Cheap digital that can satisfy the yearning for CIH?
Goto page 1, 2, 3  Next
Person99
Posted: Fri Feb 22, 2008 8:34 pm    Post subject: Cheap digital that can satisfy the yearning for CIH?
I posted this at the "other" site, and even though I hope for a diamond in the rough, I don't expect many good responses. I thought I would try here in case anyone is keeping up with digitals.
Bottom Line: Married white male desperately seeking a good looking PJ under $3000 (if built in vertical stretch) or under $2000 (if no built in vertical stretch) capable of looking good on a 50”x118” 2.35:1 screen in a bat cave. Installation flexibility is not a nearly as big of a concern as image quality. And about image quality, all I care about is film quality—don’t care about games, don’t care about sports—films, films, films. What PJs should I check out?
To set the baseline, 1.5 years ago I upgraded from my old CRT pj to a Barco Cine 8 Onyx—an 8” liquid coupled, color filter, high resolution tubed CRT. This is one of (and arguably) the best 8” CRT PJ ever made. The PJ cost me less than I’m willing to spend now and my picture is fantastic—so I’m spoiled, I expect a great picture at a cheap price!
So, why the change? The answer is twofold. First, I’m sick of my 16:9 screen. Having a projector with a 16:9 screen is simply having a big TV! I want a larger 2.35:1 image. So, I have two options:
1) Remount my CRT back further and do a pseudo-constant image area (CIA) set up based around a 2.05:1 screen.
2) Change to a digital with an anamorphic lens to do a CIH set up.
The second reason is that I may move to a location with a less CRT-friendly room to set up in. If this occurs, number 1 is not an option.
The main problem with number 1 is that I can’t achieve the image size I want. Although my PJ can do a great 1080 with a CIA set up, CRTs have zero mounting flexibility. Thus, even sliding the PJ back to partially obstruct my second row’s aisle will only get me a 16:9 image of 49”x87” and a 2.35:1 image of 42.5”x100.5”. With my current 16:9 screen, 16:9 images are 52"x92" and 2.35:1 images are 39”x92”. So, I lose a little on the 16:9 size to gain not much on the 2.35:1 image. Almost doesn’t seem worth it.
So, the digital search began. I thought about losing resolution over what I have now and going down to a 720p PJ until a great 1080 PJ got really cheap. But, this proved to no avail. 720p DLPs and LCDs have way too much SDE from my preferred viewing location (<1.5x image width from the 16:9 image). The single chip DLPs also concern me as I see RBE constantly with a 4x color wheel and sometimes with a 5x color wheel. Not only that, but I sometimes get “DLP fatigue”—further given that about 10-15% of humans suffer varying degrees of DLP fatigue, even if I didn’t, I’m not sure I’d want a DLP because it might bother my visitors.
I considered a 720p Panny LCD due to the smoothscreen. But they look horrible. Flat, un-engaging images. The 900 had terrible blue-blacks, every AX100 I’ve seen had such horrible uniformity issues that made the minor color shift of my CRT look great! So, I’m not sold that Panny even knows how to make a good looking PJ!
So, I looked at a used JVC 1400x788 LCoS (HX1 and HX2). Good looking image for high APL scenes--no RBE, no SDE, …and NO CONTRAST. Low light scenes where terrible with a “haze” over them and fade to blacks were just comical.
