How do you do greyscale?
tommo2
Posted: Fri Apr 18, 2008 5:24 pm    Post subject:
Hey, can I use my scaler test patterns?
I have a iScan HD and there is a test pattern generator which will display a grey window from 10IRE to 100IRE in 10 IRE steps.
The only problem I can see is that it is a quarter screen window, not 10% as you recommend.
Extract from the manual:
10-100 IRE
Gray Window
TP9 -
TP18
This sequence of patterns consists of a centered, quarter-screen gray window. The gray level varies from 10 IRE to 100 IRE
in 10 IRE steps.
Cheers for all this KAL. It is a very useful thread that i think everyone will benefit from.
pull up the handbrake and walk away
Barco Data 701s
iScan HD scaler with sdi mod
Oppo 981HD with sdi mod
Xbox 360
Playstation 2
Denon AVR 1507 7.1 AV receiver
Wharfedale Diamond 9.4 floorstanders (front)
Wharfedale EVO2 (center)
Pioneer 100W (sides)
Wharfedale Diamond 9.1 (rear)
Wharfedale SW150 active subwoofer
Photos on the way!
Posted: Fri Apr 18, 2008 5:29 pm    Post subject:
WTS wrote:
Correct me if I'm wrong here, but the grayscale will be the same for both SD or HD so it won't matter if you use a SD or HD disc as your source or set up HCFR to SD or HD.
Correct. Like I said previously, the only reason for setting the colour space in HCFR is so that you can see how for off from the SD or HD primaries your measured primaries are. I guess I didn't make this clear enough.
Posted: Fri Apr 18, 2008 5:30 pm    Post subject:
I wouldn't recommend it as you're not including your source player in the loop. I'll probably close.
In that case, definitely no. You have to use 10% window. It's the standard.
WTS
Posted: Fri Apr 18, 2008 10:29 pm    Post subject:
Hi Kal,
Show me were it says that the 10% window is the standard for doing the grayscale on CRTs. Not that I don't believe you.
Walter
Posted: Fri Apr 18, 2008 11:20 pm    Post subject:
TomHuffman also staes to use a 10% window over on the AVS calibration forum, you have to read down some but its in there.
http://www.avsforum.com/avs-vb/showthread.php?t=852536
And its also stated here:
http://geekwithfamily.com/2006/12/16/home-theater/howto-hcfr-free-video-projector-calibration-software/
This is actually i pretty good basic guide for grey scale using HCFR and the Syder2
Posted: Sat Apr 19, 2008 12:03 am    Post subject:
I'm not sure where I read the 10% window but I think most test discs use about a 10% window. With diigital projectors it doesn't matter that much as they put out a lot of light and it's always more or less the same amount no matter what the window size is.
CRT however will only put out about 1/2 the light at 100IRE for a full screen pattern as it will with a 10% window pattern. I tested it myself. I get just under 14 ftL with a 10% widow 100IRE pattern and only around 8 with a full screen 100IRE pattern which ! So if I calibrate using the full screen patterns I'm only calibrating for up to about 8 ft/L output I'm leaving the top 50 IRE uncalibrated! Example: If I watch a movie that has content with a bright white area for approx 10% of the screen and the rest of it is reasonably dark, I've never driven my tubes that bright during calibration so it'll be completely off.
The high end is usually where it suffers too - as blue drops off usually pretty drastically for CRTs.
WTS
Posted: Sat Apr 19, 2008 12:15 am    Post subject:
Hi Kal,
What test disc has the 10% windows? I know AVIA does but I heard long ago that it's greyscale is tinted somewhat. DVE uses 100% and HCFR uses 100% windows.
Walter
Posted: Sat Apr 19, 2008 1:18 am    Post subject:
DVE Blu Ray has 10% windows i was playing around with it this morning, the window covers 10% of the screen area. Like kal said I tried useing the 100% window and i get a very low foot lambert reading compared to the 10% window.
Wait? 10% window does mean 10 percent of the screen right not 10% of the IRE output? Is what you meant Walt?
WTS
Posted: Sat Apr 19, 2008 1:22 am    Post subject:
Okay I don't have the new BR DVE disc.
Yes I meant 10% window.
Yes of course you'll get a brighter picture when you're only using 10% windows.
Walter
Posted: Sat Apr 19, 2008 1:52 am    Post subject:
The AVS HD Rec 709 disc also has 10% windows (10% of the window is varying shades from 0 to 100 IRE)
WTS
Posted: Sat Apr 19, 2008 2:07 am    Post subject:
I guess the AVS BR version should have the same then.
Walter
Posted: Sat Apr 19, 2008 2:33 am    Post subject:
I've updated my procedure again. This time explaining how to take initial measurements with a sensor so that you have some sort of baseline to compare against.
Mort importantly, I walk through all of the graphs and explain what they mean, how they work, etc. Using my projector set to the 6500K default. You'll see (and I'll explain how) even the 6500K default is far from accurate.
See the 3d post in this thread. Link: http://www.curtpalme.com/forum/viewtopic.php?p=113347#113347
Posted: Sat Apr 19, 2008 3:28 am    Post subject:
Yes. "Rec 709" is HD colour space. HD DVD and Blu-ray both us it so it's the same result.
