    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Panasonic 1083/1085
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 3)
Page: 1 2 3 4
Notes
If your remote won't allow you to do any geometry or convergence adjustments, try the following:
  1. There's a switch in the battery compartment of the remote which needs to be set 'on'.
  2. Try pressing the ID buttons on your remote. It's possible that your remote has different ID than your projector (same thing as 'address' function on Barco remotes). Different ID allows you to do some basic operations but none of the ones needed in geometry adjustments.
Accessing the 16 different memory settings for RGB input mode:
When you input a new frequency (new resolution/refresh rate), press test key and save your settings pressing the store key twice. If the signal you're inputting is same as one previously saved, it will use the same memory location.
Every resolution/refresh rate/sync type etc. combination can have only one memory setting (A1-A8 etc.). Each memory setting can have three different settings, for example for different aspect ratios (A1-1, A1-2, A1-3, A2-1 etc.). Press test and aspect key to create a new aspect memory and follow instructions. You can change the aspect memory with aspect key.
You need the original remote to set up projector OR you can download files for various programmable remotes (ex: Phillips Pronto) from remotecentral.com.
Try and get the original Panasonic ceiling mount if you can. Not only it's the best I've seen (just lift your projector to this mount and that's it!), but it's not very simple to make one of your own.
... Previous Page Next Page ...
