    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
NEC PG Tube Replacement
 (Page 1)
Page: 1 2 3 4 5
The following procedure was written by Curt Palme.
I’ve been asked to write up a quick procedure on how to change a tube in an NEC PG projector. Removal of tubes in the NEC XG Series is somewhat similar, this can be used as a guide for those as well.
Material Required:
-flat blade screwdriver
-flat blade thin (jeweler’s) style screwdriver
-surgical tape
-Philips Screwdriver
-RTV silicone
While it’s possible, I do not recommend changing the tubes on any NEC set while it’s on the ceiling. The glass on the necks of the NEC tubes is somewhat thinner than the Barcos and Marquees, and it’s relatively easy to snap the neck of an NEC tube if you bash it as you install or remove the tube. Do this with the set floor mounted on a table.
Step 1: Flip up the top cover
Step 2: Remove the two Philips screws on each side of the set that hold the front lens cover in place
Step 3: Remove the 6 Philips screws across the top metal plate that hold the top of the tubes in place
Step 4: Loosen (these screws do not come out all the way) the two screws that hold the deflection board in place.
Next Page ...
