![](images/spacer.gif) |
Barco 120x/Cine9
Layout and Setup Tips
(Page 1)
Page:
1 2
3 4
5 6 |
This section is a supplement to the Barco 808 information already
found in here as the 1208
chassis is similar in layout to the 808.
The information below lists what is different from in the 1208 versus what the 808 chassis uses.
Note that while the layout of the basic chassis is very similar to that of the
808, virtually no boards will interchange between the 808 and 1208 models. The
power supplies, AC input, horizontal and vertical boards and H shift boards are
completely different and can and will cause other components to blow if
interchanged with one another. With certain models, the EHT board, quadrupler,
splitter and RGB switcher boards will swap between the 808 and 1208 models. The
rule of thumb is, if the 761XXX or 762XXX board numbers are the same, they will
switch. If they are different, DO NOT substitute the boards.
Note:
All LED’s in Barcos are color coded.
Green = good and indicate a normal operating
condition
Red = bad and indicates a problem. A red LED that is on may not
indicate an actual fault, it can indicate a lack of sync or signal, but in
general, all red LED’s should be off when the set is in operation and has a
video signal fed to it.
Left side
![](images/Barco1208image001.jpg)
There’s not too much to say about the above image. The layout is the same as the
808 chassis, but with different part numbers for the three boards shown.