Posted: Sat Apr 19, 2008 1:07 pm    Post subject:
Kal, When I first press the Green arrow key to start taking continuous readings it asks to calibrate the sensor. If i press no it wont start reading, untill i claibrate it , this is where i have a question. How do i calibrate it? It says place the Eye one sensor on a planar surface, what does that entail actually? And is this only for the Eye One sensor? I assume it should be calibrated to a white source but how do i determine if that white source is actual the correct white?
WTS
Posted: Sat Apr 19, 2008 3:43 pm    Post subject:
Kal,
Can you post your HCFR *.chc file for your Cine8, I'd like to compare it to mine which I just did last night. Yes I used the ire windows this time, although I never had time to do one using the full window ire.
Walter
Posted: Sat Apr 19, 2008 4:31 pm    Post subject:
Well that's odd. I have no idea what that means and I don't have an Eye-One to check this out. Are you sure you clicked "File->new" and then picked "DVD Manual" and "Eye One" ?
If yes, I'll likely have to drop mention of the Eye-One from this procedure as I don't know what how to do this calibration. You may want to read up in the AVS Calbration forum and see what they say. If it's an easy answer let me know and I'll put it in the procedure.
I don't like naming equipment that I've never used so I'll probably drop the Eye-One from the list anyway - or list it but put a bunch of caveats that it's *supposed* to be better but we have zero experience with it (which I already say but I'll emphasize it).
Walter: See my attached HCFR calibration file. I still want to tweak the upper end a bit and turn up the gamma a notch too, but other than that it's pretty good.
Color_Zenith1200_Apr10-2008_After_newcards_test8.zip
 Filename:  Color_Zenith1200_Apr10-2008_After_newcards_test8.zip
 Filesize:  1.37 KB
 Downloaded:  9 Time(s)
Posted: Sat Apr 19, 2008 5:53 pm    Post subject:
Ok I found some infor on the Display2LT probe from EYE ONE. I am waiting for some specific answers about the planar surface thing. But it does have to be calibrated : Apparently it needs to be put into a black box with not light comming in and an offset calibration needs to take place from the set up menu in HCFR for the probe.
ddrick from the AVS calibration thread:
There actually is a fair amount of information in the Master HCFR thread, but it is a little unwieldy (although it is possible to just search that thread.) Basically, you need to make sure that the Eye-One.dll driver is in the HCFR folder, and then connect the Eye-One to the computer. When HCFR starts up, select the Eye-One probe and then choose which type. You probably want to let the probe sit on the running TV for a little while (most recommendations are 20-30 minutes) to allow the temperature to normalize. After that, you'll do a dark level calibration (which can be found in the sensor setup menu, called calibrate internal offsets) by ensuring that all light to the sensor is blocked and then initiating the dark level calibration. After that is complete, start your measurements. I don't think I've missed any steps, but if all else fails, there really is a lot of information in the HCFR threads. Hope that helps!
thread link: http://www.avsforum.com/avs-vb/showthread.php?t=1012457&highlight=HCFR+Eye+One
And this, its for using on a plasma, apperantly the Display2LT changes performance with its temperature.
blutarsky:
You mean we should plug the sensor on the plasma screen and leave it for 30 minutes before starting the calibration process, then put the sensor in a black box (does it matter if it is not faceing a surface?), perform the sensor offset calibration and start calibrating? No sensor recalibration at that point?
Link to thread quote taken from:
http://www.avsforum.com/avs-vb/showthread.php?t=987720&highlight=HCFR+Eye+One
I'll investigate this further nad report back with specifics.
Ok What a planar surface is, i guess, a non porous Surface, you place the Eye One Display2LT on that surface and the rubber gasket around the bottom seals out any light to the sensors. this set the RGB values to zero for calibration.
http://www.avsforum.com/avs-vb/showthread.php?p=13681354#post13681354
WTS
Posted: Sat Apr 19, 2008 7:13 pm    Post subject:
Hi Kal,
Interesting how different your settings are. Are you pointing the probe at the projector or at the screen? I used the AVS BR test disc with the HCFR probe pointed at the screen, it was about 3/4" from the screen at an angle, I tried to attach at jpg pic of it but it is too big.
What cal file did you use, I used the NEC XG file, last time I used the NEC PG6 file, not if one is better than the other, although I will say the cal I just did does look very good.
I've attached my file, just change the ext from txt to chc.
cine8-april18-08.txt
 Filename:  cine8-april18-08.txt
 Filesize:  72.44 KB
 Downloaded:  7 Time(s)
Walter
tommo2
Posted: Sat Apr 19, 2008 7:29 pm    Post subject:
Hey KAL,
dont forget about including G2 setup before any grayscale calibration.
Barco Data 701s
Xbox 360
Playstation 2
Photos on the way!
WTS
Posted: Sat Apr 19, 2008 7:44 pm    Post subject:
One thing I don't understand looking at my results is when I was doing the continuos measurement and setting the bias / gains the 3 colours were pretty much on top of each other all the way from 10 to 100 ire. But when I did the capture part of it(clicking the GO on the measures screen) and I compare the results it shows them off more than what the continous showed. When I did the capture part I let the crt/probe stablize on the new ire window for at least 80secs before I clicked for it to sample/read it. Just seems odd that it would show so much difference in the readings.
Walter
Page 3 of 7
