CRT Primer
Updated: January 2008 |
Analog Devices (Composite/S-Video/Component/RGBHV)
Composite/S-Video/Component to RGBHV conversion
A typical analog non-HD signal, such as a video or S-Video
signal or a 480i component signal will need some sort of signal processor to
upscale the signal so it won’t look grainy on your CRT projector. This processor
is typically called a line doubler or a scaler. Depending on the model of
projector and your tube size in the projector, your ideal resolution will vary
(see projector resolution ‘sweet spot’).
Most line doublers or scalers will have more than one input
so that all or most of your analog video signals can be switched within the
signal processor. The output of a scaler or line doubler will typically have a
BNC output or an SVGA connector that has the RGBHV signal on its pins.
Many A/V receivers will have video, S-Video and component
switching right in the receiver. This is handy, as your video sources will
switch at the same time as your audio signals without having to push extra
buttons. Note however that a low to midrange A/V receiver typically will not
convert a video signal to S-Video and vice versa, so if you’re running S-Video
signals into the receiver, you’ll need to connect the S-Video output of the
receiver to the scaler. If you’re also running composite video signals into the
receiver, you’ll need to then also connect the composite video output of the
Keep in mind as well that a lot of the lower end A/V
receivers can actually degrade the video signals passing through them, so if you
suspect a poor quality video signal is due to the video switching circuits in a
receiver, simply bypass the video switching portion of the receiver, and connect
your video source directly to the doubler/scaler. A well designed video
switching section of a receiver will have no visible affect on the signal.
Now let’s add some confusion to the mix.
Many of the older line doublers and scalers will NOT accept a component
signal with a higher resolution than 480i. Therefore, a progressive DVD player
component signal (480p) or an HD signal (1080i, 720p) will not be processed
correctly by an older scaler/doubler. If you try to connect higher than a 480i
signal to a scaler that cannot accept such a signal, you might get no image at
all, or you’ll get two images side by side.
How to get around this: If you want to retain a scaler as part of your video
system, you’ll have no choice but to get a late model scaler that will accept a
component signal higher than 480i. Most of the post 2006 scaler models will
accept and process a component signal up to 720p. Examples of these will be the
late model Lumagen and DVDO scalers, the Faroudja DVP 5000, Crystalio, and many
other scaler makes and models. Check the specifications of the scaler you’re
looking to upgrade to to ensure that the component input can be higher than a
480i signal. The bad news is that late model scalers are more expensive than
earlier ones, the upside is that they are available on the used market at this
point, and chances are the signal processing in a later model scaler will be
visibly better than an older unit, so you’re upgrading your picture quality of
all of your sources at the same time.
There are a number of other methods to convert a component signal to RGBHV.
One method is to use a TRANSCODER which is usually just a signal converter. You
input a component signal, you get an RGBHV signal at the output. Many
transcoders will not scale the signal, it’s merely a format converter. There are
a number of brands out there, and range in price from about $75 for a no name
brand, to $600 or more for a broadcast quality rack-mount unit.
![](images/CRTPrimer_figure2.gif)
Most of these transcoders only have one input and one output, so you’ll need
to do source switching externally, either via your A/V receiver or an external
component switcher.
I carry various types of transcoders, including models from Audio Authority (see here).
We also feature the RTC2200 Component to RGB,
TC1600 RGB to Component Converter,
Box1020, and Box1040
products sold by our third party vendors.
Another method to convert a component source to RGBHV is to use a card that
fits into your projector or video switcher that accepts a component input. One
such card is the Sony made IFB 12 card, originally designed for 480p signals
only, but with some minor modifications, can also be used to convert a 1080i
component HD signal. This card is somewhat hard to find, but is available on the
used market for cheap. The card will only fit Sony projectors and Sony
switchers. The ISS2200 component input card for NEC
projectors and switchers is also available from one of our third party
vendors.
Finally, some of the Moome HDMI input cards
for CRT projectors and switchers feature a component input in addition to an
HDMI input. Perfect if you only have 2 sources such as HD satellite/cable
(component) and Blu-ray or HD-DVD (HDMI). So external component switching will
be needed if you have more than one source with component outputs.
