kal Forum Administrator
| Posted: Thu Apr 10, 2008 12:46 am Post subject: |
| MikeEby wrote: | | Forgive my ignorance to these kinds of thing, but when you take your readings does the sensor repeat when going from 0 to 100 IRE then back from 100 to 0 IRE? In other words do you see hysteresis in your readings |
I'm not sure I follow. I skip through from 0 to 100 IRE in 10 IRE steps. The results are always repeatable meaning that I get the same results every time no matter which direction I'm going (up or down).
No hysteresis as you change to the next pattern and then tell the sensor to take a reading, when it's done it tells you to go to the next. It's not a continuous thing unless you use the PC to drive the projector (which I don't do as I want to use HD colour space and also want to calibrate for my whole video chain). Even if it's automated there's delays and a wait period before the sensor starts to read.
MikeEby
| Posted: Thu Apr 10, 2008 12:50 am Post subject: |
| kal wrote: | | MikeEby wrote: | | Forgive my ignorance to these kinds of thing, but when you take your readings does the sensor repeat when going from 0 to 100 IRE then back from 100 to 0 IRE? In other words do you see hysteresis in your readings |
Kal |
That was my question. So you get the same reading in both directions.
I agree you need to use the actual source you are calibrating.
timf
Joined: 07 Jul 2007 Posts: 102 Location: Adelaide South Australia
| Posted: Thu Apr 10, 2008 1:04 am Post subject: |
So Kal how far off is the guide you mentioned earlier on?
WTS
| Posted: Thu Apr 10, 2008 3:57 am Post subject: |
Hi Kal,
Well it was worth a shot, I just thought maybe it might have been problem. Not sure when I;ll be doing mine next but I'll record my numbers etc and pass them on to you. I know when I was doing it last time my bottom end fell in line just like the rest. I used the continuos mode and then just went through the IREs(full window).
_________________ Thanks
Walter
| Posted: Thu Apr 10, 2008 1:42 pm Post subject: |
Full window? That's not the way to do it Walter unfortunately. You'll only get about 6-7 ft/L at 100IRE instead of 11-15. Makes a huge difference on how the tubes react/behave. You need to use the 10% windowed pattern. It won't make much of a difference in the low end but your high end will react completely differently.
If you use full screen patterns you're really only calibrating for about the 0 to 40/50 IRE range. The reason/logic: I get 5.1 ft/L at 40IRE and 8.5 ft/L at 50IRE while using a 10% window pattern which is similar in light output to my 100% window pattern at 100IRE which only gets around 6-7IRE! If I do a 10% window 100IRE pattern I get 11.8 IRE (I was targeting 12 ft/L output). Our Zenith 1200 projectors can do more than 12 ft/L (I can get 16 ft/L easily) but my rooms very dark (all black for 6 feet around the screen and ceiling) so I find 16 ft/L just too bright when watching average movie content.
studio
| Posted: Thu Apr 10, 2008 5:35 pm Post subject: |
| kal wrote: | | perisoft wrote: | | Get an HTPC, and write an avisynth script that modifies output luminance per-channel in an inverted map vs. your readings. Voila - absolutely perfect grayscale tracking! |
I have an HTPC. It worked perfectly until I bought a Blu-ray player in the summer of 2007. The HTPC hasn't been on since. I'm done with HTPC.
Kal |
HI Kal,
You said you were done with HTPC, so what is in your signal path to your PJ. I have a 1209s and just curious.
Steve
WTS
| Posted: Thu Apr 10, 2008 11:35 pm Post subject: |
Well my logic says if I was watching a 10% window then I would do it that way, but I'm not so why do it that way. Calibrate it the way you're going to be using it.
I do it that way and my results(pic) are excellent.
Walter
Person99
| Posted: Fri Apr 11, 2008 1:13 am Post subject: |
| WTS wrote: | Well my logic says if I was watching a 10% window then I would do it that way, but I'm not so why do it that way. Calibrate it the way you're going to be using it.
