs 4:2:2 HD-SDI (BD30 Panny is the first BD player I have had in my hands that does 4:2:2 HDMI) again this is processing, processing is processing
3) bit errors in the HDMI signal, digital is digital but not without problems, all HDMI contains bit errors, HD-SDI does not in anyway, bit errors cause picture problems like noise and other degradation
4)direct pure digital signal from the decoder chip, bypassing all player processing including all the above including picture controls in some cases
5)highest end direct decoder feed to your scaler which is free from all processing that can be done inside the player, results in the best image for a scaler to work with
5)HDMI port is free for audio usage only (HDMI splitters cause further bit errors and just flat out don't work)
6)unamplified HDMI cables over 10 feet in some cases have problems, HD-SDI with Belden 1694a can be run 500 feet+
7)HDMI connectors break all the time, HD-SDI is a bulletproof BNC locking connector
8)processing of the HD-SDI signal in a device(scaler etc.) can all be done digitally and then output via RGBHV analog thru high-end D/A converters, no need for HDMI converters, add-on cards or etc.
9)most gear has superior PQ with a HD-SDI input versus the HDMI input route (scalers, processors, blendzilla, edge blenders etc.)
yet you have come to this uninformed conclusion that HDMI is as good as HD-SDI for PQ, I have to say people reading this can see your view point and how shallow, uninformed and thick skulled it is, there is nothing on this earth that will prove to you that HD-SDI is better, it will never happen, just admit it, continue to be sour and go on with life
just like scalers are for rich idiots and have no use, I shutter to think what else you think is superior that is flat out wrong
-Gary
Posted: Sat Jul 12, 2008 7:06 pm    Post subject:
You say get better sources, in that very comment you prove my entire point that I and others are making, yet you don't even realize it
I was going to point this out too but arguing with Phil is exhausting... I need a nap. Very Happy
Phil Smith
Posted: Sat Jul 12, 2008 7:54 pm    Post subject:
Lumagen says otherwise Gary. Sorry, I have no reason not to believe them.
As I get time, I'm going to educate myself on this subject, because admittedly, I don't know that much about it.
But in spite of that, I don't see where you guys make a convincing argument - at all! For one, that whole, "HD-SDI is commercial" argument that you guys are so fond of is ridiculous. It's stupid! How can you argue with anti-logic like that? You can't!
You guys are tiring ME out. I will come back to this gunfight better prepared to shoot down these unsubstantiated claims. Wink
Posted: Sat Jul 12, 2008 7:57 pm    Post subject:
oh Boy Shocked Rolling Eyes Very Happy
nomadII
Posted: Sat Jul 12, 2008 8:33 pm    Post subject:
Phil,
I sent links to a site where you can learn, not hear someones elses opinion.
Couple of the things about the AWay 8022
1) It is most decidedly a non HDCP compliant device.
2) It absolutely is Pro-Gear, which is where its intended use originated.
3) It has HD-SDI inputs which allow it to perform all of its processing purely in the digital domain.
I would submit that once you have comitted to a blend it is more than a tad unsettling that all of the effort can be undone by content protection. When you find a way around it, you take it.
HD-SDI is the cleanest signal I can provide the 8022 with, makes little sense for me not to take that path.
Moome & others have done more than a commendable job, but it is a weakspot in the video chain that I can now eliminate.
The only 8022 HD-SDI experimantation that I know of to date consist of Gino & a converted HD-DVD source & Parker & Kosmann trying out the converters made by Convergent Design. Mike indicated that all though they had compatibility problems with a Beta version of the converter he clearly saw improvements that he thought had merit.
My implementation will be much cleaner since the HD-SDi output signal will come straight from a VP50Pro.
Parker vs "HDMI must be as good" means very little to me.
It may just turn out that I get best results with HD-SDI into the 8022 & RGBHV out. I will have to wait & see.
I will not have to wait & be told or assured by a third party.
Page 7 of 9
