armstrr
| Posted: Sun May 18, 2008 1:29 pm Post subject: |
so the DVI will accept 1080p24, but it won't output 1080p60 or 72 or 75 etc, correct?
_________________ Electeohome marquee 9500lc, lumagen hdp, 9' da lite high power screen denon 2809ci paradigm speakers home made dual stacked subs
Person99
| Posted: Mon May 19, 2008 12:25 pm Post subject: |
| armstrr wrote: | | so the DVI will accept 1080p24, but it won't output 1080p60 or 72 or 75 etc, correct? |
Correct. It will output 720p/72 (actually a little higher resolution than that also) and 1080i/72, but not 1080p/<anything>.
The HDP will do 96 Hz refresh rates within its bandwidth capabilities (such as 1080i/96).
_________________ Dave
| Posted: Mon May 19, 2008 12:30 pm Post subject: |
| Person99 wrote: | | armstrr wrote: | | so the DVI will accept 1080p24, but it won't output 1080p60 or 72 or 75 etc, correct? |
The HDP will do 96 Hz refresh rates within its bandwidth capabilities (such as 1080i/96). |
Dave Are you sure you cant output 1080p@48 like I do with the HDQ? The DVI should do that?
Person99
| Posted: Mon May 19, 2008 12:35 pm Post subject: |
| Nashou66 wrote: | Right I have a newer HDQ and run 800p@72 for scope movies but I think the older DVI will do the same.
Athanasios |
It depends upon the horizontal resolution. 1920x800/72 is getting REALLY close to the limit of the DVI, it might be over it, I'm not sure, I'll have to check.
As an aside, I'm just curious, obviously 1920x800 is the active image area for 2.40:1 releases, however, many scope movies on disc have ARs less than that, down to and below 2.35:1. Do you run 1920x817/72 for 2.35:1 movies or just scale those down to 1880x800 and side mask or scale to 1920x800 and side mask? Do you use the Lumagen or the projector to mask off the side areas (just curious as I like to know what people are there are doing ).
Person99
| Posted: Mon May 19, 2008 12:37 pm Post subject: |
| Nashou66 wrote: | | Person99 wrote: | | armstrr wrote: | | so the DVI will accept 1080p24, but it won't output 1080p60 or 72 or 75 etc, correct? |
Athanasios |
On the DVI's menu, it has the same behavior as the HDQ and HDP in that if you enter the output resolution as 1080, it asks you interlaced or progressive. If you select progressive, it comes back with something like "invalid value". I think I've tried doing it with lower refresh rates, but couldn't get it to do it. I think the software basically has code to stop the DVI from doing 1080p output.
energeezer
| Posted: Tue Jun 17, 2008 9:50 pm Post subject: |
Has anyone else been able to get the DVI to accept 1080p/24 input?
If so, were you able to scale to 1920 X 800/60 or 1920 X800/48 from that 1080p/24 input?
Steve
| Posted: Tue Jun 17, 2008 11:00 pm Post subject: |
| Person99 wrote: | | Nashou66 wrote: | Right I have a newer HDQ and run 800p@72 for scope movies but I think the older DVI will do the same.
Athanasios |
As an aside, I'm just curious, obviously 1920x800 is the active image area for 2.40:1 releases, however, many scope movies on disc have ARs less than that, down to and below 2.35:1. Do you run 1920x817/72 for 2.35:1 movies or just scale those down to 1880x800 and side mask or scale to 1920x800 and side mask? Do you use the Lumagen or the projector to mask off the side areas (just curious as I like to know what people are there are doing ). |
I do 1920x800p with no side masking. just straight 1920x800p@72 on my HDQ. pans a silky smooth. but doing 2.35 is a lot more dim than 16x9 screen material, this is why i cant wait to blend, full phosphor usage. I cant wait mid June is here and the TV-ones should be in soon!!!!!
energeezer
| Posted: Tue Jun 24, 2008 7:11 pm Post subject: |
Athanasios |
Did you try 1920X800/72? Did it work?
| Posted: Tue Jun 24, 2008 7:56 pm Post subject: |
| energeezer wrote: | | Person99 wrote: | | Nashou66 wrote: | Right I have a newer HDQ and run 800p@72 for scope movies but I think the older DVI will do the same.
Athanasios |
Did you try 1920X800/72? Did it work? |
Is this for Dave or me?
energeezer
| Posted: Tue Jun 24, 2008 11:38 pm Post subject: |
That was for Dave since I understand you have an HDQ.
