Barco blue gamma slope/breakpoint, R&B midlights? Huh?
Goto page 1, 2, 3  Next
Posted: Mon Mar 31, 2008 3:46 pm    Post subject: Barco blue gamma slope/breakpoint, R&B midlights? Huh?
Newer Barco's like the 's' series 808s, 1208s, 1209s, and Cine series (as well as my Barco Cine 8 Onyx clone) have the following service menu adjustments:
- Blue gamma slope (bar scale with about 6-7 ranges)
- Blue breakpoint (0-99)
- Red midlights (0-16)
- Blue midlights (0-16)
Anyone have any official documentation on what exactly what they do? The manual is somewhat useless. I've played with them and can offer the following comments but any additional info is appreciated:
From what I can tell, the blue gamma slope plays with the blue gain: When setting it higher, you get more blue in the higher IRE's. The blue breakpoint sets the 'breaking point' where the increased blue output starts from a range of 0-99. Setting a lower number seems to start the increased blue at higher IRE's only. Setting a higher number seems to bring the point where blue starts to increase down to lower IRE's. It doesn't seem to have much affect under 50IRE however, even with the blur breakpoint set to 99.
I've been playing around adjusting my greyscale recently and have always had a blue hump in the middle that dies down at the higher IRE's and goes too low like this (see the blue line):
If I increase the blue gain to pull the right side of the blue higher, the middle area goes even higher still. Not good. What I want to do is lower the blue hump in the middle and raise the right side of the blue so that a have a flat line.
By using the blue gamma slope and breakpoint, I've managed to only add some blue gain to the higher IRE areas (above 60-70 IRE) to flatten out the line. I'm still playing with perfecting this so no new readings yet or graphs yet. (The ones above were when I used a Minolta CA-100 to do greatscale - I'm now using a Spyder2 sensor with the free HCFR software - quite the bargain! Great greyscale for $60! I've heard that the Spyder3 ($165) is even more sensitive so it may be a better option for someone buying new).
Red and blue midlights seem to add a hump in the middle IREs Default is blue=0 (no hump) and red=7. Haven't tested midlights very thoroughly though since I don't need to use them.
danOO00
Posted: Mon Mar 31, 2008 5:31 pm    Post subject:
Hi Kal
I had an almost identical blue hump when I first started doing grayscale with HCFR and the spyder2 on my NEC PG. A bit of additional electronic blue defocus flattened out the hump so its almost nonexistent. The extra output of a defocused beam will compensate for the loss at the high end.
I dont know squat about the barcos, but try a little bit of blue defocus each run through the grayscale until you get to the point where the hump is as flat as it can be without the blue halos becoming distracting.
Dan
Posted: Mon Mar 31, 2008 5:36 pm    Post subject:
Ooops - I should have mentioned this above, but the graph I posted is with my blue electronic focus set to 0 (on a scale of 0-100) where something around mid-point is perfect focus. So I'm already defocussing blue like crazy - in fact, as far as it'll go. The bump is bigger when blue's not defocused and the slope at the right is a lot steeper.
Blue halo's are not distracting or even visible from the seating position even with blue completely defocused.
danOO00
Posted: Mon Mar 31, 2008 5:58 pm    Post subject:
Did you try it out with blue focus at 100? I am not sure if the over/under focus matters at all, but I remember someone mentioning it in a thread a while back.
Also my electronic focus on the PG was not able to compensate enough for the blue, so I defocused it some more on the deflection board pot. This location is probably PG specific, but I would guess your set has a similar hard adjustment. If you aren't seeing blue halos, I would guess that you can defocus some more to see a difference.
WTS
Posted: Mon Mar 31, 2008 6:11 pm    Post subject:
Hi Kal,
That's one ugly blue line you got there and the red doesn't look that good either. I had to play with the blue and red adjustments too but in the end I got all 3 colours ruler flat for my grayscale. I don't recall exactly what I did as it was a while ago, my blue focus is set to the best focus not defocused. I use the HCFR probe and software.
Walter
Posted: Mon Mar 31, 2008 6:35 pm    Post subject:
That's a good idea. I'll try that. I could have sworn I checked which way to go (under or over focus) way back when I did this about 2 years ago.
Not sure if the Barco has any sort of adjustment, but I've already defocused so far that I wouldn't want to go any farther. Subtle halo's are visible at up the screen when viewing white on black text, but not at the seating. I'm not sure I'll get any more blue drive out of going farther. Actually: I just though of something - instead of defocusing as far as it goes (down to 0) I should be taking a light output reading (the "Y" value) with a 100IRE box as I defocus and stop at the point where the light output stops increasing. There's no point in defocusing any farther if there's no increased blue output.
