Bitwize
| Posted: Thu Jun 26, 2008 2:03 pm Post subject: Foot Lamberts for CRT |
How many foot lamberts do you all shoot for with your CRT PJs?
Also, what foot lamberts are you G70 owners getting these days?
Thanks!
Clarence
| Posted: Thu Jun 26, 2008 2:51 pm Post subject: |
Depends mainly on the size of the screen. If the tube output is set up properly, you'll probably get about 7-8 FtL on a 7-8' wide screen, 5 FtL on a 9' wide screen.
Bitwize
| Posted: Thu Jun 26, 2008 4:29 pm Post subject: |
to what screen gain would that apply? i'm using a 1.4 gain screen, but i'm thinking it's actually closer to 1.1-1.2.
Clarence
| Posted: Thu Jun 26, 2008 4:48 pm Post subject: |
The 7-8 ftL range already accounts for a typical 1.0-1.3 gain screen.
Phil Smith
| Posted: Thu Jun 26, 2008 5:53 pm Post subject: |
I've never understood the fascination with projector output. I mean, it's not something that's adjustable. You set your PJ up properly, and it's either bright enough for you, or it's not.
I never once thought about measuring my G70's output. I never could see the point.
Bitwize
| Posted: Thu Jun 26, 2008 5:58 pm Post subject: |
Clarence, thanks for answering my questions!
Somewhere on this forum I read that 12-14 foot lamberts was what CRT owners crave. Does that mean 12-14 is very uncommon for a CRT and is only what they wish for? Do most people only get 5-8? Is a higher gain screen a good option for a G70VR or should I stick with 1.1-1.4?
I'm currently getting 12-13 foot lamberts with my G70VR on an 80" diagonal, 1:78 screen that has a 1.4 gain (supposedly).
Bitwize
| Posted: Thu Jun 26, 2008 6:02 pm Post subject: |
| Phil Smith wrote: | I've never understood the fascination with projector output. I mean, it's not something that's adjustable. You set your PJ up properly, and it's either bright enough for you, or it's not.
I never once thought about measuring my G70's output. I never could see the point. |
very well said, phil. i'm just curious really. i have my G70VR calibrated close to 12, but i recently brought brightness down 11 clicks in order to achieve absolute black. i then upped the contrast a couple clicks, which seems to increase light output approximately 0.5 fl per click.
Bitwize
| Posted: Thu Jun 26, 2008 6:05 pm Post subject: |
| Nashou66 wrote: | When I run my single marquee i get around 7 but with the tack its closer to 11 and that is a big difference when you see it. Hard to go back to a single PJ after stacking.
Athanasios |
anthanasios, i imagine that's a very noticeable difference! i don't think i'd be content with 7 when i'm getting around 12 now. 10-11 might be bearable.
Phil Smith
| Posted: Thu Jun 26, 2008 6:09 pm Post subject: |
| Bitwize wrote: | | Phil Smith wrote: | I've never understood the fascination with projector output. I mean, it's not something that's adjustable. You set your PJ up properly, and it's either bright enough for you, or it's not.
very well said, phil. i'm just curious really. i have my G70VR calibrated close to 12, but i recently brought brightness down 11 clicks in order to achieve absolute black. i then upped the contrast a couple clicks, which seems to increase light output approximately 0.5 fl per click. |
Bitwize, I'd be careful with the contrast. It has a major impact on tube life. Of course signal levels effect where it should be set, but for all of my HD sources, I ran my G70 at 65. It has over 12K hours of use on it, and still throws a great picture.
Bitwize
| Posted: Thu Jun 26, 2008 6:56 pm Post subject: |
| Phil Smith wrote: | | Bitwize wrote: | | Phil Smith wrote: | I've never understood the fascination with projector output. I mean, it's not something that's adjustable. You set your PJ up properly, and it's either bright enough for you, or it's not.
