Barco blue gamma slope/breakpoint, R&B midlights? Huh?
Posted: Tue Apr 01, 2008 6:43 pm    Post subject: Re: BG808S
zGman wrote:
I just do the G2 pot setup while inputting the test pattern, I haven't seen the "compensation"
effect that you spoke of, and haven't had any problem getting good results....unless of course
there really is some difference in these machines beyond the branding change....?
No, there really isn't any difference in the boards of a Zenith 1200 and a 808s. They even have Barco stickers all over them. I've got the numbers listed on the Zenith 1200 page on the main site.
What I mean by compensation is that unless I'm in the service menu G2 adjustment mode, when you adjust one one of the pots you'll see the raster go up or down in brightness (depending which way you turn) but then it immediately compensates and you're back at the same brightness as before. When you go into the service menu and enter G2 adjustment mode and tweak them, they stay put. I'm assuming this is normal as otherwise why is there a G2 adjustment mode at all in the service menu? When you enter that mode it seems to reduce the scanrate down to around 15-16Khz aka 480i (I'm guessing) and gives you instructions on the screen.
zGman wrote:
You asked about the colorfacts test patterns...I can send them, but at one time they were
available on the website. There are several very nice features, and the lowend pattern
has much finer graduations than a typical step pattern, which allow you to see more exactly
when the tube is just off "idle" (ok, ok, so I'm a car guy....)
I've found that I have absolutely everything I need with the free AVS HD 709 patterns. It's been months in the making and has every single pattern you could need when doing greyscale. They're available in an ISO download that you burn onto a regular DVD. The result is some REALLY nice patterns in blu-ray format (HD DVD available too).
See: http://avshd709.com/
The list of patterns available is here: http://avshd709.com/index.php?option=com_content&view=article&id=43&Itemid=54
For both the low and high end they have extremely fine graduations of 1 byte differences from 0-255 with 16 and 235 marked off. so they'll have vertical bars with each one being one number higher than the last. I've never seen anything this fine before.
The other thing I like is the 5% increment full screen patterns in R,G,B and white, which can be stepped
through using the arrow keys on a keyboard, which makes it easy to see when the tubes come on,
and easy to measure the relative luminance of each IRE step.
Yep, AVSHD 709 has this too. 5% steps, 10%, and 25%. They even have 105% and 109% so that you can see overshoot if you're set up for 0-255 instead of 16-235.
Their 10% steps and colors are in the order HCFR uses so you can quickly step through as you do your greyscale, primaries, and secondaries.
One thing that I had meant to mention, is that I would start all these adjustments with the focus, astig,
and convergence as perfect as possible. Light output is very dependant on these, and the blue defocus
should be just an intermediate step, after things are roughed in, and should not be more than a few clicks.
Thanks - good tip! Projector's nicely set up already (I've had it for 2-3 years now). Just want to redo the greyscale again.
I was thinking about having the do the setup with contrast at 75 and there's something else that comes into play with that: The gain pots on the RGB driver board. My new mod'ed input & driver board have the gains set higher than the stock boards. In fact, at 100IRE , contrast at 65, and green gain at 60, I get 8.4 ftL on the stock boards and 11.7 ftL on the mod'ed boards!!
On the new mod'ed boards with the green gain at the default of 69 (and others at defaults as well), I can't go past 70 without blooming. It's just so much brighter.
Posted: Wed Apr 02, 2008 1:32 am    Post subject:
Here's another question: When you take xyY measurements for greyscale you typically use a small window in the middle of the screen of varying shades of grey. When people refer to their peak like output at 100IRE, are the referring to the small window ftL reading or the whole screen displaying a 100IRE white?
Mine vary widely. I get 14+ ftL on the small window at 100IRE white with contrast set to 65 while a full screen 100IRE white only gets me 6 ftL!
