The
new version 3 card includes special improvements for
greater sharpness, higher bandwidth, less noise, and more. See the
manual for full details.
FREE WORLDWIDE PRIORITY SHIPPING INCLUDED
Marquee VIM-FULLHD v3 HDMI 1.3 Input Card with
remote
Regular price: $410 USD
Our price: $348 USD
Sign up
today to receive the latest VIM-FULLHD news
Free priority shipping to anywhere
in the world included.
Payment methods include PayPal and all major credit cards
(PayPal account *not* needed to pay by credit card).
Our payment processor
will automatically convert the
amount to
your local currency.
Orders ship direct from the
manufacturer in Taiwan.
Warranty: 1 year all parts and labour.
Upgrade your Electrohome Marquee CRT projector by
adding two HDMI 1.3 inputs with gamma correction and infrared remote
control. Don't be stuck watching PS3, Blu-ray, HD-DVD, and DVD at only
480p. Add digital HDCP-compliant HDMI 1.3 inputs allowing you to watch hi-def
content at up to 1080p resolution.
Widescreen
Review Magazine uses Moome HDMI cards in their reference theaters featuring Sony
G90 and Runco 1200 CRT projectors. "We love our 9-inch CRT projectors,
even though we have our pick of the leading edge D-ILA, SXRD, and DLP
projectors." - Gary Reber, Editor-in-Chief and Publisher, Widescreen Review
The VIM-FULLHD card allows you easily connect digital devices such as
Blu-Ray players, PS3/PS4, Xbox360/XboxOne, Satellite/Cable HDTV set-top boxes, and HTPCs
with HDMI graphic cards (to name a few) to your Marquee CRT projector. Simply
plug the card into your projector, your DVI/HDMI devices into the card, and
watch.
This product is a culmination of everything Moome has learnt
over years of building DVI/HDMI input cards for CRT projectors. It is by far the
highest end Marquee card he has yet to offer with new features such as: Two 100%
HDMI
1.3 compliant inputs for Deep Colour support, better discrete 14bit D/A converters,
faster 1GHz
output buffer, and better op-amps for the best image
quality possible.
Supply is limited and tends to sell out fast as this high-end
product for the discriminating videophile is only built in small batches. This
is the last HDMI input card you will ever buy for your Marquee CRT projector.
Need to add
an HDMI switcher or HDMI cables? See our
recommended HDMI
switchers & cables.
Works with all Electrohome Marquee CRT projectors and clones:
Marquee 8000, 8110, 8110+, 8500, 8500LC, 8500LC Ultra, 9000,
9500LC, 9500LC Ultra
Accurate Imaging Technologies Accurate 8, 9, XL
Accurate Imaging Technologies Integrated 8
Accurate Imaging Technologies Modular 8,9
Accurate Imaging Technologies Ultimate 8-X, 9-X
Crystal View CV-1, CV-2, CV-3
GTT Audio Video HT Reference 8, 9
Madrigal MP-8, MP-9
Reference Imaging CinePro 8x, 9x, 9x Elite
Spatz Tech RE8000, RE9000, RE9500
Theater Automation Wow (TAW) HD-800, HD-900
Vidikron Vision 1, 2, 3
Visual Dynamics Reference 8/9
Also works with the Marquee switcher.
Manual
VIM-FULLHD v3 owners manual
(PDF format)
What's new in
Version 3?
The new version 3 board adds the following new features:
Marquee switcher support: You can now use the card in
a Marquee switch box instead of directly in the projector. Older cards did
not work in Marquee switchers. Please refer to the manual for the special
DIP switch settings.
DTS-HD / Dolby True HD lossless audio support: Allows
you to use an HDMI receiver or pre-amp between your Blu-ray player and
projector to decode lossless audio. Previously this did not work correctly
due to the HDMI card's EDID. The EDID has now been updated so this
will work.
Cleaner video power: A large coil filter has been
added to clean up the video power, further reducing image noise.
Manual selection of input color mode: The previous card
auto-detected the colour space. While this typically works correctly, some
users like to be able to force the colour space mode. This is now possible using 4 new buttons on the remote:
Button 4: Auto Detect Input Colour Space
Button 5: Set Input Color Space at YCbCr 422
Button 6: Set Input Color Space at YCbCr 444
Button 7: Set Input Color Space at RGB 444
Remote control beep confirmation: In the past it was difficult to know if the card is receiving the signals when you press
buttons on the remote. The card now 'beeps' every time you press a button to
give you positive feedback.
What's new in Version 2?
Complete information on the changes can be found in the
Moome v2 card comparison document
(PDF format). Below is a quick summary:
Feature |
VIM-FULLHD v2 |
Gamma |
Improved Gamma for
more linear greyscale (changes suggested by Walter/WTS) |
Sharpness |
Sharper Image |
Picture purity |
Cleaner/Less noise |
Range expansion |
Now supports 0-255 RGB
level support for higher dynamic range (in addition to 16-235) |
Stability |
ESD enhanced to
prevent electrostatic discharge |
Features
Two HDMI 1.3 inputs
Supports deep color mode for 10bit and 12bit
HDMI 1.0, 1.1, 1.2, 1.3 ,HDCP 1.1, and DVI 1.0 compliant
DTV mode support (480P,576P,720P,1080i,1080p) at 50, 60, 72,
and 75Hz refresh rates for all resolutions.
PC mode support VGA, SVGA, XGA, SXGA, UXGA etc.