Bitwize, I'd be careful with the contrast. It has a major impact on tube life. Of course signal levels effect where it should be set, but for all of my HD sources, I ran my G70 at 65. It has over 12K hours of use on it, and still throws a great picture. |
phil, do you have ABG turned ON? i know my brightness setting changed a lot by turning it OFF vs. ON. also affected the contrast setting. i think i remember ecrabb saying his G70 was putting out around 12 ft/l. seems that is the sweet spot for a completely light controlled room. of course, there are always those that will go lower for the sake of tube life. tonight i'll do a quick recheck on the contrast with my DVE HD-DVD.
| Posted: Thu Jun 26, 2008 10:08 pm Post subject: |
| Bitwize wrote: | | i think i remember ecrabb saying his G70 was putting out around 12 ft/l. seems that is the sweet spot for a completely light controlled room. of course, there are always those that will go lower for the sake of tube life. tonight i'll do a quick recheck on the contrast with my DVE HD-DVD. |
Yep. I was just playing around with it last Friday night, in fact. On my machine, on my Wilsonart 96x54, I'm just a hair under 12fL. With my setup at least, it seemed like a click one way or the other resulted in between 1/3 and 1/2 ftL delta. More than I would have guessed it would be. That's 1 fL per three clicks of the contrast control!
Obviously, gain and screen size have a huge impact on reflected light output; that's why there's so much variation around here. Tube condition also has a large impact. These are all variables that you have to consider when we're comparing one setup to another. 12-14 is a fine target for CRTers in our perfectly light-controlled caves. SMPTE says 12fL minimum for a white field. Still, I think it's pretty well agreed-on - especially over at AVS - that some people love an image that's brighter than that - maybe a lot brighter. 15 or even 20 fL isn't uncommon in that crowd. I know when I stacked my two 12xx's (just for fun), the difference in how white the whites were, and how punchy and colorful the image was... it was truly amazing. I wish I could have measured the output, but I'd guess it was in the 16-18fL ballpark. Pretty amazing. I can see how people get hooked on "bright".
Then, there's the size of the white window you use the measure your light output. The larger the size of the window, the less bright the overall image will be.
Finally, there's the screen itself. Wilsonart tested at 1.24 gain. That means, if my measurements and equipment are accurate, that my G70 is putting out just under 350 lumens using the 100% white window screen from the DVE HD Basics Blu-ray - which is about right, I think. Now, if I put those 350 lumens on the same size screen, but drop down to 1.0 gain, I'll drop down below 10 fL - at the same contrast setting!!!
On the other hand, if I had gone with my Wilsonart, but on what some people would consider a more sensible screen size - say 85x48 - I'd be up over 15 ftL. Or, if phosphor life was more important than brightness, I could use 12fl for my target, but I could lower contrast from 70 to probably below 60!!!
So, you've got screen size, screen gain, tube condition, the size of the white window you're using as your source, and your priorities (tube life or brightness) - they're all in play.
Phil Smith
| Posted: Thu Jun 26, 2008 10:43 pm Post subject: |
| Bitwize wrote: | | Phil Smith wrote: | | Bitwize wrote: | | Phil Smith wrote: | I've never understood the fascination with projector output. I mean, it's not something that's adjustable. You set your PJ up properly, and it's either bright enough for you, or it's not.
phil, do you have ABG turned ON? i know my brightness setting changed a lot by turning it OFF vs. ON. also affected the contrast setting. i think i remember ecrabb saying his G70 was putting out around 12 ft/l. seems that is the sweet spot for a completely light controlled room. of course, there are always those that will go lower for the sake of tube life. tonight i'll do a quick recheck on the contrast with my DVE HD-DVD. |
Bitwize, I have my ABG on. I didn't have the ABG line problem many of you have, and don't have adjustable G2.
Regardless of tube wear, I couldn't turn the contrast much higher than 70 without noticing a little blooming. Not much, but enough to effect sharpness.
AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Fri Jun 27, 2008 2:07 am Post subject: |
| Phil Smith wrote: |
Regardless of tube wear, I couldn't turn the contrast much higher than 70 without noticing a little blooming. Not much, but enough to effect sharpness. |
ABG on here also. I don't notice it because it projects off my 16:9 screen on a flat black wall.
