Newbie question... (want to buy a CRT projector)
J.man1503
Posted: Thu Apr 10, 2008 2:12 pm    Post subject:
I do not understand why the 9" models must be ran at 1080p. If 1080i has just as many lines of resolution as the 1080p, then why would they look different? Why would the scan lines on a 1080i image be more noticeable than scan lines on a 1080p image? Thanks.
Posted: Thu Apr 10, 2008 2:15 pm    Post subject:
I'm not entirely sure why but due to the interlacing/refresh rate, the scanlines are just more noticeable. (Even on my 8" machine). My machine does 1080p (and 1080i of course) but I choose to use 1080i as it's easier on the projector and easier to set up (doesn't push the machine/electronics as much). At 1080i I can see scanlines when I'm a few feet from the screen easily, but not at the seating position.
J.man1503
Posted: Thu Apr 10, 2008 2:27 pm    Post subject:
When I read the projector comparison and rankings I noticed that your projector (the Barco Cine 8 Onyx / Zenith Pro 1200x right) can input 1080p but not resolve it on screen because of too smeared.
"While the projectors marked with an asterisk are able to sync to a 1080p signal, the image will most likely be too soft or smeared to be usable" this was taken from the rankings page.
1. Is this correct?
2. Also, how would a Runco 991 be for 16:9 1920 by 1080? Would I have to run progressive or interlaced? Is this too subjective to each and individual projector?
3. I also notice on the projector high performance page that Curt Palme states that all the projectors have LC ("All employ liquid-coupled (LC) optics for better contrast ratio") , but still only some on the HIgh performance page indicate they are LC while others do not. Why would some idicate they do while others do not if all have LC?
Posted: Thu Apr 10, 2008 2:58 pm    Post subject:
1. Is this correct?
That's a good question. Many people use 1080p on my projector and if it's set up perfectly it will do 1080p just fine. There may be subtle overlap (especially in the horizontal direction) but it will not look "too soft or smeared to be usable".
Now that I think about it, I should probably change that text a bit - it sounds too pessimistic. I've gone and redone the list slightly (hit refresh in your browser). Smile I've had projectors like a Barco 800 with that asterisk as well a the very high end 8" machines like I have now. The 800 definitely looks soft and smeared at 1080p while the Zenith 1200 does not so I've created two categories.
A Runco 991 is simply a rebadged NEC XG (see: http://www.curtpalme.com/Runco_Model_CrossRef.shtm).
So whatever's said for the XG's holds true here as well.
Oops. My text, my fault. I recently juggled some projectors around between Intermediate and High Perf to match the changes done on the best/worst list but forgot about the text at the top of the pages. I've fixed that text as well.
Thanks for finding my mistakes! I'm glad to have you on board! Let me know if you find anything else! Smile
Person99
Posted: Thu Apr 10, 2008 4:42 pm    Post subject:
OK, I'm late to the game, but that has never stopped me before! Very Happy
The folks have covered most of the basics, but let me ask some questions and add some comments.
1) What is your current model PJ and what do you view as its deficiencies (i.e. why do you want to upgrade)?
2) What is your current screen size (it seems that you are doing a zooming CIH set up so just give me the 2.37:1 size)?
3) What is your seating distance (either relative to your CIH screen height or either the 16:9 or 2.35:1 image size)?
4) In what order do you prioritize performance on these types of content (rank them in order): HD Films, SD (DVD) Films, broadcast HDTV shows, broadcast SDTV shows, broadcast HD sports, broadcast SD sports
Now for some comments (warning, I'm direct and some people get offended--it is truly not my intent! Smile).
