![](images/spacer.gif) |
Barco 70x/Cine7
Layout and Setup Tips
(Page 8)
Page: 1 2
3 4
5 6
7 8
9 10 |
IRIS/Controller boards
![](images/Barco701image017.jpg)
The above image shows the optional IRIS board that plugs into the controller
board. The thin gray cable routes to the front of the set and connects to the
IRIS camera.
The controller board is the main CPU and controls and monitors all functions
of the set. There are a series of DIP Switches (not pictured) to the right of
this board, close to the red LED’s on the controller board. These switches
control the ‘auto power-up’ function of the set, so that the set will power up
when the main power is applied, the password function to lock out the
convergence menus, and the rate of data transfer between an external computer
and the projector. The LED’s on the controller board don’t really tell you much
about the operation of the set. The flashing processor light indicates that the
CPU is functioning, and this light will flash on and off whether the set is
powered up or not. The power supply LED’s are much more useful in determining
faults in the set.