It looks bad but in fact it's miles better than the default Barco 6500K settings for gain/cutoff. Those just suck - the picture looks all wrong. I've been living with this for about 2 years now and have been very happy with it.
I finally started to use my Spyder2 sensor with the newest version of HCFR and it works great... this is all in anticipation of trying out your new boards Walter so I figured I should make sure I could get my greyscale as flat as possible before installing the new ones.
With the gamma slope/breakpoint I've actually managed to get something almost completely flat from 20-100IRE. I'm almost there. I ran out of time last night.
I also want to document the whole procedure so that even a complete newbie can do it from start to finish. With the sensors being as cheap and realiable as they are today, and the software being free, there's no reason for anyone to NOT do this. The before/after difference will be huge in most setups. Having perfectly flat greyscale is another one of those things that you thought you didn't need until you saw it. I also thought my projector looked pretty good... until I saw what correct colours actually were.
You should post your results from HCFR Walter. I'd be curious to see them. The RGB graph with the values and the primaries too, gamma curve too.
zGman
Posted: Mon Mar 31, 2008 7:20 pm    Post subject: BG808S Colorimetry
Greetings,
I have spent a lot of time fiddling with my Barco's (G808SLC, P16 tubes)
and Colorfacts, and have achieved some decent results. Here are some thoughts.
You are right, the manual has almost no info - a little more can be picked
up in the service manual theory of operation.
The red and blue midlights are very powerful and key to good results.
Blue midlight will end up at zero, red (which operates in reverse) somewhere
around 4 to 6.
You shouldn't need much blue defocus at all, just a couple clicks. And it is true
that one way is better than the other, but its been a year since, and I can't recall.
I found that the contrast setting was totally basic to getting good greyscale,
and ended up with brightness at 42, contrast at 75 for adjustment - 72 for movies, etc.
If you try to run contast too low you will never get rid of the blue hump.
It is easy to chase the bias settings down into the weeds, and that will kill the top end.
In other words, if you find too much of one color at low ire, raise the others to compensate
instead of lowering the first.
It is best to start with the blue Gamma functions at factory defaults, but the midlights as above.
The meters can be very misleading on the lowend, the main focus is to get the G2 pots set correctly,
(never mind the LED's) and then use the lowend patterns on displaymate and colorfacts testpats
to ensure that all the tubes come up at the same time when you go from a 0 IRE to a 5%IRE
full screen (colorfacts testpats)
Once you can get them to come on at the same time, then you can step through the
fields and see if the lowend is roughly grey. Small Bias adjustments can make a huge
difference - and interact with Gain, so don't try to fine tune the bottom end until
you have dialed in in the top and midrange.
I wil be working on Barco's again soon, so maybe we can come up with a more
refined procedure.
Cheers,
Galen
Posted: Mon Mar 31, 2008 7:37 pm    Post subject: Re: BG808S Colorimetry
Thanks for the input Galen - very good advice all around.
around 4 to 6.
Can you comment at all on the red/blue midlights at all? Do they in fact increase gain around the 50IRE area or am I mis-assuming what they do?
Posted: Mon Mar 31, 2008 7:52 pm    Post subject: Re: BG808S Colorimetry
I run mine at 65. Very bright for me.
Did you get something backwards in this last paragraph Galen? BIAS controls the high IREs, and CUT-OFF the low IRE's.
Very interesting. I think I'll do that. I've had problems getting it flat at 5-15 IRE.
So if I understand correctly, you're saying put all settings in the projector to more or less 'default, then put
up, say, the 10IRE pattern (is this a good one) and use the sensor to adjust the G2 pots instead of the LEDs. Interesting.
This makes a lot of sense. Then you just have to tweak the cut-offs slightly as you do your greyscale probably.
I like this idea. I was always using the pots but then have a hell of time getting the cutoffs to work right at the very low IRE's (5-15IRE) and also in the 20-40IRE range.
Thanks for the info. I'm going to be reading this again and again for sure.
I want to put together a generalized procedure for this to be used on our website, so I'll be posting it for others to critique before it goes out in a newsletter and gets posted on the site.
zGman
Posted: Mon Mar 31, 2008 8:44 pm    Post subject: BG808S
OK, that's a lot of questions, but more fun than actually working....hohoho!
1st, yes - very backwards, bias, gain, cut off, etc - mostly Marquee stuff for a year!
However, my all notes show cutoff for lowend, and Gain for high end for Barco.
Midlights - very much control middle part of response curve, not just 50IRE, but(!)
red works backwards (eg. up is less, down is more) So, I always end up Blue=0,
red about 4 or 6.