I'm a home theater nut and a projector nut. There is no popular projector that I don't get to check out--often in my own neighborhood. This is the list of <$3000 1080p digitals have have played with in theaters (not dealer demo rooms, and some in my theater):
Panasonic PT-AE2000
Epson 1080UB
Mitsubishi HC5000
Optoma HD80
I can sum them up in one word: CRAP
LCDs have a very flat (no depth of image look) to them that I just hate. They are not involving at all because of this. All of these models have major contrast ratio and black level issues. Further, every single one of the LCD models is hit or miss on convergence. The question is not "will the projector have convergence issues?" but "how bad will those issues be and will they fix it?" Every single one of these that I've seen has convergence issue that were visible from a normal/average seating distance, further, all of them were "within spec" and the manufacturer refuses to fix them. I view seeing red and blue outlines on peoples faces as unacceptable and certainly not worth giving a projector an excellent rating (maybe not even average).
As far as black level, none of them are very low. LCDs have HORRIBLE native panel contrast ratios, so even with the dynamic iris engaged, a full black screen is roughly equivalent to what a good DarkChip 3 720p DLP can do. In fact, the contrast ratio you really experience with these even with the dynamic iris engaged is typically the same as, or worse than a DarkChip 3 720p DLP (for instance, I can get a much better contrast ratio out of an Optoma HD7100 than I can out of any of the above PJs).
All these projectors also are not very detailed (compare them to a JVC RS2 for instance and you see there is detail missing). The LCDs obtain their sharpness artificially by the pixel spacing, not by real detail. So, if you compare for instance the Mitsu HC5000 to a JVC DLA-RS2, you will at first think the HC5000 is sharper (thanks to the pixel spacing creating hard edges), but after watching for awhile you will actually see the JVC is sharper looking because it has more detail.
This same thing happens when you compare a top end 720p DLP to these 1080p LCDs. Because of the better CR (both on/off and ANSI) and more detail, from about 1.5x the picture width, the 720p DLP will appear most of the time to have equal or more resolution. I have head to head compared the following in the same theater with the same sources:
Epson 1080UB vs. Samsung SP-H710AE
Panasonic PT-AE2000 vs. Optoma HD7100
In the case of the first one, the Sammy is only an HD2+ chip machine, so the Epson could beat it in black level and CR (only by a little). The percieved resolution of them was the same about 99% of the time (find the right scene with the right background detail and you could detect that the epson had more resolution, but for any viewer watching a movie, they would think they were the same. Now quality aside, the Sammy is an amazing little PJ. It is to this day pretty much the only digital the can be calibrated to accurate primaries and secondaries without the use of an external high end processor like the Lumagen Radiance. Let me tell you, once you've seen accurate (read: realistic) flesh tones like a CRT can do, inaccurate displays look aweful)! So, in this head to head, I'd have to give the win to the Sammy as the Epson only beat it on absolute black level and very occasionally perceived resolution. The Sammy was better on color, depth of image, grayscale accuracy, uniformity, and "film-like" appearance.
I'm not even going to waste much time on the second one. The Optoma was so incredibly superior to the Panny it was not funny. The Optoma had WAAAAY more depth of image, better uniformity, better colors, better on/off and ANSI CR, and thanks to smoothscreen, better perceived resolution.
I have to laugh at this "only resolution matters" mentality. Over on AVS, some guy was wondering why is Optoma H79 (DC3 720p DLP) looked better than his friends Mitsubishi H4900 (LCD 1080p). Both of them thought so, even the HC4900 owner. They were flabbergasted--they just kept thinking--but the Mitsu IS 1080P!!!!! how can the Optoma look better? Resolution is only one component of image quality!
As for the Optoma HD80--it actually makes 1080p DLP look bad! Its on/off CR is horrible (2200:1), its ANSI CR is 1/3 the amount of a good 720p DC3 DLP, and its black level is not that good!
OK, that long dissertation was setting up to my argument. Smile In the digital world right now, you've got 2 reasonable options IMO):
1) Go for quality: buy an RS2 and pray to god you get one with good convergence. You will have a spectacular picture--period.
2) Go for the "best you can afford" on a "budget": Get a great 720p DLP and live with the artifacts (RBE and minor dithering and false contouring).
Expanding to a include CRTs adds a third option:
3) Equal to, or very near the performance of number 1 at a cost equal to or very near the cost of number 2.
