Got it up! (barco ceiling mount options)
Posted: Sat Apr 26, 2008 2:01 pm    Post subject:
jkruger wrote:
It took a block and tackle to get it up so I had one of the girls do the pulling and hold it up while I attached the four steel struts that will keep it up for many years to come.
Wow - years... Very impressive. Laughing
jkruger wrote:
I'll post pics later today.
Shocked
Very Happy
Posted: Sat Apr 26, 2008 2:08 pm    Post subject:
You know, if it stays up for more than four hours, you should consult a doctor.
Heywood Jablome
Posted: Sat Apr 26, 2008 2:45 pm    Post subject:
Or seek multiple partners!
"Honeeeey? What say you call your sister?"
Posted: Sat Apr 26, 2008 3:27 pm    Post subject:
LOL ! Thumbs Up
jkruger
Posted: Sat Apr 26, 2008 5:27 pm    Post subject:
The harem doesn't have a problem with multiples.... they live for it...
jask
Posted: Sun Apr 27, 2008 4:40 am    Post subject:
jkruger wrote:
It took a block and tackle to get it up so I had one of the girls do the pulling and hold it up while I attached the four steel struts that will keep it up for many years to come. I made a couple of rails that attached to the bottom of the pj and some clevises to attach the threaded rods to the rails. I'll post pics later today.
With all that extra weight and metal holding up your gear,you will want those clevis' attached to some stout nuts....don't want all that gear to come crashing down.
I only have an 8" Rolling Eyes but the wife says it is great,she likes that I can get it mounted up so high.I was thinking all that extra paraphernalia was a bit over the top-but to be honest I think the extra support and added security of all the extra bracing would keep me from worrying during long and/or multiple performances. Lets face it this gear is getting old and failure is possible.
Posted: Sun Apr 27, 2008 1:04 pm    Post subject:
Please post a picture of the beastie hanging, set up for zero projection angle. This I gotta see Wink
jkruger
Posted: Tue Apr 29, 2008 1:43 pm    Post subject:
Okay, finally got some pics to put up. The first one almost shows the angle it is hanging at for near zero projection angle. I think it is about 1 or 2 degrees.
 Filesize:  27.32 KB
 Viewed:  6920 Time(s)
taken from the floor looking up
 Filesize:  25.27 KB
 Viewed:  6932 Time(s)
 Filesize:  25.81 KB
 Viewed:  6933 Time(s)
 Filesize:  25.91 KB
Posted: Tue Apr 29, 2008 2:01 pm    Post subject:
I must say, that gorgeous 9-incher makes me jealous. And it doesn't look like it's seen any use at all!
Posted: Tue Apr 29, 2008 2:17 pm    Post subject:
The only thing better would be virgin phosphor's
jkruger
Posted: Tue Apr 29, 2008 2:26 pm    Post subject:
It's no virgin.... 4200 hrs, the green is about a 7.5, the others are 9.5 or 10, but for the price I'm a happy camper. Need a bigger screen now.
Posted: Tue Apr 29, 2008 4:37 pm    Post subject:
Wow, that thing definitely looks spiffy. Some of these machines look like they went somewhere dragged behind a truck instead of ON the truck. The black Runcos were especially sensitive because the scratch in the black paint revealed the lovely beige plastic. Your machine looks really nice and clean.
So, where is that machine hanging? A dormer? I'm wondering... Since there's no insulation on the bottom of the sheathing, doesn't it get REALLY hot up there in the CA sun? Even in winter?
jkruger
Posted: Tue Apr 29, 2008 4:51 pm    Post subject:
It's in the loft above the 2 car garage, it's getting insulated and finished in a month. Installing vents and a fan to suck the heat out also. The room is 26 x 24, minus the stairwell and the low roofline areas. Makes it about 16 x 24 usable area but the screen is limited to about 84 wide. Yes it does get hot up there, sunday and yesterday it hit a hundred during the day which is very unusual for where I live. I'm about six blocks from the ocean and there is almost always a nice cool breeze.
jkruger
Posted: Tue Apr 29, 2008 5:34 pm    Post subject:
I'm definitely going to have to move it farther away from the screen, the focus adjustments are as close as they will go right now.
Person99
Posted: Tue Apr 29, 2008 6:01 pm    Post subject:
I'm confused. Which focus adjustments (electronic or optical)? There is only 1 correct place to mount the PJ which is determined entirely by the lenses on them. Did you not mount it in the right location?
jkruger
Posted: Tue Apr 29, 2008 6:14 pm    Post subject:
I put it in almost the same spot as the 1272, which is too close. I'm going to move it back about 2 ft so it will be about 120" from the screen. (when I get a bigger screen)
Person99
Posted: Tue Apr 29, 2008 6:54 pm    Post subject:
Just curious, how did you figure out where it needs to be mounted and where it will need to be mounted with the bigger screen?
jkruger
Posted: Tue Apr 29, 2008 7:08 pm    Post subject:
I didn't really... I put it on a cart and positioned it so the internal pattern looked like it was about the size of the screen I intend to get and then tried to get it into focus withthe lens adjustments. It was too close so I just hung it where the old one was. I'll move it to the correct spot later, the mount can move front to back very easily. Too busy to work on it much right now.
