97ss150
| Posted: Mon May 26, 2008 8:34 pm Post subject: wilsonart?!?! |
ok so i have decided that this might be the best route for me. i am curious as to the part numbers that i need to give the guys at wilsonart, in order to get exactly what i want. as was said on here there is a local supplier (to me) so i will go there and pick the material up as long as they allow such a thing. i want 8x10 material size.
ty in advance
Clarence
| Posted: Mon May 26, 2008 9:45 pm Post subject: |
5' width is the max size, 12' long.
Part number: Designer White D354-60
| Posted: Mon May 26, 2008 11:05 pm Post subject: Re: wilsonart?!?! |
| 97ss150 wrote: | ok so i have decided that this might be the best route for me. i am curious as to the part numbers that i need to give the guys at wilsonart, in order to get exactly what i want. as was said on here there is a local supplier (to me) so i will go there and pick the material up as long as they allow such a thing. i want 8x10 material size.
ty in advance |
Let us know where you are and how much they quote you will you? I've tried to buy it here but's its gone stupid expensive.
Also when ordering ask for the thicker laminate.
97ss150
| Posted: Tue May 27, 2008 12:23 am Post subject: |
will do also i think illl get a 5' and a 2.5'
henry
| Posted: Tue May 27, 2008 6:42 am Post subject: |
Yeah, you want the D354, which is "Designer White", and you want it in the "60" matte finish, hence the D354-60 that Clarence posted. You want the "standard grade" which is the thickest grade... as AR mentioned. There's also a "vertical" grade which is much thinner.
I think the standard grade material comes from the factory in sheets of 3, 4, or 5 feet wide, and in lengths of 8', 10', 12' - or 9 different sizes. Several suppliers I called had only 4x8, 5x8 or 5x12 though.
I just googled and this place sells some of the smaller sizes - prices seem good, too:
http://www.tapeease.com/wilsnrt_plastic_laminate.htm
jkruger
| Posted: Tue May 27, 2008 2:14 pm Post subject: |
Does Home Depot stock this stuff or is it special order only? I need a 5' x 8'
drice1234
Joined: 07 Oct 2006 Posts: 1309 Location: Allen, Texas
| Posted: Tue May 27, 2008 2:21 pm Post subject: |
I don't think Home Depot has it in stock but they can special order it in.
| Posted: Tue May 27, 2008 2:32 pm Post subject: |
I was going to get it from Lowe's or Home Depot, but both had to order because they didn't stock. They said it would be 10-14 days. So, I did some checking and found a local wholesaler who had a 5x8 in stock. It was about $10 higher (I think it was $105 vs the $95 or so Lowe's price), but I got instant gratification. Three cheers for instant gratification!!!
Person99
| Posted: Tue May 27, 2008 3:22 pm Post subject: |
| ecrabb wrote: | I was going to get it from Lowe's or Home Depot, but both had to order because they didn't stock. They said it would be 10-14 days. So, I did some checking and found a local wholesaler who had a 5x8 in stock. It was about $10 higher (I think it was $105 vs the $95 or so Lowe's price), but I got instant gratification. Three cheers for instant gratification!!!
SC |
In Dallas, you can buy it at home depot for the cheaper price, then go to the local distributor to pick it up. The best of both worlds!
_________________ Dave
wallace123456
Joined: 14 Aug 2006 Posts: 2236 Location: Northwest VA area
| Posted: Tue May 27, 2008 4:36 pm Post subject: |
Hey guys. When you are looking for Wilsonart stuff, go to their website http://www.wilsonart.com/ click on the Homeowners link under Laminate and then click on "find a dealer". Try some of those local dealers and see what the prices are.
The Wilsonart I purchased was about 1/4 or 1/3 the price of Home Depot or Lowes. And, it was ready for me to pick up in 2 days.
Just a note from my experiences buying the stuff....................
wallace
_________________ Life Is Good, But BBQ Is Better! BBQ Competition Team
| Posted: Tue May 27, 2008 4:55 pm Post subject: |
SC |
Wow that's only about $2.62 sq ft. I got quoted, directly from Wilsonart, $3.08 sq ft
Person99
| Posted: Tue May 27, 2008 5:13 pm Post subject: |
| wallace123456 wrote: |
The Wilsonart I purchased was about 1/4 or 1/3 the price of Home Depot or Lowes. And, it was ready for me to pick up in 2 days. |
How much did you get it for?!?!? In Dallas, the home depot is only $80+tax for a 5'x10' piece of the thick stuff. That would mean you paid $20-$27 for it?!?!?!?!?!?