Being flat out honest, the CRT does some things better than the RS2 in the picture quality department (motion, absolute black level, convergence accuracy) and somethings worse (brightness, uniformity, sharpness). But in the end, they are very close to each other with these differences not being huge (except for convergence accuracy). Factoring in non-picture quality components, the CRT wins on price/value and reliability/longevity and the RS2 wins on user friendliness.
So, if you are not willing to pop for an RS2, it comes down to priorities, because you are going to make sacrifices. To overly simplify, it goes like this: You either either going to sacrifice brightness and user-friendliness in favor of "film-like" appearance, depth of image, color accuracy and no artifacts (CRT), or, the other way around (<$3000 digital).
Now, I have not talked about CIH. A CRT is simply not a good candidate. If that is VERY important, that I would advise against a CRT. However, there is something that the best 8" machines and good 9" machines can do that a digital cannot do as well: constant image area. With a constant image area, you typically set up on a 2.05:1 screen. Doing this, you keep the image area roughly equal between 1.78/1.85:1 and 2.35:1 content. You do this because 1.78 content is a little taller and a little narrower than 2.35:1 content. Basically 2.35:1 content uses the full width of the 2.05:1 screen (but not the full height), whereas 1.78:1 content uses the full height of the 2.05:1 screen (but not the full width). This makes all aspects equality enjoyable to watch (as to your brain, they are all the same size).
Anyway, let me know the answers to the questions, and I'll see if I can give you some other things to think about.
J.man1503
Posted: Thu Apr 10, 2008 5:27 pm    Post subject:
Well, my current projector is the Panasonic 900u. I have calibrated it with a color correction filter, a similar process that is described here: Cine4home.com click on the right under specials on "C4H Innovate Tuning: LCD Projector Sanyp PLV-Z5".
The defincies are as follows:
I want a sharper image. The "Smooth screen" technology advertly affects image sharpness on a 720p projector.
I want more detail, the advantage of a (good, not a Mits 4900) higher resolution projector.
I want blacker blacks, although, my absolute black level is approx. .05 lumanice currently, but I know that current 1080p (decent ones) digital and ALL CRTs can beat that.
Also, I desire dead on color reproduction, as a normal human is not as susepatable to blue being off, I notice most of the time my green is too green. This problem is something that is inherent with the current settings of my projector that I have purposely done to improve the contrast ratio.
My current screen size is 88" wide 2.35 aspect ratio. To be able to watch moives without black bars is ESSIENTIAL. I do not really care how I will watch the 16:9 movies. I have another pull down screen that I could use to pull down right in front of my current stretched 2.35 screen that I could use for 16:9.
My seating distance is (and must be for audio nulls and frequency response purposes) approx. 1.12 times the picture width.
I do not watch anything except movies and I only watch content that is on a disc, I currently (and probably will not) do not have any services such as HD cable. That leaves us with two options, DVD and High Definition DVD. I am currently migrating to almost all High Defintion DVD content. But as of right now I watch 35% HD on disc and the rest is DVD. 80% of the content I watch is 2.35>2.4 aspect ratio. In the end (when I am totally migrated by the end of this year) I will watch 60% HD and 40% SD DVD. So my ranking would be as follows:
1. HD films 2. SD DVD (I don't watch anything else)
Posted: Thu Apr 10, 2008 5:32 pm    Post subject:
Dave,
What a well composed, objective, sensible look at the current state of things. Kudos.
Person99
Posted: Thu Apr 10, 2008 6:34 pm    Post subject:
Yes, the Epson or HC6000 is better than the 4900, but they are no RS2 or Marantz VP11S1!
(BTW, on the Panny, I could never get both: relative grayscale accuracy and blacks that were not blue black--if you've achieved this--kudos!)