Yes - set G2 pots with default settings, and brightness/contrast at 42/75.
I look into the lenses to set G2 pots(thanks Terry), the meter cant see it.
with the lowend block pattern from colorfacts testpats look for the lowest
block (2) to blend with the background and the second two (4) to just stand
out from the background.
The tube will not be completely off in the background, nor will the tubeface
be completely off at 0 IRE. (I consider this "idle", the tubes have some
excitation but no light is being projected. You can test this with a lens cap.)
The correct setting will have all tubes come off idle at the same time from 0 IRE
when you go to the 5 IRE full screen white pattern, and hopefully not too
far from grey - but really its hard to see color at 5% or 10%, 20% is where you
can make a difference with adjustments and have some small chance of getting
a reading - but trust your eyes more. Displaymate has color block patterns,
and you can use the "low red" "low yellow" low green" and "black" blocks to
see if you are tracking right at the bottom.
I know that you may find 65 Contrast setting to be "plenty bright", but that's
not the point. The high end (Gain) settings will determine the actual tube drive level.
But what I have found is that the control circuit for Gamma seems to be calibrated
to a contrast setting of 75 or 80, so if you are only running 65 then your gamma
settings can't track properly. It is possible to set the Gains to get high output at
lower contrast settings, but it won't track. This is not a random observation, but
something I worked on for hours and hours.
I found the only way to get a greyscale within a couple hundred
degrees of 6500 from top to bottom, was to set those defaults of 42/75, set the G2 pots,
and then set the overall Gains with a colorimeter and a 90 IRE input to get 6500 approx.
Then you can check your white crush with the appropriate colorfacts test pattern.
Another thing that's important, is that its also possible to push the high end too far,
you can max the tubes out at 100 IRE, and then response goes nonlinear. In other
words, say I get 7 FtLamberts at 100 IRE, 6.5 FtL at 90 IRE, and 4.8 FtL at 80 IRE.
This is what I would call "crushed white", very hard to tell the difference between
90 and 100 IRE.
If you want to see the Blue gamma controls in action, put up a horizontal 20 step
pattern full screen and try sweeping the breakpoint, sometimes you can see the
blue shift through the pattern. I usually end up with breakpoint at about 1third scale,
and slope about 2thirds scale.
Let me know if this is helpful, I may fire up the G808S LC tonight or tomorrow
and get some numbers for you,
Cheers,
Galen
Posted: Mon Mar 31, 2008 9:20 pm    Post subject: Re: BG808S
Yup - that's right: for barco's it's cutoff for low end and gain for high end
red about 4 or 6.
Sure - of course, not just 50 IRE specifically but around the 50 IRE or so centerpoint (like a hill/hump).
FYI: Factory defaults for my Zenith 1200 for midlights are B=0, R=7.
I don't have colorfacts but assume it's like any or ramp pattern you can find.
(I've been using the AVS HD 709 Blu-ray Rec709 disc available for free - I don't really care if SD is off).
That's typically how I've had my CRT projectors set up as well. You get better low end response and a little bit of light output looking into the tubes isn't seen on the screen.
My spyder2 reads really well and consistently at 20IRE even at the default 300ms read time. But always good to use your eyes too, especially at the lower IRE ranges.
True. The default gain for green is 69 which seems pretty high. I've actually got mine set to 60 and left it there and then adjusted around that. I suppose I should go back to 69 for green gain (green cutoff is 50). I'm assuming that green gain/cutoffs shouldn't be adjusted. Adjust R and B accordingly.
Interesting. I'll have to try that then. I find however, that with my current gains (R=55, G=60, B=45) and my contrast=65 that going any higher than 65 doesn't put out much more light. Anything above about 70-75 starts to get fuzzier too.
I'm going to try this anyway however. I'm assuming you also set the gains/cutoffs to the default 6500K values before setting the G2 pots.
The defaults in mine are:
R: Gain=55, Cutoff=54
G: Gain=69, Cutoff=50
B: Gain=45, Cutoff=29
And do not look anywhere near right. I produces this:
(yuck!)
90 and 100 IRE.
Yes, this is maybe what I think is happening when I turn up the contrast much more past 70 on mine. You don't get more light output but instead crush whites (and less focus).
