Tube Condition (Wear)
Example of a Poorly Installed Set
Without trying to make fun of one of my customers, here’s what can happen
when you install a CRT projector about 20% too far back from the recommended
screen distance. You get insanely premature tube wear as shown below. The raster
was not centered, the image is far too high on the tube face which can cause
convergence instability over time, and the wear shown should happen towards the
end of the tube life, not two years after the set was installed.
Remember to read the throw distance charts in the manuals, most of them are
darn accurate!
![](images/tube_poorinstall_01.jpg)
![](images/tube_poorinstall_02.jpg)
While following the manual for throw distance is always a good bet (and
recommended for new users), to maximize tube life even further do the following
steps:
- Put the projector on the cart or simply leave it on the floor
so that you can move it.
- Display something that fills the screen entirely (like a grid test pattern).
- Using only the green (middle) tube,
look into the tube and increase the image width on the tube face until it is around 1/8" to 1/4" from the edge of the white phosphor.
Under no circumstances should you allow the
image to go off of the white phosphor surface!
- Move the projector back and forth until the image fits your screen.
- THAT is the correct throw distance
for optimal phosphor usage.
It'll usually be 5-8% closer than what the manual tell you because the
manual throw instructions are conservative since they make you install blindly
without even looking in the tubes at all.
Here's an example of correctly optimized phosphor usage (see below).
Notice how the grid is very close (but not over) the edge of the phosphor.
![](images/tuberastersetup3.gif)
Note: It is recommended to use an external grid/test pattern from your actual
source device for this (and not the internal one shown in the picture above) as
the image width may vary between the two. When first setting up your
projector for various devices and resolutions, always take a peek into the tubes
to make sure your image is not going off the edge of the white phosphor.
Did you find this information useful? Please consider making a
donation to help defray the cost of managing and hosting future
articles, tips, and documents. |
Or
purchase
from
Amazon.com
and a small percentage automatically
goes to support this site at no extra cost to you! Visit their
Blu-ray and
4K UHD
stores for sales.
Want to show off your
home theater? See our
Blu-ray Release List & Must-Have Titles. |