In the CRT world, an "average" 8" machine will exceed the sharpness of you Current Panny. The question then becomes how much more sharpness do you want? The best 8" machines and good 9" machines will be a little softer than the Epson or HC6000. On normal movie content, you would really only see this in a side by side comparison. Where it is actually obvious is text like on a computer desktop (not often appearing in films). So, put simply, if you are a "sharpness freak", don't get a CRT. If you pretty darn sharp (much better than the 900).
You have a pretty small screen, so you are definitely in CRT optimum territory. The 1080UB is pretty bright. If you want that brightness on a small screen, then a CRT cannot come close. If you were going to use the 1080UB with an ND2 or ND4, then the CRT may compete. The real CR of the 1080UB is kind of borderline, so an ND2 may even push it to not that great.
CRT blacks will wipe the floor with the 1080UB. If you are a "black freak", then the CRT is going to look better. With my CRT at the beginning of Cars, when the blackouts happen, you can see anything--not the room, not the screen...NOTHING! That is kind of cool. Smile
You didn't really say anything about the deficiencies of LCDs in general, such as the flat looking pictures. If this does not bother you and the black level on the Epson is good enough, then the only real concern with going with that would be the convergence issues. You sound like you care about image quality and you may have to go through a few Epsons to get an OK one, but an OK one will still have convergence issues. If this is also not an issue, than you should probably go with the Epson.
My current screen size is 88" wide 2.35 aspect ratio. To be able to watch moives without black bars is ESSIENTIAL. I do not really care how I will watch the 16:9 movies. I have another pull down screen that I could use to pull down right in front of my current stretched 2.35 screen that I could use for 16:9. [/QUOTE]
Not sure if anyone covered this, but a CRT will not zoom. So, it is what it is.
So, I need to know what you mean by "without black bars". If that means CIH, then I would tend to steer away from CRT, but you are a special case (I'll get to that). If that means "don't project the black bars and it is OK to mask the unused portions", then a CRT could work.
Now, normally, my mantra is "don't do CIH with a CRT!!!!!!!" This is because: 1) people want screens CIH screens too big for a CRT, and 2) 16:9 content suffers too much. You, my new friend Wink, are a special case because: 1) your screen is not too big, and 2) you don't care about 16:9 content! In this case, a CRT is back in the running!
But, 1080i is not an option for you. You could run 1080i and get rid of the black bars but it will have two problems from your seating distance, scan lines would be too visible. So, given your seating distance and budget, the only viable CRTs are an NEC XCLC, Sony G70, Cine 8 Onyx (you likely would not like an older 9" near your budget as too much noise in the image and they are no sharper).
Now, to do these well, you would need at least a lumagen HDP ($750 used). You would do either a CIH or CIA set up. Let's assume CIH for a second. You would run 2.35:1 content at its active area (i.e. 1920x817@48 or 72 progressive). No black bars, and you'll save bandwidth that will increase the sharpness, and have no scan line visibility. When doing 16:9 though, you will have to down scale it to something like 1450x817 or it won't be sharp at all! Still better than 720p though! Now, if you went CIA, you would still have to downscale your 1080p 16:9 content, but not quite as much.
One thing, I see you said, your seating distance was dictated by audio, not room size. Bear in mind that the average CRT has about a 1.5 throw and they are over 2' long. So, with your 88" screen, an average PJ will have to be put about about 11' back and the back of it is further than that--so you'll need a room depth of about 14'. The shorter throw PJs like the Cine 8 Onyx would have the BACK of the PJ at about 11' so you only need a 12' deep room.
Also bear in mind that with a CIH screen, the PJ will only be a little above the screen, so if you have an elevated second row, this could pose a problem with a non-short throw PJ.
1. HD films 2. SD DVD (I don't watch anything else)[/quote]
Well, had you not said film, film, film, I'd have said get the digital. A CRT works for you. Also, since you only care about film, 1080i is an option for you if your set up accommodated it.
For what I would consider you optimal CRT set up, I'd say:
1) Get Lumagen HDP.
2) Get Great 8" LC
3) Get an HDMI/DVI input of some type.