So, on to 1080p LCDs. Given the dirt cheap price of the HC4900, I went for some critical viewing of my neighbors HC5000. First off, quality issues have me troubled. His first one developed a green line in the image, and this second one has some stuck green pixels that I find distracting. That aside, the image was not really impressive after watching for awhile. Oh, it was sharp all right and color accuracy was very nice. But, who in the heck are they trying to fool with that claimed 10,000:1 contrast ratio!!! Give me a break—the D65 calibrated contrast ratio is closer to 3000:1—pretty much looked the same as a DC2+ 720p DLP—and that was with the uber-distracting auto iris (every fade to black was a fade to light grey followed by the auto-iris clamping it down to medium grey). Disengaging the distracting iris put the CR under 1000:1—it looked as bad as the JVCs mentioned above. I’m used to perfect convergence and the green and blue where a half a pixel off. So everyone’s face had a green shadow on the left side and a blue shadow on the right side—again, very distracting. Lastly, the SDE was too bad to sit at my preferred viewing distance. The inter-pixel spacing on this 1080 LCD looked to be about the same size in the projected image as the inter-pixel spacing on a 720p DLP. So, it really needs to be watched >1.7x image width from a 16:9 image.
The only other PJs I can think of trying to see:
- Epson 1080UB (but I’m afraid it will have the same SDE and quality issues as the HC5000 I saw)
- Panny AE2000 (smoothscreen will take care of the SDE, but have they improved their image quality?)
- Optoma HD80 (Optoma quality, or lack thereof, scares me a little, but even though the 6x color wheel should eliminate RBE, I’m still a bit worried about the DLP fatigue)
Are any of these really worth trying to check out? Is there some PJ I’ve missed (new or used) that would be better in the price range then everything I’ve seen? Or, am I SOL?
Posted: Fri Feb 22, 2008 8:51 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
Friend of mine's awaiting his third one... the other 2 had bad (unacceptable) convergence that even Epson deemed not ok. If they're not ok, why do you ship them? Oh, wait, now I remember: Because most people are willing to accept CRAP so you make the end users do the testing!
I haven't seen the projector running properly set up yet so I can't comment on it.
I guess the JVC RS1 (definitely the RS2) are out of your price range. Maybe a used RS1 from someone upgrading to an RS2? I've never seen either but I think you're going to not be happy until you get into this sort of price range Dave. I know I probably wouldn't be, and I have the same projector as you.
I'd love to do CIH too but I'm limited to an image 8' wide. I'd like the 16x9 image to be 8' and stretch the 2.35:1 image out to 10.6 feet wide. Just isn't going to happen in my current house give that my L/R speakers are 48" high and 20.5" deep (and like to be out from the wall at least 2 feet).
Person99
Posted: Fri Feb 22, 2008 8:59 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
Yeah, after you add in the lens, that is over double what I'm going to be able to get out of my current equipment, so it breaks the budget!
I've viewed the RS1. Maybe it is because I'm spoiled because of how much we pay for our CRTs, but I didn't think it was the cats meow like everyone else seems to. It was good but not "all that". I'd say an appropriate price for it was about $2500 new. A 909 or G90 is way better, and our PJs compare VERY favorably with it.
Posted: Fri Feb 22, 2008 9:05 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
Yup. And that's why even if I could do CIH, I hightly doubt I'd switch. Yes, CIH would be nice, but that would be the only benefit. Just about everything else would be worse.
Unless something miraculous happens in digital PJ land, I don't see myself getting rid of this Zenith 1200 for at LEAST 5 years. When I switch I want it to be because something noticeably better is available for under $5K, not something that's "about the same". What's the point of a sideways "upgrade"?
Person99
Posted: Fri Feb 22, 2008 9:15 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
Perhaps it is because I have "upgrade-itis" but I see CIH as more than a "sideways" upgrade. Everything equal plus CIH is an upgrade to me--so I would take a digi that was equal to ours.
When SD DVD was all we really had, CIH was not that big and SD DVDs can only look so good so big. Then came decent providers and HD on cable. Then I didn't want to watch SD DVDs any more! Still, you didn't need CIH because most of the movies were pan and scan. Of the 100 HD movies I've recorded to D-VHS and the more than that I've watched on HD cable, only a handful were 2.35:1 OAR (The Incredibles and the 6 Star Wars are the only that come to mind).
