mcastleberg
| Posted: Sun Apr 20, 2008 7:21 am Post subject: Marquee 8500 - red flickering/screen going black |
Ok, the last few days I've been having a weird problem with my Marquee 8500. I've noticed that when I turn it on, it takes bit longer for the screen to initialize and takes a second or two longer coming into focus. Then when it finally does, I can see a horizontal red flickering all up and down the screen that lasts for 10-15 seconds at least. Then lets say for instance that I'll go into Halo 3 on my Xbox 360 and while the game is loading a new menu or something, my screen with randomly go black and then after a few seconds come back on and take a few seconds to slowly focus and I'll see the red issue again. Seems like its gets worse every day too, sometimes it will happen several times in a row during gameplay. I'm running my 360 through a Crescendo to my Marquee. This hasn't happened before and I'm worried that she's dying on me. Any clues? Thanks
| Posted: Sun Apr 20, 2008 5:34 pm Post subject: |
This seems like a recent problem with the Marquee, It could be one of a few problems, like one of the boards not being seated properly, or the cips in the CLM needing to be pushed it to make better contact or what I think it may be as this has been solved by a few people recently, there is a trim pot on the VNB ( Video neck board) that controls the cut off to the crt, it get corosuon on it with age and in more humid enviroments, its recomended to carefully remove the silicon covering it and then turning the trip pot a few time back and forth to free up any oxidation. keep it in the same position so you dont change any factory settings.
you can cover it with silicon again if you want.
But first try to reseat each board it might be that, especially if its mounted to your ceiling.
mcastleberg
| Posted: Sun Apr 20, 2008 5:53 pm Post subject: |
The first thing I did was take the focus boards out and clean them with some contact cleaner from Radio Shack but it didn't help. The other stuff you suggested, I would need some sort of guide to do those.
| Posted: Sun Apr 20, 2008 6:28 pm Post subject: |
Ok First in between the green and blue tube is the HDM(Horizontal Deflection Module) Remove it remebering how the connected wires are orientated as they will change the orientation on the screen of the image if switched around. Remove the board clean the contacts as you did with the focus board especially the connector to the mother board. Also there is a smaller daughter board on it remove and clean those as well. replace and test.
Now the CLM Control logic Module) this is the board on the lower left of the back of the projector with the diagnostic lights. it pulls out and has no connecting wires. there are two board connected to this if you have the astigmator board, remove both boards and now press down on all the chips on the three boards that are in carriers(chip sockets) this will make sure they have a good contact. rplace the two boards and replace the CLM and test again.
Now for the neck board, since you said its red horizontal lines i would only do the red VNB. Remove the VNB from the tube neck. look at the marquee tear down document for pics on how to remove and reinstall. On the top left corner there will be a glob of silicon, remove it carefully and under it will be a trim pot. turn it back and forth a few times and put it back in the same posistion. put the board back in remembering to make sure the G2(white wire) goest to the top pin of the two on the tube pins that are exposed, the other pins are connected onto the VNB leaving only two exposed for the white pin to connect to. test again.
if all that doesnt help try two last things pulling the power supplies on the front and just rteseating them a few times incase they have some oxidation on their contacts.
Otherwise it could be a HVPS gone bad.
Athanasios Hatzinerantzis
mcastleberg
| Posted: Sun Apr 20, 2008 11:17 pm Post subject: |
After cleaning and replacing the CLM I am not getting any display whatsoever. What have I done????
mcastleberg
| Posted: Mon Apr 21, 2008 12:09 am Post subject: |
There are no error lights and I'm sure I put the 2 boards back on correctly... I don't know how else they could even fit. Before whenever I would turn the projector on, after a few seconds of warmup the tubes would give off this crackling sound which I presume is static discharge. They're not doing that anymore, whatever that means.
mcastleberg
| Posted: Mon Apr 21, 2008 1:08 am Post subject: |
I don't recall removing anything else, no. I did the focus board and the daughter board and tested...realized I put the connectors on wrong and my image was reversed (doh!) so I took it back out and corrected it and then moved on to the CLM. It hasn't worked since and I can't figure out what I did wrong.
mcastleberg
| Posted: Mon Apr 21, 2008 3:57 am Post subject: |
I have pulled out the HDM and rechecked the connectors a couple of times. Everything seems to be secured in the right place but who knows...
mcastleberg
| Posted: Mon Apr 21, 2008 2:47 pm Post subject: |
Just did some reading on AVS and it sounds like there may be something wrong with my LVPS. I cleaned out the contacts on both the LVPS and HVPS but it didn't help. I don't know how to tell if I've blown a fuse in the LVPS. I do remember hearing a strange click or pop come out of the projector the other day but it didn't die until last night.
mcastleberg
| Posted: Mon Apr 21, 2008 4:11 pm Post subject: |
Curt just suggested that it was my HVPS instead of the LVPS. He offered to test and repair the HVPS and HDM for me but it would cost me more than I have invested in the whole unit!! There has to be something else I can do here...
| Posted: Mon Apr 21, 2008 4:14 pm Post subject: |
You have toi open it up and look at the fuses, there is one you can see and i think one under the small metal box where the plug goes in, but if that one blew nothing would go an al all.
If you heard something pop it could be anything, caps make that sound when they blow resistors just make lots of smoke. did you smell anything lately during all this began.
| Posted: Mon Apr 21, 2008 4:29 pm Post subject: |
| mcastleberg wrote: | | Curt just suggested that it was my HVPS instead of the LVPS. He offered to test and repair the HVPS and HDM for me but it would cost me more than I have invested in the whole unit!! There has to be something else I can do here... |
the only thing you could do is if you have someone near you with a marquee that can test yours or you can test their,s. and the other boards. With these projectors its always good to buy a spare for this exact situation, even if it has spent tubes.
mcastleberg
| Posted: Mon Apr 21, 2008 6:29 pm Post subject: |
I didn't smell anything. Its starting to sound like I'm gonna have to sell this thing. There's no way I'm putting 600 in repairs.
mcastleberg
| Posted: Mon Apr 21, 2008 7:05 pm Post subject: |
I'm in Chattanooga, TN.
