Tube Munching Machine
Goto page 1, 2, 3  Next
Posted: Fri Jun 06, 2008 8:29 am    Post subject: Tube Munching Machine
Is there any mod that can be done to stop Barco 1100 munching tubes???
r.bauer
Posted: Fri Jun 06, 2008 5:00 pm    Post subject:
No.
Well, if you succeed, you would be the first.
jkruger
Posted: Fri Jun 06, 2008 5:18 pm    Post subject:
Are they notorious for eating tubes? Are any of the other Barco models the same way?
Posted: Fri Jun 06, 2008 5:21 pm    Post subject: Re: Tube Munching Machine
Ask the tech heads here. I doubt there's going to be much interest because of the age but hey we're all a bunch of nuts so you never know.
Posted: Fri Jun 06, 2008 10:33 pm    Post subject:
Hopefully its not about having the best projector but about CRTs. Yes they are known for eating tubes but surely some tech head knows why!!
Posted: Fri Jun 06, 2008 11:43 pm    Post subject:
OH I know why. Curt and I talked about this a couple of years back. On the 1100 series the HV comes on instantaniously instead of powering the projector and then a few seconds later turning on the high voltage. It's comparable to someone pulling you out of bed and slapping you into your work day in .5 of a second. Too much of a shock too many times 'till you crack.
If someone could engineer a HV delay circuit I'm betting, from my understanding, the tubes would last much longer.
Posted: Sat Jun 07, 2008 12:02 am    Post subject:
That makes plenty of sense. Has anyone tried or am I a pioneer. Also Analog Rocks how is your Ampro 4000g does it throw a good image? Does it chew tubes?
Posted: Sat Jun 07, 2008 12:07 am    Post subject:
The tubes in my Ampro are minty white. I can never keep a HVPS in their long enuff to put any wear on them. Laughing
No the Ampro 4000 doesn't power up like that. It brings up the fans, then the CPU, does an onboard diagnostic then brings up the HV about 10 seconds later.
It throws an amazing image. I had 1080i dialed in from the HDFury, through the Extron running Chronicles of Riddic. It looked great! Then 2 hours latter the HV PS blew again. Laughing
Posted: Sat Jun 07, 2008 12:12 am    Post subject:
So the 4000g have a weak PSU. Are they a good PJ to own?
jkruger
Posted: Sat Jun 07, 2008 12:13 am    Post subject:
What's the difference between that and leaving my 1209s in standby until firing it up? Doesn't it still get hit with HV from a cold start when I turn it on? Are the tubes hot in standby? It doesn't use much power in that mode.
Posted: Sat Jun 07, 2008 12:18 am    Post subject:
I don't know if standby keeps the tubes heaters going or not. If yes then standby could be OK.
Posted: Sat Jun 07, 2008 1:32 am    Post subject:
Keith, what analog said about the HV is true. Without massive reworking, you're more or less stuck with the chance of imploding tubes. Nothing you can do about it. Have you gotten a hold of the guy parting out the Ampros here? He's got 5 of them in Australia that should have good tubes. That can keep you in tubes for a long time..Smile
That set is either on or off, standby does not keep the heaters going, so that won't change anything.
Posted: Sat Jun 07, 2008 1:43 am    Post subject:
Keith, what Analog said about the HV is true. Without massive reworking, you're more or less stuck with the chance of imploding tubes. Nothing you can do about it. Have you gotten a hold of the guy parting out the Ampros here? He's got 5 of them in Australia that should have good tubes. That can keep you in tubes for a long time..Smile
How about getting Marc, Mac or Scott to look at it? Maybe they know of a way to delay the HV start. Say a timed relay? Would that be easier on the tubes or would you still need a standby circuit?
Posted: Sat Jun 07, 2008 7:54 am    Post subject:
"Tube munching machine"
That's what I used to call my wife BEFORE we got married. After we got married, the problem seemed to rectify it's self Rolling Eyes
r.bauer
Posted: Sat Jun 07, 2008 11:19 am    Post subject:
I don't know if the sudden rise in EHT when starting the projector is the cause of the SD146A dying prematurely.
The later model EHT board has indeed a slower rise of the EHT on startup. It starts very gently, you can actually hear the difference. http://www.curtpalme.com/docs/BarcoServiceBulletin_R762716_New_EHT.pdf
You can probably mod the earlier model EHT for a slower rise in EHT.
Joust
TV/Projector: Marquee 8501LC
Posted: Sat Jun 07, 2008 1:24 pm    Post subject:
we need to feed it some coffee before its put into service.
nettwerkjohn
Posted: Mon Jun 09, 2008 5:16 am    Post subject:
why not just leave it on, projecting a blank image?
Posted: Mon Jun 09, 2008 5:32 am    Post subject:
That would be trading Cathode use for a lesser chance of tube failure. It's a bit of a compromise. Is the 1100 a noisey projector?
Posted: Mon Jun 09, 2008 5:56 am    Post subject:
Because CRTs draw 600-900 watts. That's why.
Posted: Mon Jun 09, 2008 5:57 am    Post subject:
I knew that was comming ^
Page 1 of 3