I know this has to do how CRT's work. I'm just surprised at the difference when I actually measure it. I can easily push the small 100IRE window into blooming when I crank the contrast above 90, but can't even get close to blooming if I have a whole white 100IRE screen.
zGman
Posted: Wed Apr 02, 2008 3:35 am    Post subject: Barco setup
Hi Kal,
Thanks for the link to the new test patterns - I will try that soon.
Yes there's a big difference between the windowed pattern and full
screen, and in some of my testing, I found a different greyscale
profile and luminance curve between the two methods. Which is
the right way...? I am not so sure. Its pretty rare any content is full
grey screens anyhow. And one of the major strongpoints of CRT
projection (in my opinion) is the ability to really punch out a bright
object (car headlights, sunny reflections, etc) in an image.
Cheers,
Galen
r.bauer
Posted: Wed Apr 02, 2008 12:05 pm    Post subject:
Maximum lightoutput is related to projected surface area. Peak lumens are always measured at 10% windowed pattern.
Use this pattern when calibrating your projector. This type of Average Picture Level (APL) is very similar to the APL of video or film material.
It all comes down to beam current. There is just a maximum that can be delivered during a certain period of time. This originates in design of the electron gun (all these electrons emiting just from the tip of the Cathode), the RGB end-stage (That 100V peak-peak video signal has to be delivered with a certain amount of miliAmps at 120MHz or more. This is very difficult, many people forget what kind of a very special circuitry is needed to achieve these specs!) and the High voltage power supply which has to deliver enough miliAmps at 34,7kVolt.
One last thing: Rember that when calibrating a CRT projector you are just compensating for CRT-aging. That's why some knowledge of CRT-aging comes in handy.
Natural Gamma curve of each CRT.
the green CRT behaviour is closest to the natural Gamma curve of 2.2. Red is more dificult and proper correction in the driving circuits is required to achieve 2.2 gamma. Blue is worst of all, much more correction is required to achieve the 2.2 Gamma curve.
Some interesting reading about Blue roll-off at high drive level:
(This link also partially desrcibes the Gamma slope and breakpoint function)
http://www.patentstorm.us/patents/5644360-description.html
http://www.torrscientific.co.uk/phosphors.htm
http://www.engineering.uiowa.edu/~aip/Misc/ColorFAQ.html#RTFToC17
Posted: Wed Apr 02, 2008 1:49 pm    Post subject:
Thanks for the info - I was aware of the reasons but was suprised at the actual numbers when I started to measure.
I can get 16 ft/L out of these P16LNP tubes (2000 hours) on a 10% window pattern of 100IRE which suprises me. That seems incredibly high. This is bouncing off the screen as well. I think I'll aim a bit lower, like around 12 or so. At 16 I'm starting to experience some blooming/softness. Certainly looks punchy though! Lots of light output and still being able to do complete black is fantastic. I understand more and more why people stack! Amazing contrast ratio.
r.bauer
Posted: Wed Apr 02, 2008 2:58 pm    Post subject:
The aim should be to achieve 13ft/L, which makes for a really nice image. A bright image is the parameter that is most important to give an image impact, it is in fact related to contrast, so a high contrast ratio is key here. Second is bright colors, so please color filter those CRT's! Third is color purity and the fourth parameter is sharpness. Many people have this list in reverse order in their head when shopping for a projector.
Minimum light output should be at least 11ft/L to give a punchy picture. In completely black rooms (floor, walls, ceiling, black t-shirts etc) less light output is required for an image to have the same impact, so you can get away with less lightoutput. In fact, there is no better upgrade possible for you home theater than to make your HT room completely black. Your contrast ratio will increase ten- to hundredfold or more! Direct light on the screen, even from equipment is a big no no.
My HT is not completely black, and every time I setup someone else's CRT in a blacked out room, I am impressed by the increase in picture quality and the impact that it has on me.
Posted: Wed Apr 02, 2008 6:19 pm    Post subject:
Tinted C-elements here on my Zenith 1200 / Barco Cine 8 Onyx clone so it's definitely filtered. Looks great too. I can't live without tinted glycol or c-elements. I've been spoiled.
