| Posted: Sun Apr 06, 2008 10:41 pm Post subject: OK, OK, I'm sold on digital..... |
http://www.hedidntseethatcoming.com/
(click on the plasma screen).
...ok, maybe I'm not quite sold... I don't need THAT feature...
Joe L.
| Posted: Sun Apr 06, 2008 10:44 pm Post subject: It it is THAT real... |
And if it is an "X" rated flick?
| Posted: Sun Apr 06, 2008 10:47 pm Post subject: |
I like the advertising though. Guaranteed that ad would not fly in North America though..
| Posted: Mon Apr 07, 2008 5:31 am Post subject: |
Funny ad, but then I started looking... Found this in the FAQs:
| Quote: | 5. Which technology has the longer life span, Plasma or LCD?
The life span for both is dependent on viewing habits, but if both are watched for the same duration, you would expect the life span to be approximately the same, 60,000 hours - roughly twice the lifespan of older CRT tehcnology. If you watch your Plasma 8 hours a day, it will last you for 20 years. |
So, Curt. From what I've known you to say before, 20 years is a little more than optimistic. What would your estimate of the true life span be?
| Posted: Mon Apr 07, 2008 11:55 am Post subject: |
| ecrabb wrote: | Funny ad, but then I started looking... Found this in the FAQs:
SC |
Things do improve; the first plasmas had pretty short lives all things considered - what, around 10k before half brightness? It wouldn't surprise me if they were hitting 60k by now. Display makers are known for hyperbole, but not usually in display lifetime since it's not a 'flashy' stat, as far as I know.
| Posted: Mon Apr 07, 2008 2:04 pm Post subject: |
What a bull**** stat all around. I have yet to see a CRT tube last 30K hours. Well, actually they probably could, but the electron gun would be pretty iffy at that point.
I don't disagree that a plasma or LCD display can/should/will last 60K hours. The catch is the chassis around the display panel itself will die way prematurely to that 60K hours. Try 1500-10K hours. Seems like the pubs around here all get free NEC plasmas from the BC lottery company, and frankly I think that NEC is amongst the tops in chassis life. All of these pubs run them 14ish hours a day, and I haven't kept on top of how long they last, but I do hear that BC Lottery has a warehouse full of dead units.
THe few airports that I've been in also use NECs (Seatac and Vancouver) from what I've seen, and they are on 24/7. But... most consumers aren't going to buy the big buck units. THe only one that I've had personal experience with was an LG that was installed at a restaurant that lasted 18 months. We sent it out for repair, $350 charge to reseat modules, and then when I was in 6 months later, they replaced it with a Panasonic.
So it's kinda like putting a lifetime warranty on the spark plug wires of an engine, but you know the engine itself will only last 100K miles.
David_Web
| Posted: Mon Apr 07, 2008 2:29 pm Post subject: |
I know what I wanna watch to have something nice dropping out of the screen.
I have a RD708 with 54k h on the clock. Not sure if it has been retubed but the serial stickers match for all the tubes.
Text wear is bad though, and focus is horrible.
_________________ SNR of people are ridiculously low.
| Posted: Mon Apr 07, 2008 2:33 pm Post subject: |
My RG808s has 42K hours on it. Minty clean tubes (not sure if it's been retubed, I'm assuming so). It's fine...
Dave Lister
Joined: 16 Jan 2007 Posts: 436 Location: Adelaide, South Australia
| Posted: Mon Apr 07, 2008 2:44 pm Post subject: |
Well I have no reason to doubt you, but you're the only person that's done that..
I serviced literally 100s of sports bars with Zenith projectors, and all of the tubes needed replacement at about 10K hours. Most let them run to 20K hours, thus the bad reputation that CRTs had when I started selling them on eBay. I always told local customers to check out an NEC PG projector with a line doubler before they bought a year 2000 vintage LCD <yuck!>. I think I lost one sale to a digital back then from a woman that absolutely wanted a 3 lb small projector.
I just don't see how you can still watch a projector with a true 80K hours on the tubes, even if they were in standby mode for 70K hours of that.
At 8760 hours in a year, your set would have had to be on for 9.1 years at 24/7 to reach 80K hours. I guess it's possible...
| Posted: Mon Apr 07, 2008 3:42 pm Post subject: |
Curt, the thing I was thinking about was a post I remember you writing a year or two ago about how the SMT electrolytic caps would dry out pretty quickly and cause failures. I'm having a hard time remembering, but I was thinking you said that because of the subminiature nature of a lot of the new stuff (and the complexity, I suppose), that the problems would be difficult to diagnose, and that the life-spans on a lot of the new electronics would be very short.