Then came HD DVD and BD. High def OAR movies--woo hoo. The Matrix, Serenity, V for Vendetta, Transformers, etc. Everytime I put one of these 2.35 discs in, I can't get through the whole movie without being discouraged by my "tiny" image. I don't have a theater, I have a big TV in a dark room! Crying or Very sad Crying or Very sad Crying or Very sad
Posted: Fri Feb 22, 2008 9:52 pm    Post subject:
Yep, there's something to be said about a bigger screen with 1920x1080 content. You can go pretty big before it starts to get soft due to individual pixel structure. In fact, you'd have to go 6 times the area to make it the 'same' softness as DVD.
You could easily have a screen 50% wider and it would still be much much sharper than DVD.
scottap
Posted: Fri Feb 22, 2008 10:00 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
You're going to have to get an anamorphic lens for any of those projectors on your list and perhaps a scaler as well to do the squeeze, unless you imagine just using the zoom lens just make a bigger image. A DLP isn't as inflexible as a CRT with setup, but it's not that great either (limited zoom range, vertical shift, etc.) I still think the RS1 beats any LCD on black levels and intrascene contrast, so if you don't like the RS1, I don't know you're going to like any of the others. If you do get a digital, make sure it has a real color management system. The RS1 doesn't and sometimes skintones can get a little orange (not unlike a crt with unfiltered lenses).
Person99
Posted: Fri Feb 22, 2008 10:05 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
Anamorphic lens is already in the budget (not reflected in the PJ budget). The reason I put different prices for with and without build it V stretch is to pay for the scaler! Smile
I didn't say I didn't like the RS1 at all! And I do think it beats any LCD. The "cartoony" colors was my biggest objection. I'm just saying that listening to the digi guys at AVS and reading mag reviews, you would have thought the RS1 was the second coming when it was released. So I checked it out and my opinion was basically that it was not really better than what was hanging in my theater.
paw
Posted: Fri Feb 22, 2008 10:09 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
The RS2 is susposed to have a built-in video processor to the the squeeze. With the RS1, you still need the scaler.
Aubrey
Person99
Posted: Fri Feb 22, 2008 10:21 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
I has a vertical stretch. I'll take an RS2, know where I can get one for my $3000 budget? Smile
scottap
Posted: Fri Feb 22, 2008 10:28 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
And you'll still need to budget for the anamorphic lens. Maybe you should look for an RS2 where the seller will pay you to take it. Smile
Person99
Posted: Fri Feb 22, 2008 10:32 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
The lens is accounted for in the total budget (as is screen, masking, etc), but these costs all all fixed--they don't depend upon the PJ. After taking those out of the total budget, that leaves almost $3000 for a PJ if it has built in stretch or about $2200 for the PJ if it does not.
Posted: Sat Feb 23, 2008 2:17 am    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
It is to them. Remember what they were coming from! Wink
I rest my case.
Posted: Sat Mar 01, 2008 6:54 pm    Post subject:
Umm, that is what Clarence has been saying except he was a little more eloquent. Mr. Green
Dave,
I am having trouble getting my head around your budget and everything you plan to purchase. Could you lay it all out and your budget for each item? My guess is you are buying these:
Digital -
PJ - $?
Scalar - $?
Anamorphic Lens - $?
Screen - $?
Masking - $?
If that is correct, then my advice would be to go with an 8" blend. The TVone is supposed to be including most of the features that people look for in a good processor plus blending. Two of the cheaper models should set you back about $2500, which is around the price of the other vps these days. The only other thing you need is another pj. My advice would be to sell the Barco and get two 8500LCs. The blend would solve both your desire for 2.35 and installation issues. You would also get the added advantage of lumens and a much sharper image running each pj at roughly 1080x815p@72. I am not sure if your new house would be able to accommodate the blend. In that case, don't move there:). Actually, I would say wait for the new Sony LCOS that is supposed to be around $2500.
Person99
Posted: Mon Mar 03, 2008 11:32 pm    Post subject:
Spanky Ham wrote:
Dave,
Digital -
PJ - $?