Is there a direct corrolation to ftL and IRE? In other words, if I measure the ftL output at 80 IRE, should I be able to determine what my 90IRE foot-lambert output (and 100IRE foot-lambert) output should be to make sure I haven't gone non-linear? Or wait a sec... is it 100% linear (hence the term non-linear) Smile ? Meaning if I get 4 ftL at 50IRE, I should get 8 at 100IRE? It doesn't seem to be that way. The last set of readings I took were (taken from HCFR):
10IRE: 0.043 FtL
20IRE: 0.211
30IRE: 0.538
40IRE: 1.032
50IRE: 1.724
60IRE: 2.564
70IRE: 3.641
80IRE: 4.942
90IRE: 6.489
100IRE: 8.243
Thanks - yes - this is the first thing I did to try and figure out exactly what the slope/breakpoint were doing.
I'm not sure what you mean by breakpoint at 1/3 scale - you mean around 33 out of 99? And slope about 2/3 of max?
Very helpful indeed Galen! Thanks a lot!
I need a Barco greyscale calibration expert like you around here to come over for a few hours and teach me a few things! Smile
r.bauer
Posted: Mon Mar 31, 2008 10:09 pm    Post subject: Re: BG808S
This is a very important starting point! (While we are at it, also set Peaking to Off.)
Your blue tube is loosing its output faster that the other two. This is very normal for a projector with 'some' hours on it. Only option is to lower your contrast setting. zGman probably has used a projector with new or at least very good tubes in his procedure. Usually you will find a projector which behaves like kal's, very normal for a projector that has seen normal use.
My projector, a BG1209s with an extremely low number of hours on the tubes, puts out 13Ft/L at Contrast 65 at 2.6m screenwidth. I can increase contast to 100 and get it to 22Ft/L. (Picture becomes a little greenish)
Older projectors max out at 5 to 8 Ft/L, at a screenwidth of 2.4m when measured. Ususally 9" projectors age slower than a 8" at the same screensize.
CRT's lose lightoutput over time, this is just how they age. A new CRT will easily have more than twice the lightoutput compared to CRT with a couple of thousand hours on it. And all tubes may be 100% white, they are just not like new anymore. For proper color balance one should replace green and blue (and also red) at the same time with new tubes, and not just drop in any replacement CRT, "because it was so cheap".
Even your old trusty regular CRT-tv at home will have 50% of its light left after 5-6 years of normal use. Projection CRT's just age faster.
This is why I love new tubes so much, nothing beats new tubes!
Posted: Mon Mar 31, 2008 11:07 pm    Post subject: Re: BG808S
Wait a minute... isn't long quality lifetime of tubes a mainstay of the CRT-vs-digital debate? It doesn't make much sense to pan digitals for dropping brightness after 1500 hours if CRTs are just as bad and cost ten times as much to replace!
zGman
Posted: Mon Mar 31, 2008 11:11 pm    Post subject: BG808S
Yes, that's true - both PJ's had new tubes, and could be very bright.
Are you saying, that for an older tube the solution might be to reduce
gain for green and red so that the blue can keep up. I could see that if
the blue was reaching an inherent limitation in output, there wouldn't
be any headroom for the blue gamma circuits to work properly.
Kal, your luminance curve looks pretty good to me. Good luck
with the greyscale tonight!
I am trying to make some of the stupid little bent metal (.030")
catches that go in the scan reverse switches, they fall
out when the silly little plastic spring retainer breaks...
Thanks - Barco!
G
WTS
Posted: Mon Mar 31, 2008 11:47 pm    Post subject:
Hi Kal,
It's been quite a while since I did the initial gamma setup where I adjusted out the humps using the midlights and the gamma curve adjustments. But I do recall it took me a lot of back and forth and trying different setting to finally get each tube flat lining. No I never did keep a file of the results even for the last time I tweaked the gamma. Normally I just setup the probe and fire up the laptop then set it for continuous sampling then go up and down the scale from 0 to 100 ire and tweak the gains/bias's as I go until they're all flat and overlapping each other from 20 to 80 or so then it's good to go. It doesn't take me that long to just tweak things.
I agree 100%, the factory setting are terrible and a properly setup greyscale makes a huge improvement.
Walter
Posted: Tue Apr 01, 2008 12:17 am    Post subject: Re: BG808S
Yup! That's always the first thing I do. Why anyone would want to add any fake sharpness is beyond me... Smile
My Zenith 1200 (aka Barco Cine 8 Onyx) was brand new when I first got it. Only 150 hours on it, 100 of which Barco puts on themselves to burn it in. I did my first greyscale calibration when it only had a few hundred hours on it. That was 2 years now. Now it has about 2000 and it still tracks the same way. Odd. I wonder if there's some sort of other blue gain control pot that's maybe off somewhere... like on the RGB Driver board. I actually have a new board to install tonight so I'll do that and reset the gains/cutoffs to defaults and redo the G2 and see if the blue tracks a bit better.
