Adds four (4) HDMI 1.4 inputs to your
Barco CRT projector by replacing your existing Port 3 card.
FREE WORLDWIDE PRIORITY SHIPPING INCLUDED
BARCO-FULLHD HDMI 1.4 Input Card with 3D
Includes
a port 3 dongle for external control, and an IR remote |
Regular price: $410 USD
Our price: $359 USD
SEP 2020:
OUT OF STOCK |
Sign up
today to receive the latest BARCO-FULLHD news
Free priority
shipping to anywhere in the world included.
Payment methods include PayPal and all major credit cards
(PayPal account *not* needed to pay by credit card).
Our payment processor
will automatically convert the
amount to
your local currency.
Orders ship direct from the
manufacturer in Taiwan.
Warranty: 1 year all parts and labour.
Upgrade your Barco CRT projector by adding
four (4) HDMI 1.4 inputs with 3D support, gamma correction and infrared remote control.
These digital HDCP-compliant HDMI 1.4 inputs allow you to watch hi-def
content at up to 1080p resolution.
The BARCO-FULLHD card allows you to easily connect digital devices such as
Blu-Ray players, PS3/4, Xbox 360/One, Satellite/Cable HDTV set-top boxes, and HTPCs with HDMI graphic cards to your
Barco CRT projector.
The BARCO-FULLHD replaces the (somewhat useless) secondary RGB port 3
card in
your projector. The mounting bracket on the existing port 3 card is removed by
the user and installed on the BARCO-FULLHD.
A port 3 dongle (included) is then plugged into your
Barco's external port 3 socket. The dongle includes an IR receiver to
allow for IR remote control of the BARCO-FULLHD functions. A 3D sync port is
also available for connecting 3D emitters. For complete details refer to the
user manual (below).
Manuals
BARCO-FULLHD
installation manual
(PDF format)
BARCO-FULLHD owners manual
(PDF format)
Overview
The BARCO-FULLHD offers advanced features such as 100%
HDMI
1.4 compliant inputs, Deep Colour support, 14bit D/A converters,
a maximum resolution of
1920x1200@75Hz (beyond 1080p FULLHD), a fast 1GHz
output buffer, and high quality op-amps and capacitors
on
the output stage for the best image quality possible.
Works with any Barco CRT projector that has a Port 3 board,
including (but not limited to):
Barco 800
Barco 801
Barco 801s
Barco 808
Barco 1200
Barco 1208
Barco 1208/2
Barco 1209
Barco 1209/2
Barco 808s
Barco 1208s
Barco 1208s/2
Barco 1208s/E
Barco 1209s
Barco 1209s/E
Barco Cine 8 / Cine 8 Digital
Barco Cine 8 Onyx
Barco Cine 9 / Cine 9 Max
Barco Reality 809/909
Barco Reality 812/912
Runco DTV-992
Runco DTV-992 Ultra
Runco DTV-1000
Runco DTV-1100/1101
Runco DTV-1200
Zenith Pro 1200
It does not matter if the projector is DATA or GRAPHICS grade. As long as you
have a port 3 board you can use this card. Not sure if you have a port 3 board?
Look on the back of your Barco for an input connector labelled PORT 3.
How does the 3D
work? When used together with a
Radiance video processor, the BARCO-FULLHD HDMI
card allows 3D movies, games, and other content to be viewed on your Barco CRT
projector. The Radiance does the processing to convert the 3D signal into
something your Barco CRT projector can understand and display, while the
BARCO-FULLHD HDMI card interfaces with and controls your 3D glasses through the
port 3 dongle (included) which plugs into your Barco's port 3 socket. Enjoy 3D
at 720p120Hz or even at custom resolutions like 1080p75Hz.
Any
Infrared (IR)
Active Shutter glasses or Radio Frequency
(RF) Active Shutter glasses that include an
emitter will work with the BARCO-FULLHD card as long as the emitter has
the standard 3-pin DIN connector.
Features
Four (4) HDMI 1.4 inputs. HDMI 1.0, 1.1, 1.2, 1.3,
1.4, HDCP 1.1, 1.2, and DVI 1.0 compliant
DTV mode support
(480P,576P,720P,1080i,1080P) up to 75Hz
PC mode support VGA, SVGA, XGA, SXGA, UXGA,
etc.