Thanks - I'll target around 12 ft/L.
Posted: Tue Apr 08, 2008 9:23 pm    Post subject:
So I've spent a few days working on my greyscale and I can get everything nice and flat except for the low end of the blue tube. Not a big deal (looks fantastic) but I'm a stickler for perfection so I'm trying to figure this one out.
I've tried so many different things that I actually think there's something slightly wrong with how the blue tube reacts.
Take a look at this:
No matter what I do, the blue drops right off in the 0-30 IRE range.
I've adjusted my G2s manually so that when 0 IRE is displayed, all 3 tubes tubes "light up at the same time". But the problem is that the light output out of the other two tubes just increases so much faster as I turn up the brightness (or display increasing patterns from 0-30 IRE) that the result turns out the same no matter how I adjust the G2's. Blue always drops off like crazy in the low end.
If I change the Blue cut-off to get more blue in the lower IRE's (ie: calibrate for the 10 IRE or 20 IRE point) it creates an enormous blue hump in the middle of the graph that makes the rest of the image too blue. My blue midlights setting is already at the factory default of zero - I can't lower it any further to reduce blue output in the mid-section.
I'd like to raise the blue in the 0-30 range but I've litterally spent 10-15 hours on this and it just doesn't seem possible.
I'm starting to think the only way is with an scaler that gives you advanced controls for stuff like this. Would be nice to have one for 72Hz output too. I'm seriously considering one.
Any hints?
Posted: Wed Apr 09, 2008 1:00 am    Post subject:
Any hints?
Get an HTPC, and write an avisynth script that modifies output luminance per-channel in an inverted map vs. your readings. Voila - absolutely perfect grayscale tracking!
Posted: Wed Apr 09, 2008 1:09 am    Post subject:
I have an HTPC. It worked perfectly until I bought a Blu-ray player in the summer of 2007. The HTPC hasn't been on since. I'm done with HTPC. Wink
Chuchuf
Posted: Wed Apr 09, 2008 3:21 am    Post subject:
Kal,
I assume that you are taking the readings off the screen w/ your sensor (sorry I didn't read all of this thread). If so that sensor is not that sensitive when taking reflective readings. Even pointed at the PJ, below 19ire is tough.
I believe that the readings you are getting below 30ire are the fault of the sensor?? Especially at 10ire.
I generally look at trends as I approach 20-30ire to determine where the color is going. Yours are fairly flat which is good.
Terry
WTS
Posted: Wed Apr 09, 2008 1:00 pm    Post subject:
Hi Kal,
I was just wondering if you have the gamma boost circuit in the path when you're doing the greyscale. Of course you need to include it during cal but have you tried it without?
Walter
Person99
Posted: Wed Apr 09, 2008 2:49 pm    Post subject:
Funny you should say this. I was talking with Jim Peterson (President and CTO of Lumagen) the other day. The DVI/HDP/HDQ do not have the controls you need to do this, but the Radiance will. The radiance actually has awesome controls For both the primaries and the secondaries. The "old" series has just the primaries, it can help, but the secondaries can get out of whack. The radiance can calibrate the colors perfectly across grayscale for any display whose primaries are outside the triangle! Yep, it can give an RS1 accurate colors!
As an aside, it was interesting that Lumagen thought their scalers at $1000-2000 would fly off the shelves since:
1) They are better than anything else at this price point.
2) It is a modest investment to improve your picture quality (most people are spending 2-5 times that on the display).
However, as Jim noted, most people just don't care about have great performance, so they are not making tons of money on volume. So, they are pretty much going upscale. They will have an even more powerful scaler than the Radiance most likely at the $8000+ price point and we likely will not see another $1500 scaler from them as (relatively powerful) as the HDP. Sad kind of.
Person99
Posted: Wed Apr 09, 2008 2:51 pm    Post subject:
So, with this approach, how do you get perfect grayscale on, say, the HBO HD broadcast of Star Wars, or a Discovery HD show?