Scalar - $?
Screen - $?
Masking - $?
This is an interesting (and highly desirable) idea but would cost more. Let's forget the screen and masking expense as regardless of the solution, these are the same.
For arguments sake, lets say I'll use a scaler for a digi solution. For my purposes, the scaler just needs to:
1) Deinterlace film-based 1080i.
2) Do frame rate conversion of film content to 24 Hz.
3) Perform the scaling for the vertical stretch.
A used lumagen HDP for $750 is quite capable of performing all these operations well (and does the vertical stretch as well as many other scalers costing more).
As for the anamorphic lens, I'm not sure if I jump in all the way at first and spend over $2000 or not. There is a very good chance that I would start with a coated two prism solution for $600 since I'm going to have a curved screen to handle the pin cushion, the Lumagen can handle the color temp differences from the lens, which only leaves me with some CA at the edges. So, lets say I do that. So, that means the budget is:
Lumagen HDP - $750
Lens - $600
Projector - ?
If I got a used RS1 say, that would be $3200. That would put the total cost for this stuff at $3850. Now, if I sell my PJ, tcoders, HD Fury, dtrovision, Jean port 3 barco module, calbes, extron, etc (all the stuff no longer needed), even a low ball puts this at over $2000. So, my out of pocket for the above is less than $1800.
There is no way I can sell what I don't need plus my PJ, then get the TV One scalers and 2 good 8" PJs for anything close to $1800. Two good PJs plus the TV One will cost me about $5500. I won't be able to sell as much stuff as the other scenario, so my out of pocket will have to be at least $1000 higher--but worth considering.
8500 LCs are hard to find (let alone two). But, even if I could, I wouldn't want them. I'm soooo not impressed with the Marquee picture. NEC XGs are too loud (in fact, getting a quieter PJ is an advantage of the digital--virtually no background noise would be nice) which means I'm likely to have to go with two G70s and the parts hassles that come with.
The questions I have, hasn't TV One said they were going to do a good blending scaler for over 1 year? Why should we believe it will ever come and it will be good?
So, after typing the stuff to advocate the blended CRTs, your conclusion is to buy the new Sony LCoS?
benareeno
Posted: Tue Mar 04, 2008 4:07 am    Post subject:
I go back and forth down this road so often...as most of you know, it's ridiculous!
Digitals can have nice pics in brighter scenes...and not as nice pics in darker scenes.
Digitals can be virtually silent (a HUGE plus!!!) - crt's are far more difficult to get to this level of nirvana, unless you're one of McGyver's on the forum (Yes Kal, I'm talking about you).
Crt still has the best pic, case closed......crt is a pain in the ass, case closed!
See, I still can't figure this damn thing out!!
In retrospect, I had my most enjoyable movie viewing on a 27" tv about 12 years ago with a Harman Kardon (then high end) receiver and B&W speakers...I watched tons of flicks on LD and dvd. I loved it...since I started into projectors, I don't watch movies. I just tweak the projector. It's fun, but not rewarding...
As long as the projector is loud, I don't bother with a good movie...it would be ruined by the noise. THen there's that one little convergence or focus issue...etc etc.
I also strive for a CIH setup...with an acoustically transparent screen. I've run CIH with crt's...seems like a good option to me. But something always holds me back from loving it. Hmmm....where's that 27" tv I had?
Fujifrontier
Posted: Tue Mar 04, 2008 3:02 pm    Post subject:
You should get a little Sony like mine Laughing
Posted: Tue Mar 04, 2008 4:14 pm    Post subject: Re: Cheap digital that can satisfy the yearning for CIH?
Person99
Posted: Tue Mar 04, 2008 4:18 pm    Post subject:
Yes I do, and it is VERY stretched. But I'm not showing you!
Posted: Tue Mar 04, 2008 4:22 pm    Post subject:
I appreciate that. Please don't show me your flower mound, either.
Page 1 of 3