Supports 4:4:4 RGB / YCbCr input
Supports 4:2:2 YCbCr input
Supports both 16-235 and 0-255 color range and auto selects
the correct range
14bit Data processing with three high precision 200MHz 14bit DACs
for conversion to analog RGB
Improved
advanced gamma boost for perfect shadow details and gamma
tracking
Improved
adjustable white level (contrast) boost for output from 0.7V-1.0V for
perfectly matching a display's expected input voltage
High speed 1.5GHz output Buffer
Supports 120Hz at 720P and 1080i
Toslink output, supporting up to 2 channels of PCM
(uncompressed) or 8 channels of compressed audio
(This is a convenience only feature. You do
not need to pass the audio through the VIM-FULLHD. Most people will connect
their source devices directly to their receivers with SPDIF or HDMI cables).
IR control for input selection and gamma boost
adjustment
Ultra
low ESR capacitors to filter noise providing an extremely clean image.
ESD
improved to prevent electrostatic discharge damage while plugging in HDMI
cables
![](images/EXT_FULLHD_info1.jpg)
![](images/Moome_HDMI13new.jpg)
![](images/Moome_HDMI_deep.jpg) What's new in HDMI 1.3?
The HDMI 1.3 specification was released in June 2006 and
includes the following new features:
Bandwidth more than doubled from 165Mhz (4.95 Gbit/s) to
340Mhz (10.2 Gbit/s) to support high resolution, faster refresh, and deep
colour.
Extended colour gamut for more natural and realistic
colours: Deep Color with 30-bit, 36-bit, and 48-bit xvYCC, sRGB, or YCbCr
compared to 24-bit sRGB or YCbCr in previous HDMI versions.
Support for lossless digital audio such as Dolby TrueHD and
DTS-HD Master Audio (not relevant on this device).
Automatic audio syncing (lip-syncing) timing compensation
Pictures
![](images/Moome_VIM-FULLHD_v2.jpg)
Reviews/Testimonials
"Moome's original design squashed (attenuated) 65% of
the full bandwidth when running 1080p 60Hz. With the new circuit, the FULLHD
v2 now can resolve the entire 1080p 60Hz signal. With Moome's new design his
card is the first and only option that can do full 1080p and YCbCr... the image
is amazing!" - Craig Rounds, official FULLHD v2 tester, professional
calibrator (www.cir-engineering.com)
"Well the VIM module is installed in my Marquee 8500 and I
love it! Moome did nice job with it. As others had stated, it's worth the
wait." - Robert M.
"... sharper that the old Moome Marquee HDMI card."
- Napos
"Recently I bought a new Moome HDMI 1.3 input card for my Marquee, to be
installed when I rebuilt and refurbished my 9500LC. I'm no stranger to Moome
products. I've been using a Moome DVI input card on this Marquee for quite some
time... Well, I'm really impressed! I've got my brightness set low enough
that when the picture goes to mute, you don't even really see ANY light on the
screen. Black is REALLY black. I'm seeing more detail in the dark images than
I've EVER seen before out of ANY display system. I can freeze frame a dark
scene, crank up the brightness to see what details I'm missing, and discover
that there AREN'T any. Even uncalibrated, I'm seeing incredible detail in
dark scenes while keeping a really solid black level. I am very impressed
and have nothing but good things to say about this card's performance,
though as of yet I have not explored any of this card's extra functionality."
- CJ (CMJohnson)
Need more information? See the Marquee VIM-FULLHD FAQ
Visit the Moome Discussion/Support Forum
Questions should be directed to the PJI-HD company (Moome) at:
moomecard@curtpalme.com
When
purchasing you will be paying and
dealing directly with the third party
seller 'PJI-HD/Moome' in Taiwan.
DISCLAIMER (Legal mumbo-jumbo because we have to): Any dealings with the third party
seller/manufacturer listed here, including the delivery of and the payment for
goods and services, and any other terms, conditions, warranties or
representations associated with such dealings or promotions, are solely between
you and the third party seller/manufacturer. Curtpalme.com shall not be responsible or liable for any part of any such dealings or promotions.
CURTPALME.COM IS NOT THE SELLER OR MANUFACTURER OF THESE PRODUCTS OR SERVICES.
THE SELLER/MANUFACTURER MAY HAVE PROVIDED A WARRANTY ON THE GOOD(S) PURCHASED.
CURTPALME.COM HAS NOT MADE, AND DOES NOT MAKE, ANY REPRESENTATION, WARRANTY,
PROMISE OR COVENANT, EXPRESS OF IMPLIED, AS TO THE CONDITION, QUALITY,
DURABILITY, CAPABILITY, FUNCTION, PERFORMANCE, OR SUITABILITY OF THE EQUIPMENT,
ITS MERCHANTABILITY OR ITS FITNESS FOR ANY PARTICULAR PURPOSE. BUYER AGREES THAT
CURTPALME.COM SHALL NOT BE LIABLE FOR EITHER SPECIFIC PERFORMANCE OR ANY
LIABILITY, LOSS, TAMPERING, ABUSE, DAMAGE, INCLUDING CONSEQUENTIAL AND
INCIDENTAL DAMAGES, ARISING OUT OF BUYER'S PURCHASE OF THE EQUIPMENT, ANY
DEFECTS IN THE EQUIPMENT, OR FAILURE OF SELLER/MANUFACTURER TO TIMELY DELIVER
THE EQUIPMENT.
