Crt Tube problem
Goto page 1, 2, 3  Next
ac/dc
Posted: Mon Apr 07, 2008 8:38 pm    Post subject: Crt Tube problem
I own a Sony VPH 1272 . My blue tube went out and is not showing any power/light
Think the tube is dead? Or could there be something else causing the tube not to work?
I'm not a tech guy, so I have no idea how to trouble shoot. Thank You
PS, I'm amazed how good the picture looks even when the blue tube isn't working.
Posted: Mon Apr 07, 2008 8:41 pm    Post subject:
Is the filament lit up ?
ac/dc
Posted: Mon Apr 07, 2008 11:42 pm    Post subject:
Last night the was no light at all in the blue tube.
Today I looked and the tube looked normal?? Weird
I'll run it more and see if it cuts out again. Thank you
Posted: Tue Apr 08, 2008 12:33 am    Post subject:
Any 'snap' or 'pop' sound at all?
Posted: Tue Apr 08, 2008 1:47 am    Post subject:
...or 'crackle'?
whats6x7
Posted: Tue Apr 08, 2008 2:46 am    Post subject:
...or 'crackle'?
ROTFLMAO!!!!!!!!! Thumbs Up
Posted: Tue Apr 08, 2008 4:05 am    Post subject:
I set 'em up you knock 'em down.
Ile
Posted: Tue Apr 08, 2008 9:13 am    Post subject:
If it goes out again after heating it could be bad VPH06 in neck board.
ac/dc
Posted: Tue Apr 08, 2008 7:45 pm    Post subject:
Well the tube didn't go out, but the picture wasn't as sharp as before. The whites look a little bit yellowish and dull. Not a true white like before.
I didn't hear any weird cracks or pop noises.
ac/dc
Posted: Thu Apr 10, 2008 4:38 am    Post subject:
Tonite the set was ok for about two hours. Then my blue & now green tube went dark.
Any ideas what's going on?
Posted: Thu Apr 10, 2008 12:45 pm    Post subject:
When the tube(s) go out try pulling up an internal test pattern to verify if its a source problem or not.
ac/dc
Posted: Thu Apr 10, 2008 7:21 pm    Post subject:
Ok, Will try that tonite
Posted: Thu Apr 10, 2008 7:28 pm    Post subject:
I know your PJ is a 1272 but read this thread its for a D50 curt is having problems with but maybe it does the same as your 1272:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10162.html
ac/dc
Posted: Thu Apr 10, 2008 11:03 pm    Post subject:
Ok, Think I'm making headway.
If I turn on a test pattern such as the RGB, All tubes are working.
I use a Sony Switcher box, If I turn that on, the blue tube goes out.
So I'm assumming the switcher box is bad. Sound reasonable?
Posted: Thu Apr 10, 2008 11:04 pm    Post subject:
Don't assure,
Hook the source up directly and see how it looks
Posted: Thu Apr 10, 2008 11:31 pm    Post subject:
Good possibility. I would try bypassing the switcher next to verify the problem is gone.
ac/dc
Posted: Thu Apr 10, 2008 11:32 pm    Post subject:
Not sure how to do that, the cable fron the switcher box goes to the projector.
You're saying run say a dvd player to the projectors rgb card and bypass the switcher?
mike calcott
Posted: Thu Apr 10, 2008 11:38 pm    Post subject:
You normally cannot plug a dvd player into RGB, but for the test purpose just plug it into the composite video input
Old dog learning new tricks
Posted: Thu Apr 10, 2008 11:43 pm    Post subject:
Bypass the switcher, yes, but I dont know what your options are without a description of you source chain or a pic of your source devices. What model switcher? RGBHV from switcher to projector? Devices connected to switcher, how? Composite, Svideo, component, vga????
Posted: Thu Apr 10, 2008 11:47 pm    Post subject:
If you mean connect it to the projector's composite input, this would not help diagnosis his problem. You would then be bypassing the RGB input of the projector and the problem may be there. He needs to keep testing on the RGB input before moving to another input on the projector.
Page 1 of 3
