![](images/spacer.gif) |
CRT Primer
Updated: April 2006 |
Setup DVDs
Regardless of the
type of projector you end up purchasing (be it CRT, LCD, DLP, or another), to
get the most out of your setup it is recommended that you use one of the various
setup DVDs available through most major retailers to calibrate both your video
signal chain correctly.
Most of the better setup DVDs help you optimize both
your both audio and video and have on-screen instructions that explain the
process to you step by step. Note: To properly set up the audio portion of
your home theater, most of these setup DVDs require a sound pressure meter.
Radio Shack sells an inexpensive analog one that works very well.
Below are two that are recommend the most. Both work well, but Avia has
a few more test patterns and is (IMHO) a lot more user friendly.
(Using our affiliate links helps support our site at no additional cost to
you. We thank you!)