13FtL at contrast 65? That's pretty good. What's the green gain at? With my contrast at 65 and my green gain at the default of 69, I'm only getting 10.3 FtL (35 cd/m2). But then you have 9" tubes are mine are 8". Smile This was measured direct from the projector facing the screen. My current setup has the green gain at 60 (probably a mistake) and I get 8.4 FtL when measured bounced off the screen (8 feet wide, approx 2.4 meters).
Yeah, that's exactly what I've been doing too. The Spyder isn't the fastest at reading so it's a bit slower than when I used the Minolta CA-100 (which takes pretty much instantaneous measurements). I've also had to learn what the midpoints do and the blue gamma slope/breakpoint to help out the curve a bit. I find the best way is to do as well as you can first with gains/cutoffs and then map out the 0-100 to see where the problems are, then go and use the midpoint/slope/breakpoint adjustments if relevant to fix the problems, and then re-tweak the gains/cutoffs. It's a very slow process but worth it as you've seen.
r.bauer
Posted: Tue Apr 01, 2008 12:25 am    Post subject: Re: BG808S
zGman wrote:
I could see that if the blue was reaching an inherent limitation in output, there wouldn't
G
True. Every CRT in a projection system has its maximum output, it will simply not go beyond that point, no matter what you throw at it, contrast, gamma circuit, you name it.
Try it yourself, set up a windowed 100IRE pattern and increase the contrast, at a certain point one tube will stay behind, while the other two still inrease their lightoutput. In an ideal world you would have done this when your projector was new and when it was at 1000-2000-3000 hours, etc. You will see that (usually blue) starts to wear out first. All tubes will lose lightoutput, just blue will do it faster.
I have read somewhere that a projection CRT loses about half of its lightoutput in its first 1000 hours, but I can't find any proof of that.
General info about non-projection CRT aging:
http://www.repairfaq.org/sam/crtfaq.htm#crtdeg
Posted: Tue Apr 01, 2008 3:49 am    Post subject: Re: BG808S
What I need are longer arms to be able to easily look into the tubes (especially the red one) when adjusting the G2 pots. What a pain in the arse - especially ceiling mounted with 3 home theater recliners directly under the projector (see my avatar picture on the left). And why did Barco have to recess these damned G2 pots to make them so hard to find in the dark. Right on the G2 card too ... I'm liable to stick my screwdriver into something high voltage that I'm not supposed to. Smile
What's also a pain is that you have to be in the service menu "G2 adjustment" mode to do this adjusting, then you have to pop back out and see what the picture actually looks like at 5/10/20 IRE. I didn't realize that you can't adjust the pots while not in the G2 adjustment mode as otherwise the projector keeps re-adjusting to obviously compensate as the tubes change over time (makes sense).
I didn't get very far tonight. Will have to continue in the following evenings.
zGman
Posted: Tue Apr 01, 2008 4:24 am    Post subject: BG808S
Hi Kal,
I just do the G2 pot setup while inputting the test pattern, I haven't seen the "compensation"
effect that you spoke of, and haven't had any problem getting good results....unless of course
there really is some difference in these machines beyond the branding change....?
Yes, long arms and a steady hand...hohoho! not fun, especially balancing on a HT recliner!
actually it is helpful to bungee up the cover plate, and sometimes get a bit of help to make
certain the driver stays centered on the pot...
You asked about the colorfacts test patterns...I can send them, but at one time they were
available on the website. There are several very nice features, and the lowend pattern
has much finer graduations than a typical step pattern, which allow you to see more exactly
when the tube is just off "idle" (ok, ok, so I'm a car guy....)
The other thing I like is the 5% increment full screen patterns in R,G,B and white, which can be stepped
through using the arrow keys on a keyboard, which makes it easy to see when the tubes come on,
and easy to measure the relative luminance of each IRE step.
Displaymate is another great set of patterns, I can't recall where I found those, but it is very handy.
One thing that I had meant to mention, is that I would start all these adjustments with the focus, astig,
and convergence as perfect as possible. Light output is very dependant on these, and the blue defocus
should be just an intermediate step, after things are roughed in, and should not be more than a few clicks.
I still have a little work swapping lens bases to get my BG808S LC fired up, and the other BG808S
that's here has decided to act up, no doubt jealous of its neighbor with new tubes.....jeez...!
Cheers,
Galen
WTS
Posted: Tue Apr 01, 2008 1:14 pm    Post subject:
Hi Kal,
All I've ever done is adjust the G2 as per the book before I do the gamma. THe G2s rarely drift off more than a hair on my cine8, I doubt yours is any different.
Walter
Page 1 of 3