Supports 4:4:4 RGB / YCbCr input
Supports 4:2:2 YCbCr input
Support both 16-235 and 0-255 color range
14bit Data processing with High precision
250MHz 14bit DAC
Improved advanced gamma correction
processing and white level adjust
High speed and ultra 1.65GHz bandwidth
output Buffer
Supports deep color mode for 10bit and
12bit
Support 100/120Hz for 720P and 1080i
- Ultra Low ESR capacitors to filter noise,
leading to the cleanest image possible
ESD
improved to prevent electrostatic discharge damage while plugging in HDMI
cables
IR control input selection and gamma level
adjust
- The port 3 dongle (included) is fully compatible with BARCO series port3
input slot
Pictures
Before bracket is attached:
![](images/BARCO-FULLHD9.jpg)
With bracket attached:
![](images/BARCO-FULLHD5.jpg)
Installed:
![](images/BARCO-FULLHD3.jpg)
![](images/BARCO-FULLHD7.jpg)
![](images/BARCO-FULLHD6.jpg)
![](images/BARCO-FULLHD11.jpg)
![](images/BARCO-FULLHD2.jpg)
(Click for high resolution
version of the above image)
The Port 3 dongle:
![](images/BARCO-FULLHD_port3_ctrl2.jpg)
Reviews/Testimonials
"I plugged in the card half an hour ago and am amazed.
My old hdmi moome card had the problem that I had to start the Barco cinemax
first and than start the hdmi source. If I did it in the other order the Max
would get in very strange errors and the HV would shut down. This one works
as it should. A lot of led start to talk to each other and after a few
second there is an image regardless of what order I start. But the image?
Amazing!!!! That is why I had to stop watching and write this. It is sharp. Very
sharp. Real. Best I ever had. The 1080p one on one showed also the best I had
(comparable to a Mac vga adapter with ultra short cable). After adjusting
brightness and warming up I looked at some of my familiar movies and as I
said looked very very good. Gave me the feeling that I have a new projector
again. Now I was going to be very honest and critical if that would be
necessarily but respect to Moome this is a top card!" -
redfox001 (complete
review)
Need more information? See the BARCO-FULLHD forum thread
Visit the Moome Discussion/Support Forum
Questions should be directed to the PJI-HD company (Moome) at:
moomecard@curtpalme.com
When
purchasing you will be paying and
dealing directly with the third party
seller Moome in Taiwan.
DISCLAIMER (Legal mumbo-jumbo because we have to): Any dealings with the third party
seller/manufacturer listed here, including the delivery of and the payment for
goods and services, and any other terms, conditions, warranties or
representations associated with such dealings or promotions, are solely between
you and the third party seller/manufacturer. Curtpalme.com shall not be responsible or liable for any part of any such dealings or promotions.
CURTPALME.COM IS NOT THE SELLER OR MANUFACTURER OF THESE PRODUCTS OR SERVICES.
THE SELLER/MANUFACTURER MAY HAVE PROVIDED A WARRANTY ON THE GOOD(S) PURCHASED.
CURTPALME.COM HAS NOT MADE, AND DOES NOT MAKE, ANY REPRESENTATION, WARRANTY,
PROMISE OR COVENANT, EXPRESS OF IMPLIED, AS TO THE CONDITION, QUALITY,
DURABILITY, CAPABILITY, FUNCTION, PERFORMANCE, OR SUITABILITY OF THE EQUIPMENT,
ITS MERCHANTABILITY OR ITS FITNESS FOR ANY PARTICULAR PURPOSE. BUYER AGREES THAT
CURTPALME.COM SHALL NOT BE LIABLE FOR EITHER SPECIFIC PERFORMANCE OR ANY
LIABILITY, LOSS, TAMPERING, ABUSE, DAMAGE, INCLUDING CONSEQUENTIAL AND
INCIDENTAL DAMAGES, ARISING OUT OF BUYER'S PURCHASE OF THE EQUIPMENT, ANY
DEFECTS IN THE EQUIPMENT, OR FAILURE OF SELLER/MANUFACTURER TO TIMELY DELIVER
THE EQUIPMENT.