Posted: Wed Apr 09, 2008 3:21 pm    Post subject:
Chuchuf wrote:
Kal,
Terry
Hi Terry - Yes, I'm reading bounced off the screen with the Spyder2 very close (3-4" from the screen angled up). I get crazy readings if I face the projector.
I know that under 30 IRE is tough but I'm getting extremely consistent readings at 10,20,30 IRE. And the results do actually look like the readings (After spending about 15 hours on this over the last week or two I've gotten pretty good at this and can predict what the Spyder2 readings will tell me just by looking at the screen - for example, at 10IRE it looks like there's not enough blue. If I crank up the blue in the low end it looks more 'grey').
I watched the 2007 Oscar winner last night: No Country for Old Men (a movie last night that's known to have an excellent transfer) and it looked fantastic. 10IRE is dark enough that really it really doesn't make much of a difference. I was just hoping someone would have some ideas.
Thanks for the feedback though. One thing's for sure - a greyscale does make a huge difference. I'd go as far to say that having a low end projector with proper greyscale and setup will be a lot nicer to look a lot than any high end projector where the greyscale is considerably off (like mine was at the default settings).
Posted: Wed Apr 09, 2008 3:25 pm    Post subject:
WTS wrote:
Hi Kal,
Which gamma boost are you referring to? The RTC2200 gamma boost? Or the Zenith 1200 Blue gamma correction? I use the RTC2200 gamma boost to come out of black faster (as expected) and the Zenith 1200 blue gamma slope/breakpoint to help fix the blue roll-off that happens at the high end.
I haven't tried reducing the gamma on the RTC2200. You think maybe it's not affecting the Blue the same was as the Red/Green? Interesting idea. I'll try taking a measurement without the RTC2200 in the signal path. Thanks Walter. It could be that the RTC2200 is defective and only affecting the R and G channels! Holy crap! That would be an easy fix! I'd be surprised though as you think I would have noticed that... but then, in the 10-20 IRE range colour's hard to see and only boosting the R and G would yeild a gamma boost too as they make up most of the light output.
Posted: Wed Apr 09, 2008 3:35 pm    Post subject:
[quote="Person99"]
I'm glad you said "outside" Dave... as obviously you cannot push something that is inside the triangle out (ie: give something 'better' colours than it can actually display).
Sad yes. But I've seen this happen time and time again. People want the biggest and best as a bragging right but then do nothing to set it up properly. Like I mentioned in my last post - I've seen setups on older projectors that were properly calibrated and set up than the latest gee-wiz projector that was just plunked down and turned on. I've seen ECP's outperform high end 9" machines simply because the ECP owner took the time to set it up right while the 9" machine owner didn't know his raster from a CIE diagram.
Person99
Posted: Wed Apr 09, 2008 4:31 pm    Post subject:
Well, outside the triangle is what most digital PJs have (the CIE chart of most digitals is a mess with a green literally in left field and a red so oversaturated everything looks like a cartoon). So, this is the exact problem they are trying to correct. Pretty much none of the digitals have a CMS that can fix the primaries and secondaries--hence putting it in the Radiance.
Posted: Thu Apr 10, 2008 12:15 am    Post subject:
Well, so much for that idea. I tried:
PS3 -> HDfury -> Extron VGA switcher (used as a cable driver) -> Zenith 1200 projector
Even with the RTC2200 out of the signal path I get the same odd blue drop off below 30 IRE. The blue tube just doesn't turn/excite at the same rate as the others in the 0-30 IRE range and playing with the blue cutoff to bump it up creates a huge over-blue hump from 30-60 IRE.
Oh well - I'll leave it as is. You can't even really notice it in the 10-20 IRE range. The graph looks odd in that range but the results still look fantastic.
MikeEby
Posted: Thu Apr 10, 2008 12:31 am    Post subject:
Forgive my ignorance to these kinds of thing, but when you take your readings does the sensor repeat when going from 0 to 100 IRE then back from 100 to 0 IRE? In other words do you see hysteresis in your readings?
Page 2 of 3