I do it that way and my results(pic) are excellent. |
Actually, a 10% white window IS how you are going to be using it. I think I've only seen 3 1 second long all white screens in all of my hours watching movies! Secondly, because the CRT limits current, an all white window will never give you the top of the white range like what you will see in a typical movie.
_________________ Dave
WTS
| Posted: Fri Apr 11, 2008 1:39 am Post subject: |
I'll try it both ways and see which way looks better or if they produce difference results on the HCFR software.
Just seems to me that stressing or driving the tubes that hard by using a 10% window is not how the tube is going to be under normal viewing/operating conditions. Yes of course you'll rarely see a 100IRE full window from any movie or program but you normally watch the full screen not a small window going from 0 to 100 IRE or 0 to peak current draw in this case for the whole pattern.
I think maybe the proper way to do it then is to have a 100 or 80 or whatever IRE level in a 10% window located in the middle(surrounded by) of a mix of other various level IRE boxes to simulate a more typical condition for current draw over a full screen.
Walter
Walter
| Posted: Fri Apr 11, 2008 3:27 pm Post subject: |
Well I've been back and forth trying different things and I pretty much always end up in the exact same spot as I try and get the blue tube to not drop off in the very low IRE's.
That being said, the results are still very good from 20-100IRE and very flat from 30-80/90 which is what you're supposed to aim for. The lack of blue at 10 IRE isn't really noticed as 10 IRE is pretty darn dark.
The general rule to try and aim for a delta E at any given more that is below 10. Changes in deltaE of 3 or less are said to be unoticeable by the human eye, so anything at 3 or is considered 'perfect'.
I may try increasing the red and blue gains by one notch to try and pull them up a bit at the high end to get the 90/100IRE reading slightly better and more in line with the other reading I posted earlier, but frankly, I doubt it would even be noticeable. Tweaking this stuff's never ending if you try and get it absolutely "perfect". Even waiting an hour will result in very slightly different readings so you have to just look at the bigger picture sometimes and consider the the margin of error that's involved in taking these readings.
I may have to reduce the contrast slighty too - I'm getting 13.8 ft/L at 100IRE (10% window pattern) and it's a little too bright I think. 12 ft/L may be a little more confortable on the eyes considering that my HT's dark (black on the wall all around the screen and for the first 6 feet into the room on the walls and ceiling).
RGB readings: From 30-90 all readings are very close to within 3 deltaE from perfect which is x=313, y=329. 10IRE is off but such is life
Primaries & secondaries: All RGB readings (except for 10 IRE) are within 10 deltaE from perfect. Primaries (the corners) are pretty close to the actual perfect values. Red's a bit off to the left but there's nothing I can do about that.
The one graph I don't know what to make of is Luminance (gamma):
White=Reference
Green=Average
Yellow=Luminance
The numbers in the first picture (very top) tell me that my average gamma is is 2.27. I'm told you want to be between 2.2 and 2.5 where 2.2 gives you more black (dark) details.
From 40-90 the luminance aboite is slightly under the reference. Not sure it matters. I use an RTC2200 with about 11 turns of gamma boost to get out of black faster so that details are not lost. The results look fantasic. I just really know what to make of this graph or how to use it. Oddly enough, if I set the greyscale settings back to defaults everything is out of whack but the luminance graph is very nice (?).
| Posted: Wed Apr 30, 2008 7:53 pm Post subject: |
| r.bauer wrote: | | Maximum lightoutput is related to projected surface area. Peak lumens are always measured at 10% windowed pattern. |
Interestingly enough, the Digital Video Essentials: HD Basics test disc I've also been using has 18% windows. My AVS HD 709 test disc has 10%.
I put both 100 IRE window patterns up one at a time and measured the light output - they were the same. Light output seems to drop off if the window gets too big, but the difference between 10 and 18% doesn't seem to affect most CRT projectors (at least mine).
If you're really pushing your contrast high then there may be a difference between the 10 and 18% 100 IRE window patterns. If you're really pushing it there's likely a difference between a 2% and 5% window pattern too (assuming you could find them).
P.S. Most of my GREYSCALE CALIBRATION FOR DUMMIES procedure is now up.