You could pick all this up for close to the same price as the Epson. If you don't like it--sell it, you'll be able to sell it for about what you paid for it (unlike the Epson) Very Happy.
As an aside, I'm moving and won't be able to use the CRT, so (if I can even accommodate a PJ) I have to go digital so viewed CIH as a perk of this. Frankly, I disliked all the LCDs so much that I could never consider one an adequate replacement for my PJ in any way. If I do get a digital projector, I'm likely to pick up a great 720p DLP and live with the artifacts until the RS2 comes down to meet my budget and I can buy a local one that I can ensure has no convergence errors. If you can handle a CRT, you could make one work for you in your budget and have a great set up. If you think the Epson is good enough, then trying a CRT is probably not worth it.
Posted: Thu Apr 10, 2008 6:49 pm    Post subject:
You can't magically lose resolution by running a projector at 'too high' a resolution. You can fail to fully resolve all the pixels you're sending, but you can't make it worse than running the lower resolution; it's just not possible.
As a thought experiment, say you're running 1920x1080 to some projector that supposedly should only handle something stupid like 480p.
Now, if you send it every other line on/off, you clearly will not see a nice stripey picture. You'll see gray.
Now suppose that you send it lines alternating every three pixels, so you're sending the equivalent of alternating lines in a 640 pixel wide image. Obviously you're going to see alternating lines quite nicely; the bandwidth, if it allows 640 pixels when driven at 640x480, will certainly be capable of the same frequency square wave when it's scanning at 1920. There may be small variations in this, but I can't imagine that there's some magic frequency that the projector 'knows' where all of a sudden all the signals drop below their rated bandwidth.
So, we've come to the conclusion that you're resolving things just as well with 1920x1080 input as with 640x480.
But let's take this a little further:
Let's suppose that now you take the second signal and shift it gradually one pixel at a time. Ah hah! Now you're going to see those bars slowly slide to the right (or left). It can obviously start the square wave where you tell it, and it can create the square wave the way you want all the way, so obviously you can now see a gradual pan of that square wave pattern.
You wouldn't be able to with just a 640x480 signal, for obvious reasons! You'd just see alternating lines.
Now let's translate this into a real image - say, a starfield.
For the sake of argument, you have a 1920x1080 image full of single-pixel stars.
Our projector will clearly display something - each pixel WILL be lit. They may be dimmer than they would be with a better projector - probably rounded off, because the bandwidth won't support the signal going BANG BANG BANG up, steady, down; it'll be more of a bump.
But the projector WILL resolve those little dots; you WILL be able to see them.
So, will running our 480p projector at 1080p, if it will physically handle it, result in more information getting to the viewer? You're damned straight it will. Will it result in a softer image? Only if you prefer artificial pixel sharpness in your 480p image - and as far as I can tell, the people around here won't.
As for 1080i vs. 1080p, the difference is, I think, in both phosphor resolution and beam focus, and in bandwidth. It's basically an optical illusion: The phosphor and the projector aren't capable of making nice sharp points while trying to do every line with 1920 pixels. But if it scans every other line, your eye will use persistence of vision to combine two of those well-resolved lines into two solid visible lines. If you take this to the logical conclusion, you could interlace it by drawing every two lines at once, then every four... pretty soon you end up with a progressive scan image at half the scanning frequency.
My experiments with my Barco bear some of this out. If I turn the contrast way the hell down and look right at the tube face, that thing will EASILY resolve 2400x1440, every other pixel. Turn up the contrast and it blows out into gray. The phosphor falls apart.
But if I light the phosphor up for half the time I can resolve more, because it doesn't get a chance to bloom. If I rely on my EYE'S persistence of vision rather than the PHOSPHOR'S persistence of luminance, I can reduce the load on the phosphor and in so doing resolve things better.
This stuff isn't rocket science. It makes no sense to keep using incorrect terminology and conclusions when we're so quick to jump on digital PJs for slight issues.