wallace123456
| Posted: Tue May 27, 2008 8:06 pm Post subject: |
| Person99 wrote: | | wallace123456 wrote: |
How much did you get it for?!?!? In Dallas, the home depot is only $80+tax for a 5'x10' piece of the thick stuff. That would mean you paid $20-$27 for it?!?!?!?!?!? |
For a 4x8 sheet (D354 60 335) which is the thinner type (I didn't need the thick type), $24.98 + $1.25 tax = $26.21. I had to drive about 40 miles to pick it up.
wallace
Person99
| Posted: Tue May 27, 2008 8:18 pm Post subject: |
| wallace123456 wrote: | | (I didn't need the thick type) |
The prevailing wisdom seems to be that you should use the thick stuff but I've not tested the thick vs. the thin so I'm curious as to how to determine when you don't need the thick stuff. Was it just the size, or the way you were mouting it that led to this decision?
| wallace123456 wrote: | $24.98 + $1.25 tax = $26.21. I had to drive about 40 miles to pick it up.
Gas is $4/gallon so don't forget to add the $12 in gas to make the trip. But, I think that is only a little bit cheaper than HD if any cheaper. Just curious, would HD not sell you the thin stuff and that's why it was cheaper?
| Posted: Tue May 27, 2008 8:25 pm Post subject: |
I think if you have a nice, smooth solid substrate, the vertical grade material (the thinner stuff) would work just fine. For instance, with my MDF-based screen I built, I probably should have gone with the thinner/cheaper stuff.
If you're not literally laminating it to another substrate, but are instead hanging or attaching it to the wall somehow (tape, nails, screws), then I think you'd want the thicker material to avoid waves or ripples.
I had no idea the vertical grade material was THAT much cheaper. I figured it was like $75 vs $100, not $25 vs. $100! Oh, well - water under the bridge.
wallace123456
| Posted: Tue May 27, 2008 9:18 pm Post subject: |
| Person99 wrote: | | The prevailing wisdom seems to be that you should use the thick stuff but I've not tested the thick vs. the thin so I'm curious as to how to determine when you don't need the thick stuff. Was it just the size, or the way you were mouting it that led to this decision? |
I glued it on Melamie (sp?).
| Person99 wrote: | Gas is $4/gallon so don't forget to add the $12 in gas to make the trip. But, I think that is only a little bit cheaper than HD if any cheaper. Just curious, would HD not sell you the thin stuff and that's why it was cheaper? |
Well, gas was only $3.25 6 months ago.
Home Depot only offered the thick stuff. And, they are a real pain to deal with here when "special" ordering things.
The folks I purchased my stuff from was very helpful, friendly and prompt. Can't ask for much more.
wallace
wallace123456
| Posted: Tue May 27, 2008 9:22 pm Post subject: |
| ecrabb wrote: | I had no idea the vertical grade material was THAT much cheaper. I figured it was like $75 vs $100, not $25 vs. $100! Oh, well - water under the bridge.
SC |
IIRC, the thick stuff was only like $10.00 more. The thin stuff was much easier to work with. I used the thick stuff the first time I used Wilsonart (I too embarresed to say what happened to with that fiasco.) and figured I'd try the thin stuff since I glued it to a thick backing (Melamie) like you did.
wallace
| Posted: Tue May 27, 2008 9:35 pm Post subject: |
Wait, so you're saying that a 4x8 sheet of the vertical grade stuff was only $25, and a 4x8 sheet of the standard grade stuff was only $35? $35 would be between 1/3 and 1/2 of the lowest prices I've ever seen. I don't think anybody has ever reported paying anywhere near $1/sqft. It makes me wonder if the supplier screwed up and charged you below their cost or something.
wallace123456
| Posted: Tue May 27, 2008 10:04 pm Post subject: |
| ecrabb wrote: | Wait, so you're saying that a 4x8 sheet of the vertical grade stuff was only $25, and a 4x8 sheet of the standard grade stuff was only $35? $35 would be between 1/3 and 1/2 of the lowest prices I've ever seen. I don't think anybody has ever reported paying anywhere near $1/sqft. It makes me wonder if the supplier screwed up and charged you below their cost or something.
SC |
YES.
Just for the heck of it, call the place where I purchased mine and ask them for prices on different sizes. The name of the company is Reico. Phone number: (703) 256-6400 or (800) 336-4526. The person I dealt with was Tammy Milne. Her direct number is (703) 245-8915.
Let me know what you find.
Now that I think about it, what has other people come up with as far as prices go? Has anyone tried the "dealer locator" on the Wilsonart site and called to some of those places close by your home?
That's how I found the company I purchased my stuff from.
wallace
dropzone7
Joined: 12 Jun 2007 Posts: 1069 Location: Charlotte, NC
| Posted: Wed May 28, 2008 2:07 am Post subject: |
I paid $90 for a 5x10 piece from Lowe's by special order. I'm not sure what grade it is though. It was thin enough to be rolled up to the diameter of a large trashcan or 55 gallon drum but rigid enough that I could lay it against the wall and it would support it's own weight.