Contrast is at ~60, any higher and may gamma drops below 2.0 and the contrast ratio falls also.
I have 100% light controlled room so I don't mind the lower fL.
kal Forum Administrator
| Posted: Fri Jun 27, 2008 3:14 am Post subject: |
Nobody's mentioned the most important factor here: With CRT displays the ftL output depends on the white window size. So while my projector does a good 12-13 ftL when displaying a 100 IRE white widow that only uses 10% of the screen, it drops to only 3 or 4 ftL (I'm guessing) when it's an entire screen of white.
So saying you get "X" foot lambers with a CRT projector is absolutely meaningless unless you also mention what sort of test pattern you were viewing. Someone could say they're getting 15 ftL while someone else says they're getting 4 ftL and they both have the same identical CRT projector set up the same way with the same screen. All that's different is the pattern they're using to measure ftL.
See the "Greyscale & colour Calibration" guide in my signature for more information on this and what you should be targeting for good/reasonable image quality, and how CRT differs from the other display devices.
| Posted: Fri Jun 27, 2008 3:29 am Post subject: |
Kal, give me some credit, here! I said, "my G70 is putting out just under 350 lumens in the 100% white window"... You were supposed to read my mind and KNOW I was talking about DVE HD Basics. Seriously, I meant to put that in my post, but forgot it. I'll edit that.
You're exactly right, though... Talking about light output without specifying pattern and screen size is like quoting amplifier output power, but not mentioning whether you were talking about a 1khz sine wive, pink noise, etc. and whether it was into a 4-ohm load or an 8-ohm load.
Whenever we talk about reflected light, we should give the full details. Just like an amplifier spec says "300w @ 4-ohms, .05% THD, 1khz sine wave, both channels driven", we should say something like, "My G70 is reflecting 12fL from my 1.24 gain 96"x54" Wilsonart DW laminate screen, using the DVE HD Basics 100% window."
EDIT - I edited my post to add your point, Kal. Thanks! I always forget something!
Gino
| Posted: Fri Jun 27, 2008 4:17 am Post subject: |
Athanasios |
At what screensize are you running your stack these days?
Also, what test pattern did you use? windowed/full etc..
Also, why only 7 to 11? If both projectors were similar, wouldn't a stack basically double your light output?
Bitwize
| Posted: Fri Jun 27, 2008 1:57 pm Post subject: |
Thanks everyone for the helpful posts!
I now have my G70VR reflecting around 12 ft/l on an 80" 1.2 gain screen using the DVE 100% IRE window pattern.
I also readjusted brightness so I am now getting much better shadow detail at the expense of blacks that are not longer absolute. But it's a nice compromise.
Resolution still looks very good as well.
| Posted: Fri Jun 27, 2008 3:08 pm Post subject: |
| Bitwize wrote: | | I also readjusted brightness so I am now getting much better shadow detail at the expense of blacks that are not longer absolute. But it's a nice compromise. |
Rob, that's where gamma boost comes in. You can have your cake and eat it, too. I want to get into something with gamma boost BAD. I love those completely black scenes in my theater where you can't see your hand in front of your face - that blows people's MINDS! I think I've pretty much decided to get the Moome IFB card - whenever it comes out. Sounds like that will finally be the sweet spot maturity in these devices and will include all the things we need - not leaving something out that will give me upgrade-itis 6 months later. I HATE that!
Oh, and where are those pictures!!! (I'm a slacker, too) I played with my projector last weekend instead of taking pics, and now I've sold my DSLR.
tony359
| Posted: Sun Jun 29, 2008 12:38 am Post subject: |
CRT are not digital projectors and to correctly measure the FL on the screen (as told: both in full and windows size) I think that a cinema spotmeter is needed. This device can average the FL measurement since in cinema the image are flashing 48 times a second, with black between them. I think that with CRT a similar device is needed.
SMPTE says 16FL for cinema, with 12/22 (if I'm not wrong on 22) allowed. In my personal opinion (I work in cinemas) 16 is the minimum, 18 is better
Ciao
Antonio