(...PS: I've never seen an LCD PJ with convergence issues. I've got a Mitsubishi HC3000 (or something, one of the first 1080p projectors) and it's flawless. With convergence, anyway.)
Person99
Posted: Thu Apr 10, 2008 6:55 pm    Post subject:
Since an HC3000 is a 720p DLP, I think you mean an HC5000. My next door neighbor has one other these. Has red convergence issues and a stuck green pixel. This is his second unit because the first developed a green line across the screen (that one also had red and green convergence issues).
Posted: Thu Apr 10, 2008 6:59 pm    Post subject:
Christ, I must have the best luck in the world. We put that thing in a motion platform and shook the ever-loving crap out of it for a hundred hours and it's good as new. 20hz 2g+ vibrations, accelerations the same as being repeatedly dropped on the floor, being stuck in a tiny hot box... no problems at all.
Very odd. Maybe all these things break if they're upside down, or are incredibly tough if they're vertical (like in our platform). Razz
Person99
The phosphor doesn't "fall apart". You are sending much more energy at the phosphor so you excite a larger region. Blooming is both this, and the inability to preserve beam shape because there is too many electrons.
Person99
Posted: Thu Apr 10, 2008 7:00 pm    Post subject:
OP, where are you located?
I'd say go see a CRT, but most are so poorly set up that you may get a bad impression. Smile So, I want to make sure you are seeing a good one!
I was speaking colloquially. What you say is exactly what I was referring to.
Posted: Thu Apr 10, 2008 7:18 pm    Post subject:
Very true! I couldn't have said it better myself... In fact in a different thread Reiner Bauer (long time videophile) had this to say in a post:
r.bauer wrote:
A bright image is the parameter that is most important to give an image impact, it is in fact related to contrast, so a high contrast ratio is key here. Second is bright colors, so please color filter those CRT's! Third is color purity and the fourth parameter is sharpness. Many people have this list in reverse order in their head when shopping for a projector.
Now he was talking about CRT but it's equally true for digitals.
Posted: Thu Apr 10, 2008 7:28 pm    Post subject:
The last 3 I saw were all Epson 1080UB's. All owned by the same person. He had to return it 3 times until he got one that was "reasonable" instead of "completely off" Wink
J.man1503
Posted: Thu Apr 10, 2008 7:54 pm    Post subject:
So how do you know where the happy medium of the contrast setting is, where image blooming doesn't happen (to resolve the most detail correct?) and the image still looks punchy (subjective i know) and not washed out?
J.man1503
Posted: Thu Apr 10, 2008 7:58 pm    Post subject:
I mean that I would be able to project (and I would cover it with masking as I currently do) or not project the black bars. I just do not want to see the black bars on my white screen. That is what I mean. Thank you for the post. Keep asking more questions!
J.man1503
Posted: Thu Apr 10, 2008 8:04 pm    Post subject:
1) Get Lumagen HDP.
2) Get Great 8" LC
How would a HD Leeza compare with the a lumagen for this type of setup? I know that the Leeza has 1080i to 1080p deinterlacing and good scaling. Is there a feature on the Lumagen that makes it so highly recommended?
scoobydoo
Posted: Thu Apr 10, 2008 10:27 pm    Post subject:
I'm running a Barco 808 with the HD Leeza from a momitsu dvd player and the picture looks pretty good. I've scaled it up to 960p as the picture does look a little soft at 1080p.
I am going to add a PS3, hdfury and RTC2200 in the near future. I have also put HD145 colour lens and that gave a huge difference to the picture colour.
I still considered myself a newbie to all of this and when I bought my first PJ a barco 800 from Curt he told me "send a few extra $$ and get a better machine". After a year or so, I ended up upgrading, should have listened to him in the first place.
So hears my words of wisdom, once you go black, you'll never go back. .....I mean...figure out what your budget it, and get the best PJ (CRT pj that is) you can find for the price. IF you are lucky enough, get one that curt has looked over and have done the mods to already.
you won't regret it.
Page 2 of 3