Your post kind of bummed me out because I've got a really nice Sony HDV camera I expect to keep for at least 5 years, and the time-frame I seem to remember you kicking around was in that ballpark. Don't the caps dry out whether you're using the device or not?
| Posted: Mon Apr 07, 2008 4:29 pm Post subject: |
Funny, I fired up my 10 year old Sony camcorder for the first time in about 3 years this weekend. The auto focus part of the lens is stuck, as you zoom in, the image goes out of focus, and the unit recorded in b/w for the first 1/2 hour (it's got a b/w viewfinder so I couldn't tell!). THen I got color squiggles, then finally it kicked into color for the last 1/2 of the tape. Wanna bet it's bad capacitors????
Also, the rubber (?) covering on the top of the unit is all sticky. I thought I'd spilled something on it, but the rubber stuff itself is sticky. My backup SOny camcorder is doing it as well. TIme to ditch them for a DVD HD recorder... one fine day.
Stupid unit, I just bought a new $70 battery for the damn thing. I'm pulling the lens apart to see if I can free up the mechanism.
The problem is that the metal cans of the caps that keep the electrolyte in place corrode over time and leak all over the PC board. Can't prevent that at all..
dropzone7
Joined: 12 Jun 2007 Posts: 1069 Location: Charlotte, NC
| Posted: Mon Apr 07, 2008 6:31 pm Post subject: |
Camcorder sticky? Hmm...what have you been filming Curt?
| Posted: Mon Apr 07, 2008 7:00 pm Post subject: |
| Curt Palme wrote: | The problem is that the metal cans of the caps that keep the electrolyte in place corrode over time and leak all over the PC board. Can't prevent that at all.. |
This is a well-known problem with older boards. If (BIG if) the companies cared about producing a product that would last more than 5 years, are there other non-electrolytic options they could use? Or are 'lytics the only way to get the capacitance density you need? Or just the cheapest way?
| Posted: Mon Apr 07, 2008 7:46 pm Post subject: |
Why not just make thicker cans? (insert crude joke here).
To me it's all about skimping out. The arguement seems to be that everything electonic is obsolete within 5 years. I still prefer the sound of a 30 year old Pioneer receiver over any of the new crap out there today.
1031
| Posted: Tue Apr 08, 2008 8:39 am Post subject: |
| Curt Palme wrote: |
I repaired lot of those old camcorders, mostly sonys 8 and Hi8 machines..Not anymore. About 5-8 years back those was quite repairable, usually it needed few new capacitors and cleaning. Those machines are too old nowdays, allmoust every smd-elyt.caps leaks and that electrolyt eats copper from pcb´s. Now i have simple "rule" if old camcorder smells , then its bye bye for that camcorder. You can smell that if caps have leaked
_________________ Marquee 9500LC (Frankenyokes / Thomas electric tubes / HD-10L / +many mod´s)
DVDO VP-50
New hobby, Rally
Dave Lister
| Posted: Tue Apr 08, 2008 11:54 am Post subject: |
| Curt Palme wrote: | Well I have no reason to doubt you, but you're the only person that's done that..
At 8760 hours in a year, your set would have had to be on for 9.1 years at 24/7 to reach 80K hours. I guess it's possible... |
I can't find the receipt for it but I have had it for about 14 years and for most of those years it ran at least 12 hours per day, some days it ran 24 hours when I would stay up all night playing games on my 3DO R.E.A.L. video games system.
These days it is probably on 6 hours a day, sometimes 12 to 18 hours for a game session on my Xbox (original not 360), I don't have much interest in the crap they have on TV these days and don't watch any where near as many movies, I spend more time online.
I will try and get some screenshots but I only have a cheap digital camera (Samsung S630) so I don't know how good they will be.
I was very conservative with brightness and contrast for most of it's life.
Edit:
Here are some quick screenshots.
The focus problem is caused by the Xbox when I pause the movie, the picture is in focus when playing.
The shot is taken with the camera on a tripod slightly to the left of the projector (looking towards the screen) as the tripod does not have long enough legs to go above the projector.
These are the best 2 I got by just trying out some settings without reading the manual.
http://s291.photobucket.com/albums/ll317/A_Frayed_Knot_Mate/?action=view¤t=S6300092.jpg
http://s291.photobucket.com/albums/ll317/A_Frayed_Knot_Mate/?action=view¤t=S6300099.jpg
_________________ I don't believe in pixels or flaries!
Stuff for sale;
| Posted: Tue Apr 08, 2008 1:45 pm Post subject: |
What are you using for a screen? In that first shot I see a "wrinkly" texture like you'd just hung up a sheet or something...
Dave Lister
| Posted: Tue Apr 08, 2008 5:49 pm Post subject: |
| Curt Palme wrote: | Why not just make thicker cans? (insert crude joke here).
To me it's all about skimping out. The arguement seems to be that everything electonic is obsolete within 5 years. I still prefer the sound of a 30 year old Pioneer receiver over any of the new crap out there today. |
...and, apparently, the quality of VHS tapes to 1080p...
