![](images/spacer.gif) |
CRT Primer
Updated: April 2006 |
Ampro
Ampro 2000, 2300, 2600 Ampro was a US
made CRT series of projectors from 1984 to 1998 when they went out of business..
Ampro was known also as: ESP, Gretag Image Systems, and Esprit depending of the
year of manufacture. In general, the picture quality was excellent out of all
Ampro projectors, but have a somewhat lower than average reliability record.
There are many Ampro projectors in the surplus market now, so parts availability
is excellent, and great deals are to be had, as Ampros sell for less than the
equivalent model from a company that is still in business. The image out of an
Ampro is at least equal to that of the ‘big 4’ name brand sets, and are easy to
set up.
Ampro 3600
Ampro made 7”, 8” and 9” projectors.
The 7” models were:
- 1400, 1500: Video only, ES focus
- 2000, 2600 D and G: Data grade, ES focus
- 2300: EM focus data grade
The 8” were:
- 3300, 3600: 8” EM focus data grade
The 9” were:
- 4000: 9” ES focus data grade
- 4200, 4300, 4600: EM focus data grade
All of the Ampros required a serial
computer interface or a custom Ampro
wired or wireless remote to operate and
set up. Without either, the projector is
useless.
Overall , however, many Ampros were
sold, and they are plentiful on the
surplus market. I was told that Ampro
started because of NASA, and continued
to be their largest customer.
Ampro 4600
Ampro Strengths and Weaknesses
The biggest weakness of course is that the company is out of business. Factory
support is nonexistent, and aftermarket parts specific to the Ampros are found
only on the surplus market and from one or two companies consisting of ex-Ampro
employees. . The upside is that Ampros generally sell for less due to this than
equivalent Sony, Barco, NEC or Electrohome models. This can make them an
excellent bargain, as there are lots of parts out there on the surplus market.
Ampro used the same tubes as other brands of projectors, either Sony or MEC.
Common faults with the Ampros are bad
solder joints, and high voltage arcing can cause havoc with the microprocessor
circuits. CRT socket cards are a common problem (repaired easily), but the HV
power supply is made by the same company that sells them to Electrohome, and
failures are usually only solved by replacing the entire supply.
By 1996 or so,
Ampro seemed to have solved some of the reliability issues of the earlier sets,
so some of the later 2000’s and the 3600 and 4600 are on par with other brands
of similar vintage.
I’ve got a good stock of Ampro parts, and can service all models of them.
